Question about Remington 16" Electric Chain Saw
I have a 107624-02 Saw. Need a replacment chain. #091375-03S. As the company is bankrupt, the new Remington has no blades. How can I find one?
    President:
  • 2,220 Answers
Any local chainsaw seller/mechanic given your chain as a pattern can fabricate a replacement in about 5 minutes. Take your saw and they might even mount the new chain for you.
You might also try here:
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
I did not see a -02 but doubt there is any difference. The number of drive links (the part in the bar groove) is most important but pitch and gauge also enter the equation. The FAQs here are quite informative. A local chainsaw (Stihl or Husqvarna) store will get it right with no doubts.
Good Luck
Lou
Posted on Sep 16, 2010
How do you tension remington electric chain saw
The most common would likely be by releasing the chain/blade assembly lock nuts (likely to be two) on the outside of and at the the drive end of the chain, or by first removing a cover over this part of the chain assembly to access these nuts. Next, there could be a tensioner screw assembly located between the inner side of the the saw blade and the motor or possibly at the back of the chain/blade assembly. Screwing this screw in the appropriate direction will tension the blade. After all slack is taken up on the chain (without over-tightening or stressing the chain!), re-tighten the two previously loosened lock nuts that secure the blade in place and replace the cover, if removed. This would most likely be the process for fitting a new chain as well!
Aug 27, 2014 | Remington Garden
Need manual for remington electric chain saw 1,5 hp 14in blade like to know how to tighten loose blade.
There is a slide bolt on the side of all chain saws that allow tightning of the chain. You loosen this bolt and slide the chain bar forward until you can just slide a dime under the chain and the bar. It may take a couple of adjustments as the chain stretches a little after it gets warmed up by the friction of the bar.
Apr 04, 2011 | Remington Electric Chain Saw
I have a 16 inch chain saw and want to buy a new chain saw blade does anyone know what other manufacturer's blade will fit
Oregon mfg. makes a full line of replacement chains and bars (blade). Check with home centers, hardware stores, and saw dealers. Bring full details of the saw with you, or the saw itself. Good luck!
Jun 03, 2010 | Desa International Remington 12 Electric...
Oil leak on Remington electric chain saw model #111174-01
check oil lines and when storing saw stand on end or on side blade up.. vote if'n i was of help.. remember BUY USA MADE PRODUCTS.. Jay
May 13, 2010 | Remington 16" Electric Chain Saw
I am trying to find areplacement for a model #
Good news Victor;
Both a bar and 3 different chains are available through an Oregon dealer. The green chain (hover the cursor over the color and there is an explanation) is most likely what your saw came fitted with but all will work, the choice is yours.
I input "Remington; M15014AS; 14"; All; All; All".
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 05, 2010 | Remington Electric Chain Saw
Chain replacement.
Input "M12510US" in the model number here (if not your saw the procedure should be similar):
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" into the "Model #:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Breakdown" link.
See pages 7 through 9, for use as a guide.
HTH
Lou
Are you aware RemingtonPower is no longer in production? Replacement parts are becoming difficult to find.
Jan 23, 2010 | Remington Electric Chain Saw
Which chain saw blade do I use to replace the blade
Remington.com
Items 13 and 14 on your IPB
6" Guide Bar $12.98 and 6" Chain $11.97
Remington Power has stopped production and many replacement parts are NLA. I suggest you waste little time ordering these. HTH
Lou
Dec 18, 2009 | Remington 111409 - 01 6" Branch Wizard...
I just bought a replacement chain saw blade for my Remington 14'' Limb & Trim. It is an Oregon brand blade which says it is for 14'' Remington among others. But it is a bit too long for what I have. My...
Take it back to where you purchased it or contact them by email/phone and explain your problem (have saw in hand). Together you can solve this. We cannot find the model number on your saw from here. GL
Lou
Sep 14, 2009 | Remington Garden
Replacing Remington Electric chain saw blade
Where the bar meets the body of the saw there is an adjustment lug that will either push the bar outward tightening the chain or may be retracted allowing slack in the chain. When backed off (loosened) sufficiently, the chain may be removed for replacement. In order to use this feature, however, there are two bolts that secure the bar to the body that must be loosened prior to any adjustment and tightened bach up after making adjustments to the chain. The above will be enough to remove and replae the chain. If you are taking off the bar (that the chain runs on), you will need to remove the two bolts that were just loosened for the chain adjustment (above).
Regards! --WoobieDog--
Jul 07, 2009 | Remington 16" Electric Chain Saw Assembled...
Remington Electric Chain Saw, Model 106890-02 I need a gear replacement for the plastic gear betwen the drive gear and the gear which drives the chain.
Here is a link to the model 106890-02... http://12.153.20.74/manuals/107052-01A.pdf, I would also suggest you contact the parts department at 800-446-1446. They should be able to help you.
Mar 15, 2009 | Remington Garden
Remington 16" Electric Chain Saw Logo
418 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
roeb
Are you a Remington Garden Expert? Answer questions, earn points and help others
