Question about Raymarine Ray45VHF (53 Channels) 2-Way Radio
Ray45vhf Where can I purchase a new base for my radio (mounting bracket)? Thanks.
    Sergeant:
  • 250 Answers
Hello Billyboy5625,
It looks like the mounting bracket for this radio is available on the manufacturer's website at http://www.raymarine.com/.
Click Customer Support > Find Parts and then search for "Ray 45." The mounting bracket and installation kit both show as available.
Best regards,
Ken
Go Ahead. Use Us.
Posted on May 20, 2008
My radio receives the wx stations fine, it transmits fine but it will not receive when switched to cb, I have tryed ex speaker, still nothing. mete wont move in receive mode, but when keyed the tx is over...
Here is the list just scratching the surface.
  • Bad antenna
  • Bad coax cable ......grounding externally or internally with shield.
  • Bad/poor ground for antenna..........door to body, painted parts when mounted elsewhere.
  • Antenna installed incorrectly. Nylon grommet must insulate antenna from contact with mounting bracket. Coaxial connector must have contact with bracket for grounding.
Jul 02, 2011 | Uniden Bearcat Pro PC68LTW 40-Channels...
Hi I have been given a plasma tv Relisys
http://www.mountright.com/desk-mount-desk-bracket-for-1422-lcd-tv-swivel-1406-21r-p-27.html
I found this site and it has a desk mount bracket for your tv.
Relisys has gone into administration so getting the origional stand could be difficult.
I hope this helps
May 08, 2010 | Televison & Video
Before I buy
the s9 is a mobile unit.it comes with a power cord and mounting bracket.
May 28, 2009 | Magnum S9 Base CB Radio
Swr too high
Check your antenna. Make sure it is getting a proper ground. Check where whip goes into coil or base. Make sure all allen screws are tight and whip is not either all the way down to the base or up to the top. If antenna is mounted; make sure that it has a good ground. You might have to remove some paint around the base to get a good connection. DO NOT TRANSMIT WITH A HIGH SWR. YOU CAN BURN OUT THE EXPENSIVE POWER OUTPUT TRANSISTOR. Hope it helps.
Tom
May 26, 2009 | Cobra 29 LTD CB Radio
I need a celing mounting bracket for 52in 5 blade encon ceiling fan. where can i get one the model # is 94b03-0395
I just uninstalled my 29 year old Encon flush mount fan light. The number on the base is E101004. It was a lighted base. The mount bracket is built into the base. It is the 4 prong and hook style the allows the motor to hang suspended while wiring and then swings up. There is a glass ring that is sandwiched between the base plate and decorative bottom.
It's the only usable part besides the 4 glass light covers. You can save this from the land fill if you haven't purchased a replacement fan.
May 08, 2009 | Encon Industries 78716 Contempra Ceiling...
Pt cruiser aerial
At the base of the antenna, take a small crescent wrench or pliers and unscrew the antenna from the mounting bracket. Any Chrysler dealer should have a replacement antenna.
Oct 06, 2008 | 2002 Chrysler PT Cruiser
I have a Raymarine VHF marine radio but cannot get channel 37 - why not?
To my knowledge, Ch 37 (M1) is used by the UK Marinas and Yacht Clubs, however, the Raymarine Ray45VHF uses the US VHF Marine Radio Channels allocations/standard where there is no Ch 37 (actually no Chs 29-59).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa
Jun 17, 2008 | Raymarine Ray45VHF (53 Channels) 2-Way...
No transmitting with Raymarine Ray45VHF
Re your queries:
1. how to memorize channels?
The channels are pre-programmed that a channel number corresponds to a frequency setting. Ex. Ch16 is 156.800 . If for some reasons some channels are missing, perhaps your best course of action is to reset the unit to factory default, that way everything would be back to  normal. Master reset is performed by pressing the 16PLUS button while powering the radio. The LCD will display "CL" indicating that the memory has been cleared.
If you  want to memorize a certain channel/frequency, you can only store it as a replacement for 16PLUS assignment. Ex. Instead of Ch16 as your priority/emergency channel you want say Ch14 (156.700), you can do this by pressing the up/down key till your desired channel; press & hold the 16PLUS key for 3 seconds or until you hear the confirmation beep that your desired channel has been memorized in the memory as the new 16PLUS.
2. Why I cannot transmit?
There could be 2 possible reasons:
2.1 You are transmitting on a channel that has been assigned as receive only. Examples are the weather channels, Channels 1,2,3,  also 70,75,76, and possibly others.
2.2 Your TX module/circuitry has a problem. More often it is the finals that gets burned.
3. When i use the PTT Channel 16 is automatically set ?
The mic has an identical 16PLUS button (similar to the radio's front panel). If you pressed the PTT switch on the side and the radio switches to Ch16 (as if you pressed the 16PLUS button on the front) then you have a wiring problem from the mic to the radio. Possibly a shorted or open connection.  It is also possible that you have a break in the small PCB (in some versions) inside the microphone.
The user's manual can provide a more detailed instruction.  It is available at the RayMarine website and the link is >
http://www.raymarine.com/SubmittedFiles/Handbooks/Legacy_Handbooks/communications/RAY45MANUAL.pdf
Hope this be of some help/idea. Post back how things turns up or should you need further information.
Oct 13, 2007 | Raymarine Ray45VHF (53 Channels) 2-Way...
Raymarine Ray45VHF (53 Channels) 2-Way Radio Logo
91 people viewed this question
Top Raymarine Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Raymarine Radio Communication Expert? Answer questions, earn points and help others
