Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Formula dispenses too fast. I only cleaned an area 3x10 and the formula tank was empty.
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Sep 16, 2010
The cleaning solution does not dispense
Hello, this is Ava with Think Crucial.
There are a number of reasons why your unit doesn't spray water. It could be that the !) water tank is empty which you can fill heavy duty bladder with hot tap water. 2) If Formula tank is empty, you can fill it with Bissell 2x formula for cleaning. 3) If tank may not be seated properly, turn the power off, remove and reseat the tank. 4) If pump may have lost prime, try to turn off and then turn on the unit, wait for one minute and depress trigger. If still nothing happens, I suggest you contact Bissell 1-800-237-7691 for further assistance.
I would like to let you know that you can order replacement parts for your vacuum needs. Please visit our website
http://www.thinkcrucial.com/search?type=product&q=bissell
As a special offer here is an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Think Crucial Customer Care
Aug 06, 2016 | Bissell 1698 PowerSteamer ProHeat Upright...
We have a bissell lift-off deep cleaner 66e1 and it won't suck up the dirty water what can I do to fix it
Loss of suction power -
1. Tanks may not be seated properly - Pick up both tanks and reseat them so they fit properly on the unit.
2. Nozzles may not be assembled properly - Unplug the unit. Check to make sure the "lip" of the nozzle cover is securely hooked into the groove on the top of nozzle.
3. The portable spot cleaner is not attached completely - Push down firmly to check connection
4. Dirty tank has picked up maximum amount of dirty water and has reached full line - Empty dirty tank
5. Formula & water tank is empty - Check fluid levels in formula & water tank Suction Gate is open Check to make sure the suction gate is closed. Follow "Cleaning Suction Gate" instructions in the manual.
I hope this helps!
Jim
May 27, 2016 | Bissell Vacuums
My formula tank is not emptying on my 8910 proheat eurka cleaner
Make sure it is on heavy traffic on the selector set. You may find it is on Clear water rinse. FYI you will find your machine will clean better and your carpet will be cleaner if you use a weed sprayer and mix your soapin it. Just spray it down fairly heavy and let it set for 10 minutes. Then just use straight water in both tanks and you will be amazed. It is like a lasagna dish if it soaks for a while it comes cleaner easier.
May 13, 2014 | Bissell 8910 ProHeat Clear View Upright...
It is not dispensing water and solution
Clean Water
Solution Tank
won't dispense.
1. Clean Water Solution Tank
not firmly in place.
1. Make sure tank is securely locked in
position.
2. Clean Water Solution Tank
empty.
2. Refill tank according to instructions for
surface being cleaned.
3. Dirty Water Tank lid not on
correctly.
3. Make sure lid is firmly in place.
4. Pump needs to be "primed"
(when using tool).
4. See "Before Using Tool" section.
Dec 17, 2012 | Hoover SteamVac F5914-900 SpinScrub...
I have a Bissell ProHeat Turbo 2x, it isn't mixing the water & cleaning solution and isn't spraying. What do I do?
Isn't Spraying:
Possible Problems->Solutions
-Water Tank may be empty-> Fill Heavy duty bladder with hot tap water.
-Formula Tank might be empty-> Fill with Bissell fiber cleansing formula for cleaning.
-Tanks may not be seated completely-> Turn power off and reset the tanks.
-Pump may have lost prime-> Turn power off, then on again, wait one minute then depress the trigger
You can also contact Bissell at: 1-800-237-7691 begin_of_the_skype_highlighting 1-800-237-7691 end_of_the_skype_highlightingto help you out on why the cleaning solution and water aren't mixing, but first try fixing the first problem, you never know, it might cure the first one. :)
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Jun 04, 2011 | Bissell Vacuums
No cleaning formula or water is coming out of the dispenser. Any suggestions.
Just a thought, did you fill the dispenser or just the bladder inside the dispenser with water? The bladder inside is filled with water through the hole on the left side of tank. The waste water then goes in the tank around the bladder, a 2 in 1 deal.
If you have filled it correctly and are still having problems, please write back.
I hope this helps. If it does, please place a vote or comment for me. Thanks,
Handie Andie
Mar 30, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
Red x does not turn water does not aooear to release properly
repaired many of these!
most likely its the pump.. the pump is located down by the brush...its belt driven(make sure your belt is there and in good condition)
the heater is located in the handle area...you could remove the hoses and blow through one end...shouldnt be restricted..
other possibilities
  • bladder maybe empty
  • formula bottle maybe empty
  • tank may not be seated properly
  • tank filter maybe clogged
Oct 05, 2009 | Bissell 1698 PowerSteamer ProHeat Upright...
Kirby Sentra Shampoo tank empties too fast
You can control how much foam the unit dispenses with the dial on the tank.
Mar 17, 2009 | Kirby G5 Bagged Upright Vacuum
I cant get it to ****
This is from the owners manual that I have provided a link to, so that you can have a copy for your records. I hope this helps.
http://www.bissell.com/images/UserGuides/9500_908.pdf
Possible Causes Remedies 1. ReadyTools dial may be at wrong setting. 1. Set ReadyTools dial to either FLOOR CLEANING or TOOLS setting. 2. Tank may not be seated properly. 2. Pick up both the 2-in-1 water tank and formula tank and reseat them so they fit snugly on the unit. 3. Tank may not be assembled properly. 3. Check to make sure the "lip" of the nozzle is securely hooked into the groove on bottom of Tank (see page 9). 4. Solution or 2-in-1 water tank is empty. 4. Check fluid levels in heavy duty bladder and formula tank. 5. 2-in-1 water tank has picked up 5. Empty 2-in-1 water tank. Refill maximum dirty water and red float heavy duty bladder with clean door has closed. hot tap water and replace. 6. Red float "door" in the tank may have closed 6. Turn the machine OFF ( O ), as a result of bumping an object or moving allowing red float door to release into machine back and forth too quickly. the open position. Turn unit back ON ( I ) to continue cleaning. Be sure your forward and backward strokes are done at a slower pace.
Jan 22, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell ClearView powersteamer carpet cleaner does not seem to be dispensing water in the pre-treat mode
Pretreating (optional)
Note: Pretreating is recommended to improve
cleaning effectiveness for heavily soiled carpet in
high traffic areas such as entryways and hallways.
A.
Spray the BISSELL Tough Stain Pre-treat formula
onto heavy traffic areas, soiled areas, or stains.
B. Allow to penetrate for at least 3 minutes.
Maybe isn't su[pposed to dispense water, just the Pre-Treat solution. Then after a few minutes, shampoo normally.
Mar 29, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
142 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
