Question about Sentry Fireproof Safe
I have a protocol home safe and dont have code or a key
3 Suggested Answers
SOURCE: i have a protocol home safe box i cant find the
The plastic panel where the Protocol lable is comes off and you will see the key lock. Be gental, don't break it.
Posted on May 15, 2010
SOURCE: Can't open my Protocol Home Safe - Electronic Keypad Entry
Hi I have a Sure Safe electronic key pad safe, i have owned for about 5 years we have moved house and it was placed in storage.
For the life of me i can not remember the code i have tried endless times !! is there a way to get in or do i take it to a professional.
Posted on May 29, 2010
Mother just past away,luckily safe was open at time,but dont know combo to keypad or we haven't found a key,how do i reset code to sentry10 gunsafe
To reset the combination on a Sentry safe, open the door of the safe, delete the existing codes, press the PROG or P key and enter the factory code. Finally, enter a new five-digit number as per individual preference, which is the new user combination.
It is always prudent to reset the combination on a Sentry safe when the door is open because it prevents the user from being locked out. To open the Sentry safe door, type the five-digit factory code given in the owner's manual. This factory code cannot be altered.
To delete the existing codes on newer models of the safe as of 2015, press the P button. Then, type the factory code and follow it up by inputting "00000" into the safe. On older models of the Sentry safe, press the PROG button and type the factory code two times.
After deleting the existing codes, press the PROG or P key and then enter the factory code once again. Within five seconds, type a new five-digit number, which is the new user code. To verify if the user code is working, retype it and then close the door of the safe. The user code is the primary code for opening the safe, and users can reset it as often as they want too
Mar 21, 2017 | We Home Security
Need a key for protocol home safe
You will need to contact the manufacturer with the model ,serial number ,and proof of ownership for a replacement key
Feb 21, 2017 | home Home Security
How to reset number code on my secursafe. I bought never set it up I have key but dont know how to set up safe with pass code
Open the safe with your key (key slot behind the blanking plate btween the safe knob and the keypad).
on the back of the door is a plastic housing put your hand on the side of the housing near to the hinges, you will feel a small push button.
Press it once the unit will beep and the far right led will illuminate.
key in your new code (8 digits) then press either A or B.
Job Done!
Feb 14, 2017 | Home Security
I dont have the keys for godrej taurus safe locker and i forgot the lock code
i dont have the keys for godrej taurus safe locker and i forgot the lock code
Feb 20, 2012 | Safe International Safelock Front Loading...
I have a 2wire gateway modem/router and i need to reset it, but i dont have the default password located on the bottom of the modem/router because it fell off. I need to find out what the default password...
Open your Internet browser.
Type http://gateway.2wire.net/setup into the browser's address line.
You should see your key on the setup page.
Back-Up Key Codes
In most cases, you will receive a key code from your ISP. This key code is used to activate the 2Wire gateway. If you did not receive a key code, you can use the key codes provided in the following table.
If your Internet Service Provider did not provide you with
a user name, password, or IP address to set up your
Internet connection, your broadband connection most
likely uses DHCP (Dynamic Host Configuration Protocol)
and you should use this key code.
52EU-2374-2262-22AT-B222
If your Internet Service Provider gave you a PPPoE
username and password to set up your Internet
connection, your broadband connection uses Point-to-
Point Protocol over Ethernet and you should use this key
code.
52EU-2374-6262-22AS-B22Y
If your Internet Service Provider assigned you an IP
address to set up your Internet connection, your
broadband connection uses static IP (Internet Protocol)
52EU-2374-2E66-22AS-B2TW
If your Internet Service Provider gave you a PPPoA
Point Protocol over ATM. In this case, you would use this
key code and Microsoft Dial-up Networking to connect to
the Internet.
52EU-2374-A222-22AS-B2QK
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Apr 21, 2011 | Computers & Internet
I have a sandleford safe es23 if i punch the code in the safe beeps until i open it with the keys and disconnect the batteries. What am I doing wrong
we are looking after a friends place with one of these safe's in them, my daughter has pushed buttons and it wont stop beeping, we dont know the code or anything?? how do i stop it beeping??
Feb 23, 2011 | Sentry Fireproof Safe
Hi i locked my combination papers to my brinks home safe and i dont know my combinatinon my safe number is 5054
Try calling 1-800-223-8566 with your model #, serial #, and key code. Monday-Friday 11AM-7PM Eastern Time.
Oct 14, 2009 | Sentry Fireproof Safe
Jan 11, 2009 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
189 people viewed this question
Top Sentry Home Security Experts
Hannah Johnson
Level 1 Expert
ray012965
Michael Galve
Michael Galve
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
