Question about Samsung SyncMaster 191T 19" Flat Panel LCD Monitor
When my computer shuts down, the Monitor flashing green light keeps flashing. My problem is that I can not turn the Monitor "on" light off.
  • bask250 Sep 16, 2010
    I removed power to the computer and to the Monitor. Both the computer and the Monitor sat off with no power for two hours. When I turned on the power to both the computer and to the Monitor, the green light was presentr and flashing. The computer was normal. Removing power to the Monitor seems not to help. My problem is still an inability to turn off the Monitor.
  • 137 Answers
Its a default feature. playing with the fromt pannel may cause an early filure or malfunction.
to get if off, switch off it from the power source. or remove the power cable from back.
Rate this solution, Write a comment to keep in touch.
Posted on Sep 16, 2010
Flashing green light and monitor wont start
There are one or two capacitors that open in the power supply, sometimes it will have a bulge at the top, making it easy to spot.
Apr 05, 2012 | Acer Computers & Internet
My lcd monitor keeps shutting off
your power supply probably has bad capacitors and they need to be replaced
Jan 10, 2010 | Acer X221WSD Monitor
Xerox computer monitor light keeps flashing
try swapping a known good monitor to make sure its the monitor?
http://www.aa1consulting.com
Jul 26, 2009 | Xerox XG-71D 17" Flat Panel LCD Monitor
Starlogic 20 inch widescreen monitor screen keeps going black
This is probably a back light problem. Take a bright flashlight and while the monitor is on, point it at the LCD and try different angles, etc. If you can see an image, it is the back light, probably the back light voltage converter unit in the lcd. It could also be the back light bulbs.
If you don't see an image with the flash light, then it could be the main logic board.
ort11
Mar 08, 2009 | Computers & Internet
Takes to long for the monitor to start
This is a power supply problem in the monitor. There is an unstable component or components that are failing or you have some cold solder joints in the connections.The reason it turns on is that some components are self healing and will sometimes stabilize after warm-up periods.Cold solder joints sometime close after heating up in the circuit You should return to dealer for repair or replacement. Hope this helps you.
Feb 04, 2009 | Envision EN-7100e 17" Flat Panel LCD...
Red light and monitor will not start up
you need to shut down the computer and pull the power cord off powersupply then remove the wire harness that goes on to the mother board then press the and hold the computer on button for 3 seconds then plug in the the harness back on the mother board and and plug in all power cords then try to turn on the computer it should give u a beep or the monitor should go from orange to green good luck e-mail me if u want tbirdfan1@yahoo.com
Aug 07, 2008 | Intel Motherboard
LG L1751S Flatron Screen
My sister's monitor wont turn on at all. She was shutting her system down due to a storm rolling in, and it said windows shutting down installing updates, while she is shutting it down. She turned it on today and the little light came on then it went off and hasn't been on since then. The Tower works fine but the monitor isnt turning on at all. What should she do? She has had the monitor at least 2 years no more then 2 1/2 years! And it is a LG Flatron 20". HELP
Apr 25, 2008 | LG Flatron L1751S-SN 17" Flat Panel LCD...
AL 1916 Monitor Green Light Flashes
I think you have loose cabling somewhere. Try to unplug (and untangle) the video cables and then plug them all back together firmly. If this does not work and you know your machine is booting up properly, you might have damaged the monitor somehow accidentally.
Nov 16, 2007 | Gateway FPD2275W LCD Monitor
ViewSonic Monitor has trouble to wake up after been shut down?
Ok sounds to me like a power supply problem.. this a a fairly common symptom. I suggest that as a temporary fix you set the monitor to NOT turn the power off to the monitor in sleep mode if possible, in your power settings for the monitor.
Jul 24, 2007 | ViewSonic VX924 19" LCD Monitor
Monitors on/off green light flashes
Try first unplugging the monitor and the computer from the wall for 12 to 24 hours. If this does not work, hook up another monitor to the puter to see if the problems with the puter or the monitor.
Sep 22, 2006 | Dell E171FPb 17" TFT LCD Flat Panel...
Samsung SyncMaster 191T 19" Flat Panel LCD Monitor Logo
218 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
