How do I up the density setting on an HP 4050 laserjet?
  • 567 Answers
Hi there
To change the density setting please follow the steps give below
1)From the control panel of your printer 2)Press the Menu/Enter button 3)Press the button to Common Settings 4)Press the Menu/Enter button. 5)Press the button to Print Density . 6)Press the Menu/Enter button 7)Press the button to change the Print Density value. The print density setting values are one to five, with three being the default value. Select 1 if the density needs to be lighter. Select 5 if the density needs to be darker. 8)Press the Menu/Enter button to confirm the change the setting.
This will resolve the issue you are facing. If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue. Please do mention the complete details of your oven like it's make and model number etc.
Regards
Posted on Sep 16, 2010
  • Anuj Joshi
    Anuj Joshi Sep 16, 2010
    Your welcome twingfiel341
    Glad to help you....have a nice day
How to fix sensor error on hp color laserjet 2600
54.06
Error message
54.06
Description
Color density sensor error
Action
  1. Power cycle the printer.
  2. Calibrate the printer. Click here to view the document "HP Color LaserJet 2600n - Calibrating the printer" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314525).
  3. Change the Print Density settings through the HP Toolbox. Click here to view the document " HP Color LaserJet 2600n Printer - Change Device Print Settings in HP Toolbox" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00310627).
  4. If the problem continues, contact HP Customer Support Center for technical assistance athttp://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Apr 02, 2014 | HP Color LaserJet 2600n Printer
Printer speed is erratic. Sometimes fast, sometimes very slow. How do I control?
Check your paper type settings in the printers menu and the driver on the pc.
Some types of paper settings will slow the printer down for improve print quality.
Set thepaper type to 'plain' for best result
May 02, 2010 | HP 4050: HP 4050 laserjet printer , 8MB...
Our company has a LaserJet 4000 and a LaserJet 4050, and both are printing the margins unevenly, in all applications. For instance, in Word the margins are set to 1 inch each side, but when it prints the...
It could be the rollers, try updating the firmware firstly, Sometimes the firmware will cause alignment and print quality issues. If that doesn't fix the problem, contact hp for a list of ASP's. 1800-334-5144
Al
Apr 20, 2010 | HP LaserJet 4050 Printer
HP Laserjet 4050. Can I connect from my TCP/IP to JetDirect?
To use a printer DIRECTLY into your PC or laptop (without plugging both into a network hib, or switch), you need to use a CROSSOVER patch cable.
Feb 19, 2010 | HP LaserJet 4050 Printer
Windows 7 purchased used hp 4050 laser printer and I can't get tray 3 to operate?
Hello, Carl.
Be sure the tray is added in the driver device settings in Advanced tab under Properties.
Print a test page and see.
Hope this helps.
Jan 25, 2010 | HP LaserJet 4050 Printer
I have a hp laserjet 4050 that will print my files but will reverse and print same files again. what is the problem?
Check your driver settings. Make sure the number of copies is set at 1 copie.
Gerrit Jan
Nov 01, 2009 | HP LaserJet 4050 Printer
How do I download a drive for my laserjet 4050? I
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=18322&prodTypeId=18972&prodSeriesId=25475&swLang=8&taskId=135&swEnvOID=228
Aug 23, 2009 | HP LaserJet 4050 Printer
Separation pad for HP LaserJet 4050
Open tray 1
remove the pick up roller
pad is located under the roller
in the front center of the pad is a small notch
inset a small screwdriver or key something small and flat.
give it a twist and the pad should pop out.
install the new pad by aligning with the holes and push down should sort of snap into place.
Reinstall pick up roller
Hope this helps
Mar 25, 2009 | HP LaserJet 4050 Printer
MY PRINTER WILL NOT PRINT OUT
check and see if the computer actually recognises the printer. go into printer settings and see if your printer is listed. if not click on install printer.
Jan 12, 2009 | HP LaserJet 4050 Printer
HP Laserjet 4050 hangs on processing job
Unplug printer cable.
turn off
turn back on and wait for READY
turn off
connect printer cable
turn on
Jan 05, 2009 | HP LaserJet 4050 Printer
150 people viewed this question
jasbo
jasbo
