Question about Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed
WhaT TYPE OF OIL DOES THE 16.5 HP B&S engine take
  • 183 Answers
Your 16.5 hp Briggs engine takes SAE HD30 weight motor oil. I recommend to use a name brand high quality oil. It should take 48 ounces from a complete drain. If you run this engine when it is cold outside (below freezing) then you can change to a 10W30 oil.
Good luck
Posted on Sep 16, 2010
  • 2strokeguy
    2strokeguy Sep 16, 2010
    I forgot to mention, Briggs recommend to change the oil every 25 to 50 running hours depending on conditions. Most shops will recommend to the average homeowner to change oil every year, and to the professional/commercial user to change oil every week.
What oil do I use for a G Force 2 HP air compressor, model 50622
  • www.air-compressor-guide.com/.../air-compressor-oil Keep your compressor in top condition by using the right air compressor oil. Make your compressor run nice and smooth. Using the right air compressor oil for your ...
  • Oil - Air Compressor Oil ' RONA www.rona.ca > ... > Parts and Accessories - Compressors Compressor oil. 473 ml. For all oil lubricated air compressors.
  • Husky 16 oz. Air Compressor Oil-HDA10700AV - The Home Depot www.homedepot.com/p/Husky-16-oz-Air-Compressor-Oil-HDA10700AV/...
    • 5/5
    • 1 REVIEW
    • $2.49
    • IN STOCK
    Air Compressor Oil from Husky is designed to reduce carbon buildup in compressor valves to ensure a longer compressor life.
  • Air Compressor Oil & Lubricant www.ecompressedair.com/compressor-oils.aspx eCompressedair is your source for Air Compressor Oil & Lubricants for major air compressors and synthetic compressor oil brands in 5 gallon air compressor oil ...
  • Oil-free air compressors - Atlas Copco Canada www.atlascopco.ca/caus/products/air-and-gas-compressors/1472896 Oil-free centrifugal compressors. Oil-free reciprocating piston compressors. Oil-free rotary tooth compressors. Oil-free screw compressors. Oil-free scroll compressors
  • Air Compressor - Oil-Free Air Compressor ' RONA www.rona.ca > ... > Products > Tools > Pneumatic Tools > Compressors Air Compressor - Oil-Free Air Compressor. Oil-free air compressor. 26 gal. Vertical, saves 50% more space. 1.7 running HP. 120 V. 15 A. Easy to operate controls with ...
  • May 17, 2016 | Air Tools & Compressors
    What kind of oil goes in a 2003 ford focus with new motor?
    Depends on what engine you have.
    2.0 HP Zetec SVT Focus 5W-30 motor oil all others 5W-20 motor oil.
    Feb 23, 2015 | 2003 Ford Focus
    Oil issue
    try running the engine for 10 minutes then remove the drain plug. The sump oil is burnt to almost tar from lack of service or badly worn rings allowing combustion fire into the sump
    Jun 01, 2013 | Tools & Hardware - Others
    Blow by coming from the dip stick seal oil on Briggs & Stratton Vanguard 16 HP v-twin
    2 options--- replace the dusted motor (faulty air filtering system) or re-ring the engine. Go for the new engine as the dust will have worn the piston and bearings.
    Mar 22, 2013 | Cars & Trucks
    Engine knocking
    hello sir, check to see if the engine is over full on oil and gas in the engine .this will make starter drag eventually ruining starter.this is the only thing i can think of other than engine having high compression except valves not opening and the pressure relief valve not working,or engine low on oil 30 WT, is also important to keep good oil in engine and full. the solenoids under the carburetor will go bad,and cause flooding, if you have one. make sure you keep battery charged. if it is follow these directions ,well it is a simple fix,but a lot to correct problem, parts needed,1 new spark plug,1 new solenoid,1 quart of 30wt oil,1 pan to catch old oil in. tools needed,1 spark plug wrench,1,7/16 or 1/2 or 9/16 open wrench,pen&paper. ok, empty fuel tank or clamp off fuel line,make a drawing as how the wires are connected to the solenoid,white & black wires,unplug wire fittings,remove solenoid, in stall new solenoid,plug wires in. now drain oil & gas out of engine,remove old spark plug,important so follow directions,after oil is drained plug is out crank engine so to clean out cylender of excess oil & gas,it would be a good ideal to let oil drain for a while. add oil & spark plug,engine will smoke for a while but should clear up.when you go to the parts store you will need engine horse power,engine brand,mobel number,type number,parts should cost around 50.00. including everything you need,check oil often you can put a inline fuel shutoff in the fuel line about $5.00, or replace solenoids for $40.00.hope this helps,don't forget the 4 thumbs up,any comments welcome,thank you,,after you need to check this, ``
    Feb 15, 2012 | Garden
    Husqvarna 22hp Oil blowing breather Problems
    Feb 14, 2012 | Garden
    I have a Husqvarna 340? with 16 inch bar. Has sat for a while but now will not start. It pulls fine but doesnt crank. Second, what type oil should i mix with the gas
    Any brand of 2-cycle oil for air cooled engines will work. Do not use outboard, snowmobile, etc. Sounds like the gas evaporated and the oil was left in the carb and clogged it up. You can try removing the air filter and spraying some gum cutter, carb cleaner or Sea Foam(my favorite) into the carburator. It will probably need to be diassembled and cleaned. Usually the hardest part of the job is getting the link and hoses unhooked.
    Feb 21, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
    I'm looking for the oil presher switch on a 2000 Grand Am GT
    Look on the engine block for a sensor with wires on it: Sending Units & Switches Oil Pressure Sensor/Switch Removal & Installation To Remove:
    1. Remove the battery negative cable from the battery.
    2. Raise and safely support the vehicle.
    3. Disconnect the electrical connector from the engine oil pressure sensor.
    4. Remove the engine oil pressure sensor.
    To Install:
    1. Install or connect the following:
      • Engine oil pressure switch. Tighten the switch to 12 ft lbs (16 Nm) on the 3.4L engine, 16 ft lbs (22 Nm) on the 2.2L engine and 106 in lb (12Nm) on the 2.4L engine.
      • Electrical connector to the engine oil pressure sensor.
    2. Lower the vehicle.
    3. Install the battery negative cable to the battery.
    Aug 19, 2010 | 2000 Pontiac Grand Am GT
    What type of oil do I use in my remington 16 inch 3.5 hp electric chainsaw?
    You need “Bar and Chain Oil”, available at hardware stores and home centers. It is SAE 30 with additives to make it adhere to your bar and chain.
    An excerpt from a Remington manual follows (edited).
    FILLING OIL TANK
    1. Remove oil cap.
    2. Fill oil tank with SAE 30 motor oil if the temperature is between 30 & 75°F.
    • Colder use SAE 10 oil.
    • Warmer use SAE 40 oil.
    3. Replace oil cap at once. Tighten oil cap firmly for a good seal. This will avoid oil seepage from tank.
    4. Wipe off excess oil.
    • It is normal for oil to seep when saw is not in use.
    • Empty oil tank after each use to prevent seepage.
    If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
    Lou
    Thank you for using FixYa.
    Apr 11, 2010 | Remington 16" Electric Chain Saw
    Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed Logo
    1,011 people viewed this question
    Top Poulan Garden Experts
    Roland W VanLue
    Roland W VanLue
    Phil Walker
    Phil Walker
    Are you a Poulan Garden Expert? Answer questions, earn points and help others
