Question about Caravell Refrigerators
I have a Caravell upright open chiller model WD60 /95, im getting a error code A1 3 & A1 4 and it keep bleeping constantly. Its working, so thats a good sign. Any idea what the code means ? Rgds
Jexx
  • 148 Answers
SOURCE: error codes
One of the parts went bad, and you need to take it into the dealer. The way Alpine's error codes work are very vague. E-3 could mean the psu fried, a resistor went bad etc.
Posted on Aug 17, 2006
Powerman
  • 68 Answers
SOURCE: Oven error code
See my solution to OVENMAN/April 12, 2007. I have supplied my fix to over 650 individuals and have had a high reported success rate.
Posted on Apr 14, 2007
aborcass
  • 2651 Answers
SOURCE: Freezer runs constantly
not necessarily, is it maintaining temp? all food staying frozen? especially ice creams if stored in there. most newer freezers displace the heat generated while cooling the food through copper lines running through sides of unit, helps to cut down on air temp differences between the inside (0 degrees) and outside temp to prevent moisture and possible condensation causing premature rusting of unit
Posted on Mar 03, 2008
SOURCE: Kenwood kdw243a dishwasher has an e3 error code
i have same prob,seen this elsewhere folks. apparently it's the temp sensor which MAY have failed. http://www.howtomendit.com/answers.php?id=134096
has to be cheaper than an expensive call-out and worth a try.
Posted on Mar 16, 2009
  • 193 Answers
SOURCE: WHEN CLOSING AND OPENING CHILLER DRAWER LIGHT BLINKS
could be that the bulb is not screwed in all the way. it could also be that the switch is going out. if that is the case you can find a replacement here.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?aplbrand=10&model=+PSS26MSRSS
Posted on Aug 14, 2009
Why is my upright fridge freezer bleeping constantly, both fridge and freezer cooling ok
Model number? Usually that is warning that something is wrong. Example defrost not working properly thermistors are defective, or door open. Need your model number to give you answers
Appliance 911 Sea Breeze
Oct 01, 2015 | Refrigerators
Samsung Cool n Cool upright fridge freezer bleeping constantly, both fridge and freezer working OK
Oct 01, 2015 | Samsung Refrigerators
Why does my acer aspire z5761 keep freezing and has horizontal lines across screen and constant bleep?
You probably somehow killed the screen. Did you drop it or bang it into something? You can try downloading and replacing the drivers, but I doubt that will help. Lines on the screen are usually a physical problem, not software related.
You may try a Windows Restore if your machine has that ability. Some do, depending on who you bought it from. Again, doubful it will help, but worth a shot.
Need more information on the bleep. When does it bleep? Constantly? When you touch the screen? Or when you boot it up? What kind of bleeps? One? Several? Long? Short? Both? Repeating sequence?
Jun 28, 2015 | Acer Computers & Internet
Kenwood KDW12ST3A dishwasher keeps bleeping and showing E4
Many owners manual list common error codes. I would check there first. If that doesn't work try repairclinic.com and access trouble shooting DIY help by model number for model specific information. Good luck.
Jun 27, 2015 | Kenwood Dishwashers
My battery is fully charged but my scooter wont go?
hi, how many bleeps before a pause ? or is it constant bleeping ?
This error can be caused by a bad connection , check where the back end comes away from the frame...
Regards
Rob
www.gewizrepairs.co.uk
Aug 17, 2014 | Pride Mobility Products GoGo Elite...
Display panel on fridge door display flashing from 4 to 7 and beeps 5 times.
the blast chiller fan has prob failed
also check the thermal fuse on the heating elements that are around the chiller elements {used to defrost the chiller section}
and if there is also one on the fan check it
the beeping is prob an error code
you can consult the manual or phone the makers support number
to get more info on the exact error detected
usually there is some reset error like hold in the button etc and power on then let it go
more any more appliances have this
and if you dont know to reset
even if the error is cleared the unit will remain in this error mode
till reset again check the manual
Jun 19, 2014 | Amana SXD524VW Side by Side Refrigerator
Caravell CATF61 can not find temperature control
It's supposed to go to -20! Is there a panel in the side at the bottom? Stat is inside the panel
Mar 31, 2014 | Caravell Freezers
The ice cream gets to hard and we have to take the big cartons out for 2 hrs before we can scoop it. (How can we bring the tempreture up about 10 or 15 deg.?)We can't find any controls on it. We have no...
Hi, I think you have tell wrong model . Please try find out the temperature controller. Your freezer should able to adjust temperature from 0 - 18 Deg. F
Chest freezer of caravell has 2 model i.e :
1. Caravell SST-5213.7 cu ft Chest Freezer With Solid Sliding Doors
  • Durable white powder coated, baked on enamel finish
  • Solid sliding top doors
  • Cord and plug included
  • Self-contained refrigeration system
  • Temp. range 0 to -18 degrees F
  • 13.7 cu ft capacity
  • Heavy duty casters included
  • Dual drain plugs for easy cleaning
  • Environmentally friendly CFC-free R-134a refrigerant and insulation
  • 115V, 4.5 Amps
  • 51 1/2"W X 25 3/4"D x 34 3/4"H
  • One year parts, 90 days labor warranty plus 3 year compressor warranty
  • & 2. Caravell GST-5213.7 cu ft Chest Freezer With Glass Sliding Doors
  • 115V, 4.5 Amps
  • Regards, jay
    Nov 30, 2010 | Caravell 13.7 cu. ft. / 388 liter Chest...
    Model 30gx faults code
    Hi, the indoor chiller unit blower section will have a sheet glued to a panel on the unit that will tell you where and what the code 302 means on the unit. Then you will be able to make the repairs you kneed.
    Shastalaker7
    PS the numbers above show that this is a 3 ton unit, 38CKC036. The error code more than likely will be 3 flashes from the board followed by 02 flashes. I may be wrong on that , so correct me if I am.
    Mar 16, 2010 | Carrier 38CKC036 Air Conditioner
    Refrigerators Logo
    52 people viewed this question
    Top Caravell Refrigerators Experts
    John Tripp
    John Tripp
    Brian Coughlan
    Are you a Caravell Refrigerator Expert? Answer questions, earn points and help others
