Question about Averatec All-In-One D1130 Notebook
I'm looking to buy a cpu fan, but can't find one. Really don't know which kind to buy
  • 31 Answers
I am in the same boat as you are. Ebay does not sell them, the manufacturer of the fan does not sell them. So I have gone to the source of the PC and found the company that put these baby's together fremontec.com and they can replace the fan but you will have to ship them your unit and pay for them to fix the problem. In my case I have 15 of these dam pc's and guess what I am not going to spend that much to have it repaired. I will post back if I can find a solution.
Good luck
VCS
Posted on Sep 20, 2010
What kind of cpu cooling fan can I use in a Acer America ASE380-UD420A desktop computer?
Cooling fan to CPU are come along with the CPU. You can use any other fan, having speed regulator pin, ie, the connector wire to it will have three conductors. Keep a close look at the size and seating screws to its body to the heat-sink of the CPU.
Jul 22, 2014 | Averatec Sotec 3200 Series Fan with...
Where can i buy motherboard for msi ae2020m
Because your computer is an All-in-one you may have problems finding one on the secondhand or retail market. The best thing I can suggest is to remove the old one( or at least get a really good look at it and) check the size in mm. Then buy a compatible board and CPU. For the heat from a failed fan to have fried the board it would need to have been forced to stay on. There is a thermal cutout and a fan cutout built in to the board. Try just replacing the fan first and see if that helps.It could be the power supply unit that has failed and that is why it doesn't start up now.
Apr 25, 2013 | MSI Computers & Internet
I don't know what kind of chairs to put in my living room. What should I do?
EBay has a really great Buying Guide regarding living roomchairs. It give you certain things youshould know and some tips to keep in mind when looking to purchase chairs foryour living room. Check is out here: http://reviews.ebay.com/Living-Room-Chairs-Buying-Guide?ugid=10000000013133587
May 29, 2012 | Furniture
My computer keeps turning off i not sure what happening with it my hard drvie is fine and power supply but you see the fan that keeps it cool well i don't know but the cpu is a hp with window 7 and...
do you mean 1gb of ram.no this is not a ram issue ,sounds more like overheating or cpu fan is failing.how old is pc and have you clean the fans since owning it.Its a common problem .where do you keep your pc tower ,if on the floor then you may find your fans for your cpu,power,graphic are coated in dust,and you may find your fans are overheat due to the weight add and no Im not joking .try clean your fans and cpu cooler fins.don't use a vacuum cleaner like some people do as you can damage your chip-sets on your motherboard .buy a can of compressed air from pc store and make shore the fans dont spin when clean as it can short your cpu,graphics card.cpu fan clean gentle with cotton bud.if this does not work try replace your cpu fan. hope this helps let me know how you get on. ..............DT
Sep 07, 2011 | Microsoft Windows 7 Ultimate for PC
CPU fan running at constant full speed
Seems like you cpu is running hot and therefore triggering the fan to spin fast in order to keep the temp low. You can monitor the cpu temp buy downloading this programs and see its really the cpu thats overheating. http://www.techpowerup.com/realtemp/
Sep 07, 2011 | Dell OptiPlex 330 Desktop Desktop Computer...
WANT TO KNOW HOW TO INSTALL A PROCESSOR
First you will need to know what kind of socket you have on your motherboard, so you can purchase the correct CPU for your replacement. Intel and AMD have lots of different socket sizes so don't overlook this point. If you have the CPU that you are going to replace, all you need is a screwdriver, thermal paste, and CPU fan.
1) Open the case cover with screwdriver, and open side panel to locate CPU.
2) Using a screwdriver or sometimes just release clamps to take off the CPU fan.
3) Release lever on the side of the socket to release the CPU.
4) Pull out old CPU and install new CPU, (Be very careful not to bend the pins on the CPU.)
5) Put small amount of thermal paste on top CPU.
6) Replace CPU fan and connect power to the fan, replace cover.
Now in a perfect world this should be it, but if you upgraded you CPU you should go into you BIOS and check the settings for your CPU. To make sure the voltage is correct.
Look here if you need more help.
Jan 27, 2011 | Computers & Internet
Dimension 3000: P4@2.8GHz. NOISY - alway has been. Want to remove green shroud permanently, add quiet 80mm thermistor-controlled fan to CPU stock heatsink (without exciting a BIOS temp alarm), replace...
As for the green shroud, I would not recommend removing it. The computer case is designed to correctly circulate the air through the system and safely out. As for replacing the fans you can replace them with anything you like, just make sure the new fans are the same dimensions they come in szies 40, 60, 80, 92, 120, 140 and a newer 200 mm form factor so you can just measure them if you don't know the correct size. Next look at where the fans plug in, if it is a three pin plug then they fan's are kept at optimal speeds via the motherboard and bios. So they are already controlled by heat sensors / thermostat so to speak. If they are 2 pin then they just run full speed usually. For the back fan just make sure it is the right size and pin out. You can hook a 3 pin fan to a 2 pin fan plug on the board it will just run full speed all the time. For the CPU fan buy a combo fan/ sink and just make sure the sink is the same as the existing one so it will fit on the motherboard. You could probably get rid of the green shroud if you went with a really high end fan / sink for the CPU but that's up to you. For the thermal paste it is easiest to put a small blob in the center of the CPU and then use a plastic card, such as a drivers license to spread it out to cover the entire CPU, thinly and evenly. Add small amounts if you need to to cover the entire surface. Try not to have a bunch oozing out the sides although it won't really hurt if it is.
Nov 02, 2010 | Dell (6F858) Cooling Fan
The fan has given up and now serious heat build up. are fans readily available and can they be easily replaced?
If you are asking about a desktop PC, yes, they are really cheap and easy to replace. If you are asking about a laptop, it's a little bit difficult. You need to go to ebay and find a replacement fan and some laptops need complete tear down in order to replace the fan or cpu, etc. it all depends on the brand and model of the PC. Some are somewhat easy to reach the fan. I suggest you buy a Notebook cooling pad which cost really really cheap. Some are about $10. Of course there's nothing better than the internal fan of the CPU but it could be an option WHILE you take it to a repair center.
Apr 26, 2010 | Sony CPU FAN CPU Fan
OVER HEATING
Two possibilities:
  • the CPU is really overheating; and/or
  • the motherboard is falsely sensing high temp.
Corrective measure for an overheating CPU would be:
  • clean, re-lubricate or replace the fan;
  • clean or refit the heatsink. If it is overclocked, you may need a better heatsink.
If the CPU is not really heating up abd the motherboard is sensing erroneous temp readings, then the problem may be with:
  • BIOS version, try to flash and update the BIOS; and/or
  • check the temp probe underneath the CPU, it may need cleaning or slightly bending away from contact.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 13, 2008 | Intel D865GBF Motherboard
Replace CPU Heatsink and Fan
okay as long as the heatsink fits it will work. socket type is for the processor. also dont forget the thermal paste. look up www.ribbitcomputers.com
Apr 29, 2008 | Acer Veriton 3600G PC Desktop
Averatec All-In-One D1130 Notebook Logo
261 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
