Question about Acer Aspire One PC Notebook
My aa1 doesn't start but the power button will not go off
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
Posted on Sep 18, 2010
Hi i have an acer aspire one 523h-2588 and in the bios it says "IDE0 HDD Password is : Frozen" how can i get rid of it to use my laptop again cause it wont let me see my windows
Acer Aspire One BIOS Recovery The Acer Aspire One has a built-in BIOS recovery routine, which can boot into a minimal BIOS environment via a special boot block to re-flash the BIOS, even if the system does not pass POST and does otherwise not boot anymore. This procedure is also known as Crisis Disk.
First format an USB flash drive with FAT. It does not need to be bootable.
Download the latest BIOS, and extract all files. Put both FLASHIT.EXE and the BIOS file with FD suffix in the root directory of the flash drive. The files must not be in a folder. Rename the BIOS file to ZG5IA32.FD before proceeding. It only works with this exact filename.
Turn the AA1 off, and verify both battery and AC adapter are plugged in.
Press Fn and Esc simultaneously, keep them pressed and press the power button. Release Fn+Esc after a few seconds. The power button starts blinking at this point. Press it once. The AA1 will now access the files on the flash drive and initiate flashing the BIOS. After a while the power button stops blinking, and the AA1 reboots by itself. Wait patiently.
If it doesn't reboot, but keeps blinking, wait at least a few minutes before turning it off, and try again.
Oct 06, 2011 | Acer Aspire One AO532H-2527 Netbook
Acer Aspire One BIOS hard drive password?
BIOS passwords are set individually for each computer, so even though two of them might be the same model or from the same company, they won't have the same password.
Generally, BIOS's don't have passwords, and they shouldn't have a password by default. If someone has set up the BIOS with a password, there is no way to recover the password other than remembering it.
If you can't remember the BIOS password, you'll have to have the BIOS flashed, which is like re-installing an operating system for the BIOS. I would suggest taking it in to a computer repair shop and asking them what they can do.
May 10, 2011 | Acer Aspire One D250 (99802378332) Netbook
I turn the netbook on and the blue power button is on, but the screen is still remaining black
sounds like the common BIOS flash fix.
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS.
Nov 29, 2010 | Acer Aspire One AOD150-1920 Netbook
My Acer Aspire One boots up but only runs for 5 seconds then click, and it goes blank. It has a charged battery and does this even when plugged in to the charger. I have tried to boot it up using F2 and...
hi there,
use at your own risk.
Follow every step carefully!
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that’s important. Do not remove the USB stick.
If for some reason you made a mistake during the procedure and it doesn’t reboot by itself wait 5 minutes before turning it off, just to be safe that it isn’t still flashing the BIOS.
Jul 11, 2010 | Acer Aspire One PC Notebook
Power button is on yet no monitor display? need help
this is a common problem with aspire one netbooks. You need to flash the BIOS
Mar 17, 2010 | Acer Aspire One PC Notebook
Power is on but i get nothing but a black screen
ASPIRE ONE BIOS FLASH RECOVERY
http://support.acer.com/drivers_download.aspx
Jan 19, 2010 | Acer Aspire One Netbook 8.9" Notebook
My ACER netbook turns on but the screen remains
After switching off the aa1, when trying to turn it on again, it just shows blinking leds and the fan is turning. But the screen remains black.
If your aa1 does like this probably its BIOS has been damaged...
Luckily the Acer Aspire One has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore.
Please note that the process I'm about to describe is only meant for emergencies and may void your warranty, so use at your own risk.
1) Format a USB memory key with the FAT mode.
2) Download the latest version of the BIOS from Acer support website:
3) Extract the files from the zip and put both the FLASHIT.EXE and the BIOS file in the root directory of the memory key.
4) Rename the BIOS file to ZG5IA32.FD and then remove the disk.
5) Turn the AA1 off, insert the battery and connect the AC adapter.
6) Insert the USB Memory Key into one of the USB port of the Aspire One.
7) Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on.
8) Release Fn+Esc after a few seconds, the power button will be blinking.
9) Press the power button once. The AA1 will start the BIOS flash, do not interrupt for any reason. After some minutes the power button will stop blinking, and then the AA1 will reboot. Wait till the AA1 has completed all this operations.
If everything has gone right, the BIOS is flashed and all settings are reset to default.
Nov 16, 2009 | Acer Aspire One Netbook 8.9" Notebook
Mo display
Acer Aspire One BIOS Recovery The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
Sep 13, 2009 | Acer Aspire One A150-1006 Notebook
MY COMPUTER WONT START UP!
Jan 13, 2009 | Acer Aspire One PC Notebook
Acer Aspire One  PC Notebook Logo
21 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
