Question about Dryers
The dryer is making a thumping noise when the drum turns. you said it may be the rollers. how do I get to them and are they easy to replace?
  • Dryers Master
  • 5,568 Answers
Since you didn't include make and model in this post (it's better if you comment to your original thread) no one can give you a detailed answer.
You might try entering your make and model at the link below to see if Sears has your machine cataloged; they have many thousands of appliances in their library and if yours is present, there will be a line drawing of your machine which will allow you to determine if this is a DIY project or not.
If it is present, you can order parts directly from their pages.
Sears PartsDirect
Posted on Sep 16, 2010
What is making mywhirlpool/admiral electric dryer sound loud and thumping noise
You dryer belt may be shot and a piece of rubber is missing making it jump while working. Needs replacing before it completely quits. It will eventually just break apart.
Apr 13, 2015 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
GE dryer DCVH515EFOWW thumping noise after heats up. Recently replaced front drum bearing and slides which fixed squeaking. Now having rhythmic thumping (no squeal or squeak).
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
Aug 18, 2014 | Dryers
The dryer works but makes a loud thumping noise model#GLEQ642AS2
All dryers have some type of roller system that supports the drum as it turns. It sounds like one of the rollers or roller bearings has worn and is making that thumping noise. If you have some basic skills and good general mechanical sense you could fix it yourself. Make sure the dryer is unplugged before you attempt anything.
Feb 25, 2011 | Frigidaire Dryers
Thumping/rubbing sound in drum
The belt tensioner roller has a flat spot caused by a worn bearing that catches and stops whilet the drum is turning. This causes the flat spot and the noise its making. You can purchase a new roller by itself and do change the belt the same time too
Apr 08, 2010 | Frigidaire Electric Dryer
Dryer making a thumping noise, heating okay, drum is going round. could drum be out of round and thumping on the rollers
the roller is out of round instead for the internal bearing has dried up and locked tight making the belt to burn the nylon roller flat in the spot the belt rides on. It will be neccessary to replace the belt and the roller as well
Feb 20, 2010 | LG DLE2532W Electric Dryer
Dryer makes a clunking noise while drying. Is it possible that the drum is "Out of balance"?
Most likely if it is a thump thump noise a drum roller has a flat spot and is causing the noise.
The dryer will operate ok but it will be loud.
A service call may be needed to replace all 4 drum rollers.
Jan 06, 2010 | LG DLE2532W Electric Dryer
Dryer makes a thumping noise when drum is turning its an electric fridgidare de5520rw2
Sounds like you have flat spots on your drum rollers.
If your machine is a front loader, remove the front of the machine, this will expose the belt and drum, remove the drum and belt, and this will expose the drum rollers.
Check the rollers to see if they have flat spots on them, if they do replace them with new ones. This should solve your thumping noise.
If the rollers do not have flat spots on them then you can try to lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil.
I hope this helps
Oct 02, 2009 | Frigidaire Dryers
The dryer (Bosch Nexxt 500) makes a loud grinding noise when rotating. Any idea what this may be?
The noise could be your drum rollers need lubricant or replacement.
When the drum rollers get flat spots on them they will make a bumping/thumping type of noise.
The grinding noise sounds to me like the drum rollers are in need of lubrication.
Sep 26, 2009 | Bosch Nexxt 500 Dryer
Dryer make very loud thumping noise when running
HI THANKS FOR THE QUESTION. ON, DRYERS THEY USE DRUM ROLLER'S SO THAT THE DRUM TURNS EASY. THE NOISE YOU ARE HEARING IS THE WORN DRUM ROLLERS REPLACE THEM. THANKS THE APPLIANCE DOC.
Oct 04, 2008 | Amana Dryers
Dryers Logo
55 people viewed this question
Top Dryers Experts
