Question about Samsung Refrigerators
Samsung fridge/freezer Model RL38 SBSW which is three months old has started to make an intermittent noise which is getting more frequent. The engineer attended and he said this is normal and is the vents opening and closing to take in air. If this is the case, why should this noise suddenly have started after the fridge/freezer being very quiet? It is a whirring sound which gets louder and softer and goes on and off at random.
  • 42 Answers
SOURCE: Samsung RSE8KPUS noise
I have worked on refrigerators for 30 years but never worked on a Samsung. This is a WILD and I do mean WILD guess at what the noise may be. Don't use this information to attempt a repair but just to track where noise may be coming from.
There is a motorized damper door that opens and closes between the freezer section and the refrigerator section. My guess is that that damper assembly is what is making this noise. I can not tell you why it may be making this noise except that if is making the noise it probably is going bad. Remember this is just a guess and you will need to locate the damper assembly in order to try to pinpoint the origin of the sound. Your recording was wonderful and I wish more people in my everyday job would use their heads like you. I hope this sheds some light on the problem. Remember I am just guessing, don't spend money till you are able to verify cause.
Seems there would be a 1 year warranty on the frig.
Posted on Nov 22, 2007
  • 3614 Answers
Fridge problem could be the fan is bad or that it is hitting ice. When the noise is kind of a buzzing like it is hitting ice...defrost your unit by unplugging and waiting a day or so for full melt out...then check your door gaskets for cleanliness and good seal.
Posted on Mar 08, 2008
  • 1314 Answers
SOURCE: vibrating noise from freezer/fridge?
take the cover off the fan in the freezer section and see if the fan blade is loose or hitting ice the blade just pushes on make sure the mountings are tight its probably the blade but you might need to replace the motor if i reamber correctly on the cover there is a screw at the bottom you remove then slide the cover up and its on hooks plastic hooks built on the cover ok
Posted on Mar 28, 2008
  • 18 Answers
SOURCE: Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Posted on Nov 15, 2008
  • 242 Answers
SOURCE: panel between fridge and freezer very hot and no sound at all
Dont know about the noise prob. but I can help with the over heating cabinet. Your condensing coil is dirty and needs cleaned. it is located under your refrigerator or behind the back panel. You should use a brush and vac. it out. Air must travel through the tubing freely in order to cool properly. It should be easy to find following the tubes coming out of your compressor.
Posted on Dec 30, 2008
How do you remove the, RL40 SBSW model Samsung fridge cover to replace the bulb?Thank youAdele
There are 2 plastic extrusions that clip in place. Pull sharply forward, or lever the sides gently up and down with a flat screwdriver above the bits that clip in. The bulb unscrews.
Apr 21, 2014 | KitchenAid KSF26C4XYY 26.0 cu. ft. Side by...
Condenser fan noise
you should have warranty from the tech at least one month ,but it sounds like motor fan is giving up umplug your fridge take off back bottm part to expose the fan and condenser clean all the lint in the condenser vaccum is better ,turn fan with your finger it should be very loose ant turn freely if it stucks its the motor ,umplug the motor pull the fan with the plastic base out of its place,take off the screw on the fan,pull and twist it by hand,take off two or three screws that is holding the motor to de base, buy a newone ,a the apliances store or online for about 45.00 put back everything in reverse way.plug your fridge, enjoy!!! good luck
Apr 07, 2014 | Samsung RFG297AARS (285 cu ft) Bottom...
Brand new Sharp Fridge Freezer Clicking noise
Make sure that the unit have adequate ventilation at the back , move the unit forward a few inches ( in your direction , standing in front of it) Make sure the unit don't touch anything surrounding it ..
Dec 03, 2013 | Refrigerators
Loud humming noise as fridge is running
I've had the same problem.
The problem is: There is Ice accumulating around the Vent (where the cold air comes in from), and is therefor over working and making noise (that is the reason why the electrician thought it was working too hard, so he changed the capacitor but couldn't pinpoint the problem).
This occurs because the freezer is left open or is opened every other second. Check to see if you can see the ice and remove it, if not, ask your local electrician - they usually know these stuff.
Oct 04, 2012 | Refrigerators
I have a samsung french door refrigerator that is only 20 months old and it just started making a very loud humming noise that is coming from the back/top of the fridge. It stops when you open the fridge...
Hi David,
There's a big chance that the evaporators fan touching ice and that's why you hear that noise, if you have an ice build up you gonna have to defrost the fridge and test components to see which one has failed.
Jul 07, 2017 | Samsung RFG237AAWP Bottom Freezer French...
I have a Samsung side by side model # SRS 632NSS. it is about 18 months old. The freezer side does not function but the fridge side is normal .We have tried turning it off and resetting it however it is...
Defrost cycle is very often. Check freezer timer/thermostat might be cuts off frequently. Check thermostat setting..Check fridge is working continuously until frosting over freezer by keeping thermostat at 9' clock position. If not replace thermostat.
Jan 30, 2011 | Samsung RS2630SH Side by Side Refrigerator
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
My Zanussi fridge/freezer is making a funny little noise
What you may be noticing is the system going through a defrost cycle. Check the time of the day that you notice this event. If it happens at the same times it could be a normal situation if at all other times normal temperatures are being maintained. A popping sound can be caused by thermal expansion during the defrost.
Sep 13, 2008 | Freezers
Refrigerators Logo
160 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
