posted by maryfkm on May 17, 2008
Everything looks ok from the bottom. But the machine is just too low.
Solution #1
posted on Jun 01, 2008
This unit has the outer window, and a half moon window behind it. Check to make sure the 2 screws holding the half moon window are tight and that the plastic hasn't broken. The 2 windows at the bottom cener merge together, they may have come apart. Usually when one or the other window is out of place, it will cause a drag. You may have to replace the half moon window.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Bissell 1699 ProHeat Clear View
Email this problem
Email this problem
Can you Help with these Vacuums problems?
Bissell 1699 ProHeat Clear View Upright Steam...
i have a 1699 proheat
i have a 1699 proheat upright... Answer This...
Carpet Cleaner
Carpet Cleaner
i was cleaning my carpet and it... Answer This...
replace the switch that...
My carpet cleaner is not... Answer This...
BISSELPRO HEAT CARPET CLEANER
i have taken the top handle... Answer This...
Bissell Proheat
Bissell Proheat
I need help installing a belt... Answer This...
Repair Service
Find Vacuum Repairman Near You:
