Question about Crosley CDG6000 Gas Dryer
Dryer is noisy - Crosley CDG6000 Gas Dryer
  • Crosley Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Sep 21, 2010
The dryer is making a knocking sound when running. The sound has increased lately. What may be the cause of the noise?
Hello there and thank you for choosing fixya
If your dryer is noisy, check these:
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them. Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn. Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to repla
Aug 04, 2011 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
My GE dryer is making a real loud noice while drying model #DBXR463ED2WW
hELLO THERE
If your dryer is noisy, check these: Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them. Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn. Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Dec 04, 2010 | GE Dryers
Dryer noisy while running overloaded yesterday
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
May 09, 2010 | Whirlpool ET8CHEXSQ Dryer
My Asko stacking dryer makes a small squeaking noise
Hi, Check for the following:
  • Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time
  • Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
  • Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
  • Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Apr 17, 2010 | Asko T761 Electric Dryer
Affinity front loader dryer. The drum is not
It's noisy If your dryer is noisy, check these: Rollers Idler pulley Glides Rear drum bearing Blower wheel Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them. Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn. Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it. Hope this helps
Dec 10, 2009 | Dryers
Sqealing
May 12, 2009 | Dryers
Dryer makes a squeaking noise
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
thanks and please do not forget to accept the solution
Apr 03, 2009 | Frigidaire FEX831CS Top Load Stacked...
Dryer makes noise when turning like bearings going or belt squeek
check the following -
It's noisy
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
good luck.....
Mar 28, 2009 | GE WSXH208A Front Load Washer
Kenmore stackable washer/dryer...dryer making HORRIBLE shrieking sound while drying...any ideas?  don't have dryer #
Hi
Please revert for further assistance and Do rate the solution as "FixYa" if found useful.
Thanks
Rylee
Mar 18, 2009 | Kenmore 84052 Dryer
When our dryer is turned on it has a very high pitched noise as if some metal is rubbing on the drum. It is model number DBXR453GVOWW.
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Mar 07, 2009 | GE Dryers
Crosley CDG6000 Gas Dryer Logo
61 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
charles
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
