Question about HP DeskJet 970cxi InkJet Printer
970cxi hp printer
Inkjet cartidge light keeps on flashing tried replacing with new cartridges
still the same
  • 3 more comments
  • chinablue32u Jun 28, 2008
    Hello I am having the same problem I am wondering if it is because I am using refurb cartridges I have tried 2 carts from a company called ijt direct do you think this could be the problem????? did you sort yours
  • Anonymous Aug 07, 2008
    Red light,3rd button left flashing printer will not work.
  • arrakeen Nov 13, 2008
    I used some Refurb Cartridges and over the span of a year or so printing in B&W I neglected them. They dried out and the printer was simply not functioning. I was going crazy thinking it was a driver, the USB cable, the OS or everything else. I normally refil my own cartridges.
    The lesson here is NOT to let the cartridge dry out. If you do it will fail when you need to print a 50-page report right now in black only but this old workhorse will just upchuck because the Color cartridge dried up. Screwey that you have to have a working color cartridge to just print black. Go figure.
  • zhongyur Nov 30, 2008
    What is PCA?
  • eccredit Mar 27, 2009
    What is PCA???
  • 1,031 Answers
The PCA is held to the carriage /cradle by usually one or more screws. sometimes these loosen over time, so while the contacts on the PCA and the ink cartridge look ok, they're not actually making good contact. try removing the pca from the cradle, and reattaching it, making sure you torque the screws down firmly (but don't crack the board). sometimes a small washer or shim helps to get the board closer to the carts.
many times if you look along the top of the cradle/PCA assembly, you will notice that the gap between the board and the cradle is not uniform. this is usually a dead giveaway, and snugging up the screws will usually fix it.
also if you closely examine the cartridges, you may notice that the indentations or scratches on the contacts aren't uniform which may also point to a skewed PCA.
Posted on May 17, 2008
My deskjet 6122 will not print but a teardrop looking button light keeps flashing. Have tried shutting it off and unplugging but no help??? Bryan
The teardrap light imples that your ink cartridge needs replacing or is incorrectly installed. If you have recently replace your incartridge, check to make sure it is properly installed. If it has been a while, your cartidge probably needs replacing.
Nov 18, 2010 | HP DeskJet 6122 InkJet Printer
I just had my ink cartridges refilled, but the ink light keeps blinking and the printer won't print.
probably needs to be reset !! go on the Internet and do a search for "How to reset my HP Deskjet 970cxi" and that will tell you what you need.
Nov 01, 2010 | HP DeskJet 970cxi InkJet Printer
Resume button will not stop flashing.
The HP series of printers you have can be finiky when cartridges are swapped. Use an old toothbrush to very gently clean the contacts behind both ink cartridges. Carefully wipe off the contact strip on the back of each cartridge. repeat this till the cartridges are properly detected. close the lid after each attempt!
Nov 10, 2009 | HP DeskJet 895cxi InkJet Printer
HP Deskjet 970 Cxi. Printer cartridge light flashing.
Try removing the printer icon in Printers and Faxes and reinstall.
Hope this helps.
Aug 17, 2009 | HP DeskJet 970cxi InkJet Printer
Flashing orange light
My printer will only print when both cartridges are installed, regardless of what I am printing.
May 13, 2009 | HP DeskJet 970cxi InkJet Printer
What does the orange light blinking on the computer mean?
It generally means that you have an empty, damaged, or incorrect ink cartridge installed.
May 04, 2009 | HP DeskJet 970cxi InkJet Printer
Hpdeskjet 970cxi only prints blue and black
When refilling cartridges it doesn't always work. replace the ink for known good or new cartridges.
Feb 19, 2009 | HP DeskJet 970cse InkJet Printer
Problem printing with HP Business inkjet 1200
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
Oct 28, 2007 | HP Business Inkjet 1200dtn Printer
HP DeskJet 970cxi InkJet Printer Logo
332 people viewed this question
Ben Johnson
