Question about Mitsubishi WD-73733 73" HDTV
White spots showing up on my 73" mitsubichi wd tv
  • rottylover10 Oct 06, 2010
    yes, they started with a few, 2-3 and now there is like 27.! and counting..I cannot get any help from the place i purchased it, and believe it is still under manufacturers warranty..what can i do.?
    the spots never move, they stay in the same place, they just keep adding more everyday, and are mostly near the bottom of the screen and right side. there is also a cold air vent about three feet from the left side of the tv..could this be why the spots are all on the right side.?
  • 4,889 Answers
Clear case of bad DMD module. Does this happen on all inputs? Do the dots stay in the same position always?
Posted on Sep 16, 2010
  • eagle338
    eagle338 Oct 06, 2010
    No I don't think its related to the cold air vent. It is clearly a case of bad DMD. Please let me know which country you are located in so that I can give you the customer support contact info for your country.
What can be done to repair
This is usually due to physical damage from the screen being touched or bumped. There is no way to repair.
Aug 01, 2014 | Mitsubishi WD-73837 73 in. HDTV
White spots on my screen
Seems like a dead pixel in the display. The only way to fix it is to buy a new screen which could be more than the TV itself or just buy a new tv.
Dec 30, 2012 | Mitsubishi WD-73734 73" Television
Just paid to replace the lamp 2 weeks ago in our mitsubishi 73 dlp 1080p tv purchased a 5 year in home contract with Tweeter Sevice net 1/2008 lamp fixed and picture is once again great but now the 73...
Mitsubishi that the one,who u should contact.Talk to them make some kind of deal with them to help u to do a repairing or replace the tv Light Engine Projection Block.That the tv problems,this problems a design flaw on the tv Light Projection Egine Block the IC they put in that causes of this white spots are showing up will continue showing up more and more white dots.It will not stops.
Sep 03, 2011 | Mitsubishi WD-73833 73" HDTV
Thousand white spots on screen started with two more every day can it be fixed ???????????????
Sine the TV's a rear projection DLP and the problem "grew" over time, perhaps those white spots are... DUST!!! Try a vacuum cleaner; there are ventilation holes/slots on the back and sides. If sucking and/or blow air into it moves the spots, then it's definitely dust or some other debris/contamination. If the contamination is hard to access, you may have to open it up to do liposuction.
Jul 18, 2011 | Mitsubishi WD-73734 73" Television
White dots on screen
I developed white spots on the screen of my Mitsubishi WD-57734 in increasing numbers over days and weeks. I called a repair service who quoted me $1500 to replace the light engine. He suggested I call Mitsubishi Customer relations at 800-332-2119 option 5 which i did. To make a long story short after several conversations with them they agreed to replace the part for free if I picked up the labor (Would have been less conversations if I had the original purchase receipt). Instead of $1500 I paid $250. The tv was only 3.5 years old. Perseverance paid off.
Jun 17, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
I have white spots and black spots on right side of Mitsubishi WD-C657. I've done research online, and have heard its the dlp chip. Is that true, and if so, is it something that I can replace myself,...
This tv is it the DLP projection light engine block main board itself is the problems,not easily to go into the tv itself and replacing the IC chip itself.Must take out many mechanical parts to get u the Light engine block it self.U can replaced IC but somethime the IC chip it replaced,will not solved the problems,because the tv problems now the it is spreading and going on beyond the IC chip itself.If want to keep this tv very exspensive repair,i would reconmend hire a bound qualify tv tech replaced the whole Light projection block itself,but first call Mitsubishi for some kind of deal,they might help with the repair amount cost.
May 13, 2011 | Mitsubishi WD-C657 65" HDTV
Bright white spots on mitsubishi wd-73833 I just replaced the lamp and now these bright white spots have started to appear!
This unit uses a DLP (digital light processor) chip and if this starts to fail then you will get spots appearing on the screen. The DLP chip will need to be replaced.
Mar 24, 2011 | Mitsubishi WD-73833 73" HDTV
I have black and white spots on my tv i can i fix it?
You need to replace the DLP chip to resolve this issue.
Dec 12, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
White dots on my tv screen
this problem is coming from your DMD board it looks like some LCD chips are getting stuck in the on or off position you need to replace the light engine system to fix this problem check this link out
Please rate this solution as I do this for free!!!!
http://forums.cnet.com/5208-7596_102-0.html?threadID=257865&tag=forum-w;forums06
Sep 20, 2010 | Mitsubishi WD-73733 73" HDTV
Mitsubishi WD-73733 73" HDTV Logo
577 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
