Dryers Logo
Posted on May 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Glowing Red in Dryer
I'm not sure if this is just something I never noticed, or if it is a problem. I can see the element glowing red inside of my dryer behind the screen, only on one side, it is also reflecting red off of the wall behind it. Is this normal?
Anonymous
Level 3:
  • Master 413 Answers
  • Posted on May 29, 2008
Anonymous
Master
Level 3:
Answers
413
Questions
0
Helped
209720
Points
1203
The element will glow brightly with the door open because there will be no airflow through the dryer. DO NOT operate the dryer this way for long periods or the element will overheat and fail. If the element glows brightly (as seen from the rear of the unit) with the door closed, it may be an indication of restricted airflow in the exhaust system.
Anonymous
Level 3:
Genius:
  • Master 1,073 Answers
  • Posted on May 17, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1073
Questions
0
Helped
392243
Points
2842
1helpful
Should the lower oven heating element heat all the way around? The heating element in my oven only heats and glows red on the front and two sides, The rear part of the element never glows red.
This is probably normal. the element has a fine wire inside the tube that you see and depending on where it starts in the tube it will start glowing from there.
Creda simplicity t313vw glowing red and heating to quick
I'm not familiar with the T313vw, however, if it's an electric dryer, check the element and make sure that the element isn't grounding out to the chassis. You can check it with an ohmmeter set to check continuity by unplugging your dryer and disassembling it a little to get access to the element, then disconnect one of the leads to the element and place one lead from your ohmmeter on the terminal you just disconnected and the other lead to the chassis ground. You should have NO continuity. If you read a short, then your element is grounding out and needs to be replaced.
Barring that, a bad operating thermostat can cause similar problems.
1helpful
Roper Dryer RED4440SQ0 TOO MUCH HEAT
T'he glow you saw was on the back wall in the dryer behind the a grated area if I'm correct. What you saw was the heating element, or a reflection of it while it was on. The element glows bright red when power is being applied to it to function and is housing is made of sheet metal so it does carry a reflective quality. If you really want to make sure that the dryer isn't over heating, which I don't believe it is due to the fact that would mean the high limit thermostat has failed in a way that I've never really seen, take the vent off the back and using a digital thermometer check to see how high it gets before the machine cycles off and the temperature drops.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Kenmore dryer. Glowing orange inside rear vent. Outside dryer very hot. Ideas?
the orange glowing is the element, since there are safety features on the dryer I would not worry about the glowing as they are coils and glow. I would probably clean the dryer inside and out off all lint, thus ensuring that the air flow for the dryer is not restricted. Hope this helps Tim
1helpful
2answers
I have a Hotpoint CTD00G. My wife reported to me the drum was not turning on the dryer and there was a smell of burning and when she stopped the dryer and opened it she said it was glowing red hot at the...
this would be the heating element, and as long as the thermal fuse is not bypassed it is all good. You might want to clean all the lint inside(taking the dryer apart) and outside(vent tube) of the dryer, this should be done at least once a year if not twice depending on the usage. The thermal fuse is a safety feature which senses temperature and blows(one time use) thus preventing a fire. Hope this helped Tim
May 15, 2011 • Dryers
1helpful
Heating element is getting red hot - like a heater.
No the first thing I would check is the vent going outside may be cloged the air going across the heating element should keep it from glowing real bright
Bottom oven element sparked then quit working
The element sometimes will continue to arc inside after it burns out. It's 220 volts jumping across the break.
Top Dryers Experts
john h
