Question about Element Electronics FLX1911B 19 in. LCD TV
Dish Network remote will not turn the set on or off and will not adjust the sound level. Dish tells the they do not have the code For Element TV's and I will have to use 2 remotes. Can you solve this problem? Jerry Weber
    Novelist:
    Champion:
  • 286 Answers
Sometimes the remotes have a hard time programming to the tv. Below is the link to the steps for a power scan. Instead of needing a code to program the remote, the remote will scan through the codes on the tv until it reaches the one that works. I hope that this helps!!!!
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Becki Barned
DISH Network Customer Service
Posted on Jan 20, 2011
Codes for tv remote for dish
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts. Dish TV remote control code list is given.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Sep 16, 2014 | DISH Network Televison & Video
Element 32 inch tv how to control sound with dish remote?
Check it by set it up with an other code to Element brand TVs. The most used code to Element is "0159". You can try these codes too. 0225 0324 0378 0421 0456 0460 0604.
Sep 16, 2014 | Televison & Video
Incidentally, i am using the monitor as tv, not computer monitor--it is hooked to the satellite(Dish)--image is perfect, but no sound. The adjustment on the remote works, and I can see that it thinks it is...
Hi well i assume you are using the HDMI output? or maybe you are using the ordinary Video out? In any event what you may need to do is hook up also the Red & White Stereo Audio... on the TV to the Output of the PC's sound card. This will then give you sound.
Also when changing the sound NOW when using the two you must control the sound by first setting a volume on the TV with the Remote, and set a level, then ALSO you can adjust this as well with the remote or Volume control of the receiver, ie: The PC's volume,
Oct 10, 2011 | Envision Monitors L19W698 19 in. LCD TV
My remote will not turn the tv on or adjust the sound, it will change channels
First, try pressing TV on the remote, check if that solves the problem. Then press Sat and try the TV power button again. If the remote previously controlled the TV, you lost the code for the TV. If you have your Dish Network manual, check if you wrote down the code when it was originally programmed. Which specific remote/receiver do you have? The programming directions and code lists are available here: http://www.dishnetwork.com/supportsection/remote-setup . You can also scan all of the codes to find the correct one: see http://www.dishnetwork.com/SupportSection/power-scan-instructions . Additional remote/receiver manuals are here: http://www.dishnetwork.com/SupportSection/manuals .
The direct coding procedure for the Dish remote that I have is: while facing the TV to be controlled (after adjusting the key for TV1/TV2 in a multiple TV system), press and hold TV until all four indicators light up. Then enter the 3 digit code. Press and release the # key. Then see if the code TV powers off when you press Power. Then press Sat and check if the TV power button works. Try additional codes if the TV doesn't respond.
If you recently got a new TV and you tried to program the remote for your TV, your dish remote may not have the code you need. (Most universal remotes are limited to codes for devices released 6 months or more before the remote was programmed.) In that case, you should use the TV remote (and see if it has an option to control the satellite receiver). Alternatively, get a new universal remote that will control all of your devices. (The remotes that can be programmed by USB are the easiest to set up.)
I hope this helps.
Jul 09, 2011 | DISH Network IR Remote Control
My new remote that came with the tv does not allow me to change channels, but my dish remote still allows me to change channels
Your dish remote is the only one that is compatible with the dish receiver. You're going to have to program all the functions you want to use to the dish remote. They are usually set up for all the normal functions, volume, power, dvr etc.
Dec 08, 2010 | Element Electronics PLX4202B 42 in. Plasma...
I need a code for my element tv for the dish remote
Hi there! This is Cheri Torres with DISH Network customer service. I was reading through the questions posted here and wanted to see if I could be of assistance to you. :) We have a few different codes for each of our different IR remotes, so I will give you the remote codes that work the best for the most common remotes that we have. For the 3.0, 3.1, and 3.2 IR remotes the best codes are 627 and 659. For our 5.0, 5.2, 5.3, and 5.4 IR remotes the best codes for the Element TV are 627 and 902. I would also like to list for you the instructions for addressing your remote to your Element TV. I hope you find these codes and instructions useful. If you have any further questions regarding this issue or any other issue please feel free to post back here or email me at Cheri.Torres@Dishnetwork.com.
Instructions for addressing your DISH remote to your TV
  1. Turn the Television On.
  2. Press and Hold the TV mode button for three seconds until all of the mode buttons light up. Once you release the TV button it should flash.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press the pound(#) button once. Note: The LED will flash three times.
  5. Test functionality with the TV
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Dec 08, 2010 | DISH Network IR Remote Control
My dish remote does not control my element tv do someone needs the codes?
castro_ed387, I am unable to provide you a code as I do not know the remote model, but the steps below will help in programming the remote to the TV, and I included a link on the bottom that has the codes on it.
Program to TV:
2. Press and hold the gray TV button on top of the remote until all lights turn on.
3. Let go and TV will be blinking, enter the three-digit code using the buttons on the number pad.
4. Press # and test functionality with the TV
5. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television. If it works press SAT.
Link for codes: http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml
Tommy Faust
DISH Network
Oct 04, 2010 | DISH Network IR Remote Control
Dish remote
cathyw43
I have provided instructions on how to program your DISH remote to your TV. I have also provided a link with the codes for TV manufacturers. I hope this helps.
Program remote, step 6:
Ray Calo
DISH Network
May 29, 2010 | DISH Network IR Remote Control
Have to manually turn on tv when turning on digital converter box
astoner3,
Our dish remotes are compatible with most TV manufacturers. On some older TV, we may not have codes that allow for full functionality for the DISH remote. I have provided the most common codes to work with the Sharp TV. The codes are: 628, 605, 740, 591, and 606. I have also provided instructions on programming the remote to the TV.
Remotes: Basic (Television Only)
  2. Press and Hold the TV Power button for three seconds until the LED flashes
  4. Press OK. Note: The LED will flash three times.
Ray Calo
DISH Network
May 15, 2010 | DISH Network EZ Remote Remote Control
Dish network remote with a element tv
Since you dont have a popular brand set you should try using the scan method. Here is a link with a video to help program your dishnetwork remote to work with your set. http://www.disheez.com/videos/dish-network-video/programming-dish-network-remote/
Nov 23, 2008 | DISH Network IR Remote Control
Element Electronics FLX1911B 19 in. LCD TV Logo
200 people viewed this question
Top Element Electronics Televison & Video Experts
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
