Question about Dynacraft Girls 16" Barbie Bike
16 inch bicycle tire is flat. Need replacement, where to buy?
Call Dynacraft (bike maker) at 1-800-551-0032. My daughter's rear tire was flat and they sent out a new tube for free. She had the bike for only about 4 months. They also sent out a new rear tire as bearing/coaster brake assembly was make noises. The only problem is her original rim was purple and they sent out a silver colored rim as they don't have purple replacement part. I also had to install the tube and tire on the new rim. They only send replacement parts not assemblies.
Posted on Sep 30, 2010
I have a Gio 500w ebike. The tube inside the back tire needs to be replaced and I cannot find the size to buy anywhere.The Gio website sells them but dont give u the size. I was also told that you can...
Hi! I have 2 Gio Scooters. I looked and looked for a tube for my tire and couldn't find a place until I realized that if you go to Ebay online you can actually buy them through Sven the supplier who sells the Gio Scooters on Ebay. You can just buy them from him and pay through paypal. Make sure the valve is curved and not straight out or it's not the right one. He ships pretty fast too:) I hope this has helped. It took me awhile to get parts. He also will ship parts, he's out of Vancouver. So Good Luck:) Do you know anything about fuses for these bikes???? Grrrr....
TTYL.G
Jun 15, 2011 | Health & Beauty
Tip
How to Change a Flat Bicycle Tire
1) Begin by looking at your old bicycle tire, and find the dimesions of the tire on its side. Write down these dimesions, becuase you must then go buy a new innertube for the tire that is the same (or about the same) size. I suggest going to a bicycle store; at the one near me tires run about 5-10 dollars.
2) With this new innertube in hand, you can begin changing your bike tire. You must start by taking off the entire bike wheel. To do this you need a hexagonal-shaped wrench thingy that looks like this:
See the hexagonal wrenches on the left side? You're ging to need something like that to remove the wheel. If you don't already have one, you can get this one from here (Walmart.com), or you can look up 'bike tool' on Amazon or Ebay.
3) You then use this tool to remove two hexagonal bolts, one on either side of the wheel; shown here:
Then use a flathead screwdriver or another falt object/tool to pop the outer tire off to expose the old innertube inside, like this:
4) Remove this old innertub, and put the new one around the wheel. It might seem a little big, but that's okay. Proceed by slipping the outer tire back on over the new innertube, using the same tool you got it off with.
5) Put the wheel back on the bike, screw the bolts back in, and inflate the tire to whatever PSI (Pounds per Square Inch) it says on the side of the tire.
6) You're bike is ready to ride again!
on Feb 16, 2010 | Cycling
Can you buy spare tires for an old baby jogger performance, the tires are 16
I'm sure you can, but some more details would be necessary. Look at the sidewalls. There should be a set of numbers molded int othe rubber that goes something like "# x ?.??". Copy it down verbatim and look for that same spec. A real Bicycle Shop would be glad to assist you in identifying and obtaining what you need.
Or look on eBay.
Feb 20, 2011 | Cycling
The back rear tires will not keep air in them. How do I fix them or do I need to replace them? (Baby Trend Jogging Stroller)
More than likely there's a leak, maybe small but enough to cause a flat.
As for tubes your local bike shop may carry the 12" or the 16" depending on the stroller make and model. Check the side of the tire to see if you can identify the size, if not the stroller manufacturer or the site should give you more information.
The tires with these jogging strollers come off fairly easily with any regular bicycle tire levers. Although it's possible to take them off by hand, if it's difficult any bicycle shop would carry standard bicycle tire levers. I personally recommend the life time warranty tire levers by Pedro. They are very strong and designed to take off some of the beefiest mountain bike tires.
It would also be good to have spare tubes. You can find bulk tire tubes on eBay for cheap!
Nov 04, 2009 | Baby Trend Expedition Double Jogger
My jeep jogging stroller has a flat. Do I need to
Replacement tube may be more beneficial even though the fix/patch may be cheaper. If you live in an area that have varying climate, the patch along with the repaired tube can expand and contract and may cause small leak if not repaired properly.
Otherwise I would get the right size tube, most jogging strollers are either 12" or 16" tube inside and can be bought from your local bicycle store. With that, you'll need bicycle tire levers which can also be bought at the bike shop. Just about any type of tire levers will do. Of course I'm sure your bike shop can do this for you to possibly for free with a purchase of replacement tube!
Oct 27, 2009 | Jeep Liberty Limited XT Urban Earth Jogger
Replacement parts.
Many Valco Baby models are equipped with 12 inch tires. Just like a car or bike, punctures can occur. A 12 inch inner tube or bicycle tire repair kit would be all you need to seal the puncture. If need be, tubes can be purchased from your local retailer or contact them at (USA) 800 610 7850 or email info@valcobaby.com Tubes are not covered under warranty.
Aug 29, 2009 | Valco Twin Runabout - Blue Jogger Stroller
Dynacraft Girls 16" Barbie Bike Logo
1,377 people viewed this question
Top Dynacraft Cycling Experts
Michial Gueffroy
Tony
shaun taylor
Are you a Dynacraft Cycling Expert? Answer questions, earn points and help others
