Question about Kenmore 91112 / 91114 / 91117 Electric Kitchen Range
F-1 error code on kenmore stove. shut off power for five minutes but it did no good
  • 15,935 Answers
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
Error message O FF
Unplug the refer and leave unplugged for a full FIVE minutes. This will reboot the CPU and fixes about 98% of all problems with the .
the Kenmore Elites.
If you can't pull the refer out for some reason, try switching off the circuit breaker instead.
Apr 22, 2014 | Kenmore 73502 / 73504 / 73509 Bottom...
Stove burner will not shut off Flashing F-1 tried to reset but stove burner stays on
I am sorry to hear regarding the trouble. This is one of the bad error codes on this product. You could disconnect the power supply for few minutes, say 30 minutes and then turn it ON. If the error codes still remains, this would confirm that you need to replace the clock ( also known as ERC ).
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 22, 2011 | Kenmore Kitchen Ranges
Oven not working after a power outage. Stove top DOES work.
HI, The power surge has, essentially, destroyed your main control boards circuitry. This will happen during a power surge. Most oven control board are not protected from this type of potential damage. To confirm, simply unplug your unit for 5 minutes. Once the five minute reset has passed, simply re- introduce power to the unit, and observe. If you experience the same issues after the five minutes reset, this will confirm the damage to the control board.
It must be replaced if the damage persist after the reset.
Dec 31, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore dryer shuts off after five minutes
The vent box inside the dryer still has lint in it. You need to reach way inside to get at it. Turn power off.
Jul 22, 2009 | Dryers
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
My kenmore electronic stove is having a beep with code F1 on the
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore elite flat top stove
Analog to digital failure. Disconect power for 1 minute. if the code comes back replace the control board.
Nov 17, 2008 | Kitchen Ranges
Problem with Kenmore Electric stove
I have kenmore stove mod.790-95660103 you turn on any top burner . T he small one inside the big burner comes on Roy
Nov 24, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Error code E1 -F5- Broil element comes on and wont shut off
if it is a whirlpool, kitchen aid or kenmore by whirlpool you need to check the self clean latch asembly found on the rear of the unit. check the micro switches with an ohm meter. always remember to unplug the oven before you test any thing or replace parts. not sure why the broil wouldnt shut off. but the f5 error is definatly related to the door latch.
Sep 06, 2007 | Kenmore 95822 / 95824 / 95829 Electric...
Kenmore 91112 / 91114 / 91117 Electric Kitchen Range Logo
417 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
