Will convergence ics stk 392-110 interchange with stk 392-150?
  • 10,594 Answers
You can use STK392-150 as replacement of STK392-110
Let me know model and brand of your tv to help you out in details as I do have lots of schematics.
Thanks.
Posted on Sep 16, 2010
  • 9 more comments
  • Shahid Electronics
    Shahid Electronics Sep 16, 2010
    I have its schematics/ service manual.
    Let me know your email if you need copy that will help you to check voltage supplies, resistance values etc in convergence section to fix the problem.
  • Patrick McAlexander Sep 16, 2010
    My email is patmac92057@yahoo.com I do need that schematic. Thank you.
    OK, sent schematics copy, please check your email box
    Hope this will help you a lot to fix convergence problem.
    Thanks.
    Thank you. I shouldn't have to change any resistor values right?
    It depends, if resistor color looks faded or it looks like heated up, check its value and replace it.
    It happens usually with big size resistors (1 or2W) nearby STKL ICs
    Thanks.
    I replace a 1.8 1 watt with a 1.5 1 watt. Is that ok?
    Did you got schematics copy in email?
    These resistors values are critical and should be exact same because it provides feedback/ error signal for further process in circuit.
    IIt got better but then rk58 and rk50 burnt. Should I just put stk 392-110 back in? Could one of the picture tubes be causing this?
    bad picture tube is not reason of problem in convergence section and I have seen heat is major problem in this section that these STKs produce due to high current in convergence deflection.
    Its up to you to put back STK392-110 back but STK392-150 is more better chip with better current rating. Just make sure that big resistors (1W) are all OK in that circuit board.
    You have schematics and its easy to get correct value of these resistors.
Red and blue convergence
Adjustment or IC replacement---the adjustment with the original remote via the customer menu should be tried first----set if has convergence should use either two stk-392-040 or -020 chips that are interchangeable with the -040 being the higher current part and more expensive.
Oct 26, 2012 | Samsung HCL5515W 55" Rear Projection...
Can I have the part # for convergence ICs for Phillips TV Model 51pp9200D/37?
IC convergence number: STK392-120 or STK 392-150 Will work correctly. Any question, please let me know.
Aug 04, 2011 | Philips 51PP9200D Television
STK IC 392-110 Chips
am having stk 4392 amp board 2 channel, i want to change this two channel in to one channel. what modofication should i do
Dec 02, 2008 | Toshiba 42H81 42" Rear Projection...
Convergence IC's
Stk 394-160 are the better IC and they are available in the DP15H Upgrade kit at the following link.
http://servicemanuals.vstore.ca/
Nov 23, 2008 | Hitachi 43FDX20B 43" Rear Projection...
Red Convergence
Good day, enamual;
The Part number for the convergence IC's: STK 392-150, the originals are STK 392-110/120's, Hit recommends the 150's.
The part number for resitors; KIT 10. (includes IC's).
Contact: B&D ENTERPRISES; 1-800-458-6053; www.bdent.com.
I hope this helps.
Good Luck, big IRISH.
Jul 18, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Jvc convergence
1024x768 Normal 0 Convergence
When A REAR PROJECTION TV has coloured outlines or a 3D image the Convergence Circuits most likely need attention.
Replacing the output amplifiers (located within the Convergence IC's) allows the pictures to line up correctly, and no more color outlines.
This is the most common fault in all makes of rear projection TVs.
Some models of TV require major disassembly and considerable shop/manufacturer's support to repair because of their design that causes other power supply or vertical deflection problems. The poorly designed products require a "bench" repair that can typically cost from $350 t0 $700.
Some TVs are designed for on-site repair and have more reliable circuit design that does not usually cause damage to other parts of the TV when convergence chips fail. The ones that usually allow reliable on-site repair are JVC, Samsung and Hitachi.
It is normal to have some resistors in the circuit burn up or increase in value from the heat (from 2.2 ohms to 5 or 10 ohms). These resistors must be replaced with the right value or the chip may fail again.
This is not a simple repair like changing batteries or a fuse. Reading through the other posts shows many that try and end up with bigger problems.
Your JVC uses STK 392-110 IC's. Misinformed people replace the IC's with other "new and improved" IC's, like STK 392-150. These are devices with different characteristics and require different value resistors in the circuit. Replacing with the STK 392-150 will cause overheating of the resistors and a damaged IC.
If you are in Calgary, I can help. If not, get someone that has experience working on your JVC. My website is below with some costs and explanation.
calgaryconvergencerepair.weebly.com/convergence-explanation.html
Good Luck,
Easyab
Jun 18, 2008 | JVC AV-56WP74 56" Rear Projection...
Tv troubleshoot for me
chances are that IC804 has failed. You have two ICs that allow you to converge the three colors. IC804 is used for Red Horizontal and Vertical Convergence and also for Green Vertical Convergence. IC805 is used for Blue Horizontal and Vertical Convergence and also for Green Horizontal Convergence. These ICs run very hot and have a very high failure rate which sometimes will cause damage to resistors in their associated circuits. They are both STK-110 and it's best to replace them both at the same time. It's also a good idea to upgrade them to either STK-150 or STK-180. These will run a lot cooler than the STK-110.
Before replacement do inspect for any open or overheated resistors as I stated earlier. Being you only have problems with Red Convergence the plus and minus power supplies should be okay since they are common to both ICs.
Try www.tritronicsinc.com. They have the Hitachi CZ00433 (STK392-150) in stock for $20.11 ($32.43 retail). These are Hitachi OEMs. I've had very good results replacing STK392-110s with these chips. Do check for open or overheated resistors before replacing these chips
Dec 29, 2007 | JVC AV-48WP74 48" Rear Projection...
Hitachi 65xwx20b convergence
Your message says you "replaced stk392-150", did you replace both of the stk`s or just one of them??? One is for RGB vertical the other is for RGB horizontal, you should always replace both stk`s as a set, Hitachi recommends you use a "replacement kit"
part number X480306", this kit includes both stk`s with a new & supposedly improved set of stk`s as well as all resistors that are required for proper set-up, they strongly recommend you change all of the parts in their kit. The only other thing besides IC`s & resistors that could cause your problem is:
1) bad dcu output (you need a scope to check this)
2) you`ve lost either the +15 volt line or the -15 volt line to the IC`s, "Fxxx" chemical fuse open in power supply.
Dec 01, 2007 | Televison & Video
Televison & Video Logo
185 people viewed this question
Top Televison & Video Experts
Electro Med Services...
