My Garmin Novi for use in my car does not get any current when plugged in to the cigarette lighter connection. It worked ok for a while, but not now.
  • 3,083 Answers
Make sure the lighter cord is getting power to the Garmin, first thing. You can measure it with a voltmeter. Try to ensure that the contacts are clean (you can sometimes use a qtip and alcohol or electrical contact cleaner). Next, after you know the power's good, insert the adapter end into the Garmin. If you can wiggle it and make it come on, the jack in the Garmin may have a cracked solder joint on its legs. You have to take it apart to fix that. If you need parts, check with Garmin's support site here:
http://www.garmin.com/garmin/cms/site/us/support
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 16, 2010
'93 Jeep won't start - used cigarette lighter for gps instead of power socket
Sounds like a bit of a stretch... (nah).
"Lighter" is a GREAT OUTLET...
Has been for decades.
Perhaps it is just time to consider some BATTERY MAINTENANCE... cable and terminal cleaning
or even A REPLACEMENT battery.
I ASSURE you a cigar/cigarette lighter ELEMENT
pulls a lot more power than your Garmin Nuvi 1450LMT.
Get your JEEP battery checked...!!
Carnac the Magnificent
Jan 07, 2018 | Garmin Nuvi 1450LMT
Garmin says low battery and now will not work in the car. Does this Garmin have a battery inside the unit that I have to replace?
There is a battery in the satnav but it's not user replaceable. It can only be replaced by returning it to Garmin. Before sending it away to replace the battery you could check the following;
  • Have you the satnav connected to the charger?
  • If it's connected to the charger is the cigarette lighter socket working. You can check by plugging in another device to see if it works
  • If the cigarette lighter socket is working and the battery of the satnav is not charging it's possible that the fuse in the plug, that goes into the cigarette lighter socket, is blown.
To change the fuse;
Unscrew the ring that's at the end of the plug and the plug comes apart. Be careful not to lose the silver coloured tip. When the plug comes apart you can take out the fuse and get a replacement at any car accessory shop or a shop that sells garmin satnavs.
If you have to return your satnav to garmin you can find their contact details at http://www.garmin.com/garmin/cms/home/support/supportcontact
May 23, 2011 | Garmin nuvi 255W GPS Receiver
Car power supply for Garmin nuvi 755t does not work. Not sure if its the Wire, mount Adapter or other.
I assume you have checked the cigarette lighter to be sure it's working.
The most likely problem is the fuse in the power cord/charger. The plug which goes into the cigarette lighter socket has a ring at the end of it. Unscrew the ring, taking care not to lose any small parts, and it comes apart. Replace the fuse and it should be ok.
Dec 25, 2010 | Garmin nuvi 755T Car GPS Receiver
GPS plug do not fit in car cigarette lighter
Buy a adapter for your cigarette lighter socket that has multiple sockets with one that will fit the Garmin adapter.
I've never heard of a problem you are having??
Are you using a Garmin plug?
If not get one.
May 08, 2009 | Garmin Nuvi 660 GPS Receiver
Charging the battery in Nuvi 760
1) Check the cigarette lighter is working by plugging in the lighter unit and see if it gets hot. If it doesn't then it is possible the fuse has blown.
2) You can plug the unit into a PC using the USB cable and if there is a fault you will get a message on the screen about 'USB over-current' but it shouldn't damage the computer.
If it runs/charges using the PC and (1) is OK then you may have a problem with the cigarette lighter - cradle cable or a problem with the cradle itself.
HTH
Peter
Jan 24, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
My Garmin Nuvi (200 I think) freezes..
My recomendation is to use the original accesory for cigarete lighter. I'll give you an example: when I connect my Nuvi 200 to any other USB cable (computer or home charger) its behaviour is like you said - it "says" that is connected to a computer and remains in stand by. But when I connect it to cigarette lighter (but note - the original one) the nuvi 200 recognize it as a car power source and works. The battery symbol disappear from screen and it works perfectly. When I turn off the engine or simply unplug the device from cigarette lighter (not from nuvi !) it recognizez that and ask me if I want tu turn it off on remains on on own battery. If I make no option the nuvi will turn off automatically after some seconds. So it recognize perfectly the car adapter and its behaviour is adapted to a car.
Oct 08, 2008 | Garmin Nuvi 350 Car GPS Receiver
Charging unit with AC adapter
I have a 100v A/C power / charger unit for my garmin C340 GPS that I use to charge my Garmin's battery every day. I can use thj adapter to run the GPS, or just turn it off and let it charge the GPS. But it connects dirctly to the Garmin GPS unit, not to the cradle like the Cigarrette lighter unit does. .
Mar 18, 2008 | Garmin StreetPilot c340 GPS Receiver
I can't charge my GPS while I am in the car
Verify that the car cigarette lighter outlet is working. Do you have something that you could plug into the lighter like a light?
With the car running plug the Garmin into the cigarette lighter outlet. Does it come on without pushing the ON button? If the answer is no then there is either a problem with the cable or the cigarette lighter outlet. It should come on by itself if the lighter is working. Also are you using Garmin cables and DC adapter?
Jan 31, 2008 | Garmin StreetPilot C330 GPS Receiver
How to recharge the unit
you can charge it via the usb or cigarette lighter.  either method will work and i am not aware of any problems created by using the lighter.  that really should be the primary charge method as it is expected to be used in the car.  is it charging on your computer.  if it is, but not on the lighter you may want to ensure that the lighter is itself working correctly and then also check to make sure that the fuse in the car charger is intact.  just a few suggestions
Dec 25, 2007 | Garmin StreetPilot c510 Deluxe GPS...
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
