Question about Toshiba C99704 Mouse
My blue nipple mouse is screwing up Toshiba Satellite 6100 Mouse i in the middle of the keyboard works rarely but sometimes moves cursor to upper right or lower left corner of screen & then it can't be moved
    Novelist:
    Champion:
  • 226 Answers
Sounds like the keyboard has gone bad (the mouse and the keyboard are integrated into one unit). Replace it. Cheapest source of these parts will be eBay.
Posted on Mar 05, 2011
I have a toshiba 6100 and the cursor wont move unless i connect mouse
Make sure you have not pressed the little button right above the mouse pad that toggles between locking the mouse pad or freeing the mouse pad.
Mar 09, 2012 | Computers & Internet
I need to copy text with this built in mouse on my Toshiba laptop...cannot figure it out.
Hi there! To copy text follow these steps, 1) Put the mouse cursor at the beginning of the text you want to highlight. Click the left mouse button and then drag the cursor to the end of the text that you want to copy. The text should now be highlighted blue. 2) Right click on the highlighted blue text 3) Left click on the "copy" option in the menu that just opened.
If you cannot get the right click menu to work, there is a keyboard shortcut for "copy" - CTRL-C After the text is highlighted, press those two keys at the same time to copy.
To paste, right click where you want the text to go, then select "paste" - keyboard shortcut is CRTL-V
Alex
May 30, 2011 | Toshiba Satellite Pro L300 Notebook
I have a Toshiba LapTop Windows 7 My granddaughter pushed keys and now i can't get the cursor to move. I have tried shutting down and it is still frozen in the middle .
Are you using the trackpad to manipulate the cursor, or are you using an external mouse?
If you're using the trackpad, it may be as simple as using the Fn keys and the corresponding F keys at the top of the keyboard to enable the trackpad feature again. If that doesn't work, try plugging in an external mouse via USB port to see if that works.
If you're using an external mouse, then try to see if the cursor moves while using the trackpad.
Hopefully one of these options will give you control back over your cursor again.
May 03, 2011 | Toshiba Satellite Pro L300 Notebook
Toshiba satellite pro's cursor "floats" off as though a mind of its own
Your keyboard is bad - the Toshiba Accupoint mouse portion of it, at least - just replace the entire keyboard. Access is easy: remove the thin plastic cover strip above the keyboard, then two screws that hold the keyboard down, lift it up slightly, and disconnect the keyboard connector. eBay is the best source for these parts, and replacements should cost no more than $20 delivered.
Aug 23, 2010 | Toshiba Satellite Pro 6100 Notebook
Toshiba A100 touchpad mouse not moving
Many toshibas have the facility to turn the mouse/trackpad on or off. I have seen it on the upper keys in blue text, meaning you need to hold the fn (Function) key down at the same time as the mouse enable/disable key.
Jul 25, 2010 | Toshiba Satellite A100-S8111TD Notebook
Dell Lattiude D600 cursor locked in middle of screen - even after we turn on and off - no way to do anything because cursor won't move - not even little blue mouse in the middle of the screen
Try booting up after installing an external USB mouse. This may give you a mouse to install new keyboard drivers.
If the problem is the keyboard/tracking pad, (hardware) installing another keyboard may eliminate the issue.
Jun 14, 2009 | Dell Latitude D600 Notebook
Mouse pad not working...?
Try pressing fn+f9 key, which is used to lock the touchpad and if this does not work, Try booting in safe mode using F8 key and try using touchpad there
Hope it will help.
Tc and
Cheers!!!!
May 10, 2009 | Toshiba Satellite M35X-S311 Notebook
How-to move cursor ?
If there is a black square in the middle below the keybord, that is what is called a glidepoint. You just use your finger to glide the mouse arrow around inside of that box. The bars are for the mouse buttons.
If you are like me, I like to hook up a regular mouse via USB and use the regular mouse instead.
I hope that I have provided the correct information that will assist you in the resolution of this issue. If you have any questions, please post back with a comment to this thread.
If I have helped you with your question and/or solved the problem, please take just a moment to rate this post. Thank you!
May 09, 2009 | Computers & Internet
CURSOR WILL NOT MOVE
If the cursor doesn't move - and the Accupoint mouse is part of the keyboard - then simply replace the keyboard. Remove the plastic strip in front of the keyboard, one screw that hold the bottom of the keyboard down, and the rest is obvious.
Dec 13, 2008 | Toshiba Axiom 60GB HDD Satellite Pro 4300,...
Toshiba C99704 Mouse Logo
74 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
