Question about Wilton 17202 8" Bench Grinder
Motor willnot spin blows breakers - Wilton 17202 8" Bench Grinder
    Problem Solver:
  • 11 Answers
Well, with out seeing it I `d say you had a shot in the cord or switch. I hope this will help
Posted on Apr 30, 2011
Thermostate kicks pump motor on ok. but when its time for the fan motor, all you here is a loud humming then the breaker blows
check for a failed start/run capacitor for the motor
if the motor spins freely then the humming will be a frequency hum because there is not enough power to start the fan running
the extra current will blow a cb
Apr 08, 2016 | Mastercool 67680 Evaporative Cooler Air...
Vulcan Bonaire gas ducted - gas flows and ignites, then fan makes sound like its struggling To get enough power b4 fuse in controller blows. fan spins freely. Any ideas what the problem could be?
have an electrician check the start/run capacitor for the motor
it may be faulty and the motor will not start properly and will blow the overload breaker
Sep 03, 2015 | Dryers
Washing machine willnot wash,rinse,agitate,or spin when I slect the options it will only buzz and then awitch off like a breaker kicks out.
it probably has a start / run capacitor on the motor that has failed and the overload /thermo coupler trips out
have a technician check it out.
Jun 30, 2015 | Amana Washing Machines
Pool pump tripping breaker
shorted pump motor need new one or something is caught in the impeller and wont let motor turn or you can try to spin the motor by hand then try agai if still blows breaker new pump is needed
Jul 14, 2014 | Intex Pool & Spa
My washer keeps popping new circuit
You havent given details when the breaker pops. Is it right away, in wash cycle, spin cycle or drain? If it pops right away, there has to be a short circuit, but it fills water up then as soon as the motor starts n it pops, it could be motor. If blows during spin, definately motor drawing too much current. Then it could be the breaker that is weak/faulty. The breaker if not faulty it will pop if the current drawn by the motor exceeds it's rating or there is a short.
Aug 01, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Heaqt willnot work
The list of suspects usually invovles the heating element, the limit mounted on the heating element, the circuit breaker. The motor is a 120 volt one but the heater needs 240 volts. If the breaker is partially tripped the dryer could run but havee no heat. If the dryer cord id partially out of the recepticle the heat will not work. Make sure the dryer is getting 240 volts. Videos and more are here on my page
Mar 06, 2012 | Whirlpool Dryers
Washer keeps blowing fuses
Do you mean the houses circuit breaker? If so, WHEN in the cycle does it blow the circuit breaker? WHEN it trips will tell you what to look at. I.E. If the circuit breaker trips during the fill cycle then it would be the walter inlet valve or the timer in the control panel; if it trips as soon as it is in the agitator cycle - then the motor or transmission; if it trips in the spin cycle - then the drain pump or transmission or control panel.
Jul 15, 2011 | Maytag LSG7806A Front Load Stacked Washer...
Will not spin out water
Sure its not pump you can hear? your motor carbon brushes may need replacing
Feb 11, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Just replace compressor keep tripping circuit breaker
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
The fan motor could have been your problem all the time, because if the fan doesn't come on or runs slow, it causes high head pressure,
which causes high amps, which could trip your breakers.
Aug 02, 2009 | Heating & Cooling
My washer does not spin.
Check the drive coupling. Part number is 80040. This item connects the drive motor to the transmission. If broken, you will hear the motor running but the machne willnot do anything else but drain....
Mar 22, 2009 | Kenmore Washing Machines
Wilton 17202 8" Bench Grinder Logo
104 people viewed this question
Top Wilton Grinders Experts
DrBogo
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Tom Chichester
Are you a Wilton Grinder Expert? Answer questions, earn points and help others
