I have a canon pixma MP496 model,when i try to print out something,LCD shows an error message" paper output tay is closed.please open the tray and then click OK".however,the paper output tray is already open but display this message.what's the proplem and the solutions?
  • 117 Answers
SOURCE: canon pixma ip1980 service error 6000.. it flashes
your canon pixma paper jam open the printer caling
Posted on Oct 07, 2009
SOURCE: Canon PIXMA iP5300 InkJet thinks paper output tray is closed (it isnt) and won't print!
It was rather easy to figure out how to pop the silver plastic outter casing off, but now that I have it off I still can't seem to identify where the switch that signals the paper outter tray is.
Posted on Sep 17, 2008
SOURCE: Paper output tray is open but message says it is closed
I solved this problem by putting a shim between the door & switch lever.
The shim is just a piece of cardboard/plastic/whatever about the thickness of a credit card & about 1/4 inch wide.
At the lower right corner of the paper outlet is an opening about 1/4 inch square. On the right side deep in this opening is a lever (rather hard to see). When the door is opened it lifts the lever up (presumably telling the printer the door is open). I took a small screwdriver, inserted it into the left side of the opening, turned it counterclockwise until it caught the edge of the lever & lifted it up, inserted the shim below the lever, & withdrew the screwdriver. This solved the problem (it has only recurred once since the shim was put in).
If the shim falls out just reinsert it. Of course, if you ever want to close the door you need to remove the shim first.
Posted on Sep 28, 2008
Joed911
  • 4338 Answers
SOURCE: Canon Pixma MP610 Printer LCD is
With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2. When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3. When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4. When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in. (orange and green, starting with orange.)
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5 times Orange Destination setting See Destination setting
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 24, 2008
SOURCE: The ip4500 will not print - says the paper output tray is open!
Just fixed this problem on mine. Need to remove the covers, watch these 2 vids to see how..
http://www.youtube.com/profile?user=martop49#p/u/1/iQdHDR6po80
Then on the right side where the on switch is, near the hinge is a little switch with 2 yellow wires, it's probably broke. Pull the 2 wires out and solder or twist them together, then put everything back together. It will now assume the door is always open. Jobs a good'n :)
Posted on Jan 07, 2010
I receive the following message on the PC display: "Document printing cannot be executed because the paper output tray is closed. Open the paper output tray. Printing will restart". I want to mention
The blinking is just an attention light so there's nothing to worry about that. Try adjusting your paper tray to the paper size you are about to use. Or try checking the duplexer panif its positioned properly. Hope this helps.
Dec 20, 2012 | Canon PIXMA iP3000 InkJet Photo Printer
Error 1250
look for a small sensor on you right hand side. it tell the m/c if it is open or close. it migit be stuck.
Nov 04, 2011 | Canon Pixma iP4500 InkJet Printer
Printer notes "Error 6000". It is being used
Take a close look at the printer and the paper tray. The error usually means that the paper output tray is closed (or something is blocking it from opening). Remove the object blocking the paper tray and pull it fully open (including the extension). Then turn off the printer and turn it back on. The error can also occur when a book is being scanned that blocks the paper tray.
Some documentation on the Canon error messages for the MX860 is here: https://www.canon.ie/Support/Consumer_Products/products/Fax__Multifunctionals/InkJet/PIXMA_MX_series/PIXMA_MX860.aspx?faqtcmuri=tcm:24-644260&page=1&type=faq .
I hope this helps.
Sep 11, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Error e03, but there is no jammed paper
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
I have Canon pixma MX310 and I just trying to set it up.I'm trying to print and there is message open paper out tray.What is that mean and how I can fix it
The printer will not print as long as the paper output tray is closed.
  1. Open the Paper Output Tray (2).
    Put your finger in the rounded indent beside the Paper Output Tray and open it gently.
  2. Open the Output Tray Extension (3).
    Open up and set the Output Tray Extension completely by pressing down the hollow on its front side.
  3. Adjust the position of the Paper Thickness Lever (4).
    Set it to the right when printing on envelopes or T-shirt transfers, and left when printing on any other type of paper.
Oct 29, 2010 | Canon PIXMA MX310 All-In-One Printer
Error 1250 on PIXMA ip4300 printer. Despite open tray messae will not o away or allow printing to start.
the error message means there is something wrong with the printer and if the problem is not attended to, the error message will not go away.
In this case, the error message showing on your canon ip4300 is related to a door problem. It has something to do with the front door of your printer. I think the front door of your printer is closed of which is supposed to be opened.
So, the solution is to Open the paper output tray of your printer and the problem should be solved.
Good luck.
May 24, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Error code while trying to print
Slap the printer with your right hand from the right side of the printer.This process always solves the problem. I did, it worked
Apr 01, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
PIXMA ip8500 not printing
i have a pixma ip4300 i keep getting the error number 1250 "paper output try is closed" but infact its is open i have tried opening and closing and restarting and everything else i can think of. any ideas of what to do?
Jun 23, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
226 people viewed this question
jasbo
jasbo
