Question about Horizon Exercise & Fitness
The beltof my treadmill turns for about 15secs and then stops and an E1 error message appears on the display. what might it be.
    Problem Solver:
  • 13 Answers
This happens when the console isnt receiving a speed pulse from the sensor on the motor
Posted on Sep 16, 2010
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
May 22, 2016 | Exercise & Fitness
Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
True Treadmill Errors and Service Messages
  • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
  • The error messages that may be displayed by the built-in diagnostics are as follows:
    • E1:INCLINE
      • This means that the incline is moving when it has not been commanded to.
    • E1:MINIMUM
      • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
    • E1:RANGE
      • This means the difference between the treadmills zero position and maximum incline is not sufficient.
    • E1:STALL
      • This means that the incline is not moving when it has been commanded to.
    • E2:OVERSPEED
      • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
    • E2:CAL
      • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
    • E3:EEPROM
      • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
    • E5:SENSOR
      • This error occurs when there is no speed or RPM feedback detected from speed sensor.
  • The service messages that may be displayed by the built-in maintenance reminders are as follows:
    • S1:LUBE
      • This service message displays when it is time for inspection of the deck lubrication system.
    • S2:CLEAN
      • This service message displays every 500 miles and is your prompt to clean the treadmill.
    • S3:MOTOR
      • This service message displays every 2500 hours and is your prompt to check the motor brushes.
  • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
Oct 12, 2015 | Exercise & Fitness
What does treadmill error code E1 mean?
Precor Error 01, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis.
Here's a link to more error codes:
Error Code List for Precor Fitness Equipment
May 26, 2014 | Precor Exercise & Fitness
Lifespan Pro3 - treadmill E1 error message
Hello
yes, your correct this could be the lower board with the issue.
The lower board could have blown a fuse, which you can check and replace quite easily. If the fuse is good look for other burnt spots on the board. The lower board may need repairing/replacing.
If the machine stopped while in use (after about 10min) then you will have a few other problems to check. Try adding silicone spray under the belt and if this has already been done then the running belt may need replacing.
E1 is never a good thing...
gymWorld.net.au
Jan 10, 2014 | LifeSpan Fitness Lifespan PRO3 -Treadmill-...
I get an error message E1 on my Athlon model Simplicity treadmill. Belt stops. Any ideas on what this means?
Step 1:
ERR 1 - Motor Movement
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.
Clean the s.speed , test for open or faulty-see the diagram for adjust. tight the connector very well.
God bless you
Step 2:
Feb 08, 2013 | Exercise & Fitness
CardioZone SuperSportHR Club Fold-Away II ERROR 1
see the video and proceed according. God bless you
2) LUBE the rollers bearings too
3) test the drive belt motor, and replace it
4) Test the input voltage motor, if there are the motor need repair, see my personal TIPS for help
5) Test the output voltage board, for input voltage motor, if there are NOT THE board is faulty. see the block d.
God bless you
Nov 29, 2012 | Cardiozone Supersport Hr Club Commercial...
Motor not going on York Optimum 60100 - after a while E 1 appears
Dear Sir:
This is probably a 1) faulty speed sensor or 2)the speed sensor is not plugged in properly. Its also possibly a 3) faulty motor control board or lower board 4) Main motor faulty. . The error codes will differ between makes and models but could be e1.You must test
see my personal TIPS for diagnose and troubleshooting.
See if you can run the software calibration for diagnose and trouble.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Mar 05, 2012 | York Exercise & Fitness
Tuturi J661F stopped working - Error E1
Your problem might be that a magnet has fallen off. Here's an illustrated tutorial that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Apr 20, 2009 | Exercise & Fitness
Tredmill error code e1
Trimline treadmill starts up then code E2 comes up, and the display shuts down.
Any ideas???
Apr 02, 2009 | Nautilus Tr300 Treadmill
E1 Error Message on Reebok Cross Trainer
i too have this problem am under the impression there is a problem with the resistance but am waiting on areply from reebok technical support
Mar 27, 2009 | Reebok Exercise & Fitness
Exercise & Fitness Logo
409 people viewed this question
Top Horizon Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Jerry Kramer
Jerry Kramer
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
