Question about HP Pavilion dv9000z Notebook
My lap top dont turn on, only the lightning icon will lit when pluged to the power source, but if I take out the battery the lightning icon truns off
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
Posted on Sep 18, 2010
Battery will not charge connection seems loose
your battery charger is bad theres bad cell in it what happens is when pluged to long it makes the cells weaker the longer it sets on your lap top wile your lap top charged.
Feb 15, 2011 | Computers & Internet
No power will not trun on
Hello
Plug in the printer power cord into electricity to charge the battery.The battery might need charging if the On light flashes green it indicates that the battery is charging.
Switch ON the printer, the battery charging icon (lightning bolt icon) flashes above the battery icon on the printer screen to indicate that the battery is charging.
If the battery is charged and the printer does not turn on with the battery power, unplug the printer power cord, if it is plugged in. Open the battery compartment and remove the battery. Wait for about 10 seconds, and then reinstall the battery.
An empty battery should fully charge in approximately four hours when the printer is not in use. If the battery still does not charge in 4 hours,you should replace it
Good luck
Apr 23, 2010 | HP PSC 2210 All-In-One InkJet Printer
My lap top makes a snap nose and then truns off is it just the batterie or is could it be more just want to know if it's worth fixing it's a Hp pavilion n5350
It could jmust be the battery. When it happens, is your battery low? Does it happen if you have the lap top plugged in and not on battery power? If so, then it's not the battery.
Mar 13, 2010 | HP Pavilion N5350 Notebook
Micron Trek 2 laptop won't start on battery or AC (NBKU375)
The lightning bolt is used to indicate an electrical problem but then, you know that already :-( Try removing the battery pack and start it from AC only; some battery types don't like to be ignored, they can have individual shorted cells.
Sep 30, 2009 | Computers & Internet
Monitor goes to sleeep on lap top
Hello, you can try this... Connect your laptop with an desktop monitor throughVGA cable.... then Click on start>> goto control panel>> Double click on Power Option>> Under Power Scheme it should be Poratble /Laptop >> Select Never under System Standbye, Trun off Monitor and Turn off Hard Disk.
Thank you for contacting Fixya support, please rate if that helps!!
Sep 06, 2009 | Relisys RLT1720 17" LCD Monitor
Flashing stike laptop won't start
lightning strike usually is battery indicator try charging/replacing battery also battery might be dead and ac adapter broken
Jul 06, 2009 | Computers & Internet
Lap top not turning on
i dont know anything about the number 9 lock thing, but try plugging your laptop into a power supply if you havent already, if that fails then take out the batteries and put them back in again, this worked for my friend when a similar problem happened
hope this helps
josco91
Jun 23, 2009 | Dell Latitude D430 Notebook
Blank screen
You need to power drain
step1. remove battery and ac adapter for your laptop
step2. HoLD POWER BUTTON for 30secs-1mint
step3. put back battery and ac adapter
step4. power on it sud boot normally
try this hope it helps you
Feb 25, 2009 | HP Pavilion dv6000z Notebook
Palm v
the lightning bolt indicates that the battery is being charged. I will stay on as long as it is being charged either in the cradle, or using an external charger. If it stays on after it is removed from any external power source, there is a problem with the unit and it needs serviced.
--Randy Miller
Aug 25, 2008 | Palm TX Handheld
Charging, downloading
your lap top probbubly has a power saving seting for your usb ports ..try changing that or pluging into a regular desktop computer... it will turn on when it is charging and show a lightning bolt going through the pickture of the battery...
if that dosent work make use of the warenty (if it is still useable)
May 18, 2008 | Creative Labs ZEN V Plus MP3 Player
HP Pavilion dv9000z Notebook Logo
88 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
