Tengo problemas con mi lavadora elite he3 lo que pasa que esta lavando y de repente se detiene y cuando voy a ponerla otra vez a lavar se regresa el tiempo de lavado aveces solo le faltan 115 minutos y se regresa a 40 esto me esta ocasionando inconveniente ademas de un alto uso de luz. por favor aconsegenme que puede ser
  • nora2678 Sep 16, 2010
    ME EQUIVOQUE EN MI PREGUNTA PUSE QUE SON 115 Y EN REALIDAD SON 15 MINUTOS
    i have a problem with my washer kenmore elite he3 when i start to wash it only works for 15 minuets then it stops and starts to flash the numbers and when i press start it washes all over for example 15 minutes going back to 40 minuets it takes 4 hours to finish washing.
  • 2,272 Answers
Please explain your problem in English.So it can be helped in much better way and your problem could be understood well and all experts can help you solve the problem.Keep updated.Thanks.
Posted on Sep 16, 2010
  • 1 more comment
  • raj somaiya
    raj somaiya Sep 16, 2010
    Ok so what numbers does it flashes/.Give the exact numbers.and if any other light flashing on control panel then mention that also.
    Please keep updated.Thanks.
  • nora2678 Sep 17, 2010
    it flashes the remaining minutes, for example if it has 2 remaining minutes the washer stops and goes back to 20 minutes and it keeps on going like that for a couple of hours.
  • raj somaiya
    raj somaiya Sep 17, 2010
    Turn the machine On.Press the pause/cancel button two times.Then check running the cycle.If same thing goes On then,Check the drain hose and make sure its not plugged or kinked.If the drain pump is jammed or the drain filter is plugged:Remove or disconnect power to washer.Remove the lower access panel by opening the door and removing the two screws at the top of the panel.If your washer has water in it have a shallow pan under the drain pump before removing the pump filter cover. The drain pump cover has a handle - turn the handle counter clockwise to remove the filter cover on the pump . Be aware that water will come out even if the washer is empty of water, so have a large towel handy.
    Clear any clog or debris from the drain pump filter. Reassemble in reverse order. The drain pump cover has a seal that must be reinstalled properly. Check for leaks after reassembly.Then again check running a cycle.If still the same thing happens then the Diagnostic test has to be performed to locate the faulty part.Check this link and perform the test mentioned in it:---http://media.fotki.com/1_p,swqsdrsrgtstr...
    Thanks for keeping updated with your query.
Por que el audio de mi computadora se escucha un poco mas rapido de lo normal, yla voz se ecucha como la de las ardillitas??
Si eso le esta ocurriendo cuando usa determinado programa verifique la configuracion del mismo. Otra sircuntancia seria que tuvieras algun tipo de virus o troyano que te este afectando el sonido. El problema que esta teniendo no es habitual y es la primera vez que leo algo asi. Te recomiendo que con tu maquina desconectada de internet le hagas un escaneo profundo con un buen antiviru y tambien verifique las aplicaciones (si fuera el caso) que estes usando cuando te sucede la situacion a la que haces mencion.
Suerte y gracias por usar FixYa.com
Jan 11, 2011 | Computers & Internet
Tengo problemas con los frenos, se me enciende la luz indicativa del ABS, y el problema es que cuando freno, al momento en que casi se detiene el vehiculo jala hacia la derecha, como si solo frenara ese la...
evidentemente la luz se enciende por un fallo, revise que el caliper o compensador del lado derecho no este muy ajustado y tambien purgue el sistema por posibilidad de aire en el sistema
Jun 08, 2017 | 1993 Toyota Previa
Tengo un problema con mi lavadora whirlpool duet cuando la enciendo para lavar me presenta un fallo en la pantalla. y sale fallo 22.que es el swich de la tapa.pero se lo cambie por uno nuebo y sigue...
ke tal tengo una lavadora whilpool duet pero al encenderla y poner el ciclo de lavado normal me prtecenta una falla dice falla 11 y no se que es esta falla me podria orientar?
elrayo_0609@hotmail.com gracias
Feb 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Tengo una liberti sport 2002 y de repente se le
PUEDE SER UNA CABLE DE TIERRA QUE ESTE HACIENDO FALSO CONTACTO CASI ES LA MAYORIA DE LOS CASOS QUE PASA ESO. CHECA TODOS LOS CABLES DE TIERRA AL CHASIS QUE ESTEN BIEN CONECTADOS POR QUE HABECES CON UN BRINQUITO ES CUANDO LA TIERRA HACE FALSO CONTACTO Y SE APAGAN LAS LUCES
Aug 10, 2009 | 2006 Chrysler Executive
Problemas de transmision automatica
hola que tal, tengo un saab 9000 1988 y tengo problemas con la transmicion aveses me hace los cambios y abeses no, si abansa para atras y para adelante pero me abienta los cambios cada que quiere,,, alguin tiene idea de que pueda ser?? nesesito ayuda ya estoy desesperado...
Aug 02, 2009 | 2001 Hyundai Accent
Aire acondicionado
tengo problemas con mi aire acondicionado ..al cambiar el filtro...solo tira aire caliente no enfria en lo absoluto
Jul 06, 2008 | 1994 Toyota Land Cruiser
Se reinicia a cada rato
tengo un problema con el ADF de una Xerox Pro 215 cuando quiero copiar algo se van las hojas en fila no juantas sin separarlas una por una que podria ser el prolema alguien podria alludarme
Dec 03, 2007 | Xerox WorkCentre XD100 All-In-One Laser...
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
