I am have issues with my projection TV. Hitachi model 57T600. Colors are mis-aligned. Magic focus butoon doesn't help the issue. Go into manual adjust and can get the first point aligned, but the rest of the grid gets worse. Can get second point close, but rest of the grid gets even worse. making it almost impossible to continue at each point. What will fix the issue and is there a service manual available for my TV?
MikeMaierTV
  • 206 Answers
SOURCE: hitachi 42 hd projection tv
With out a model number to ref to just have to give this a stab. Sound like you are talking about a projection set that has convergance Ic failure, Hitachi put out a kit that has all the most common parts to repair you set, but there are about 4 kits and need a model number to get you the right one
Posted on Jan 30, 2008
  • 58 Answers
SOURCE: Hitachi TV
You have a defective light engine and you do not have to be under warranty for Hitachi to replace this part. We just went through this and here's what you need to do. Call Hitachi's customer relations department at 800-654-7013 and tell them that you have a defective light engine. They will act like they've never heard of this problem but they have. They will give you the names of some certified dealers in your area to call. Once a tech comes out and confirms that it's the light engine, call Hitachi back and they will send a brand new light engine to the dealer and Hitachi will cover the cost of the part (cost $1500).
Here is the deal, if you're under warranty, Hitachi will cover the part and the install. If you're not under warranty, all you pay is the install. Our install cost $400. Others on this site have paid $200. Do not let anyone tell you that you have to pay for the light engine part...you do not. Hitachi has not recalled this part but they are replacing it for free. Also, deal only with Hitachi customer realations number that I listed. Good Luck!
Posted on Mar 05, 2008
Ecollier2012
  • 3459 Answers
SOURCE: Hitachi 43VWX10B Rear Projection Television - color adjustment problem
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Mar 15, 2009
  • 197 Answers
SOURCE: Menu pop up
needs sft waer update call philips
Posted on Jun 07, 2009
  • 30 Answers
SOURCE: magic focus problem
in the menu first check if focus is set to auto or manual, need to be auto, if it is then pop off the front cover and acess panel with TV on cafefully press small button on signal pcb front edge, this is service mode, press pip mode,then pip channel after intialize turn TV off then on, function should be restored.
Posted on Aug 09, 2009
I have a 65 inch Hitachi projection TV and all of a sudden lines apperaed on the screen that runs across the upper part of screen. I tried using the"Magic Focus" setting to get rid of these lines...
The tv Magic Focus button don't solved these R,G,B colors lines mis alignments problems.Mean ur tv have a convergence pictures problems,it is dead.Ur tv now have any colors lines like R,G,B mis alignments,have a colors shadows picture or a 3D pictures look alike?Yes,mean ur tv convergence board it is dead to causes all of these pictures problems.The tv convergence board must have to repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Sep 24, 2011 | Hitachi 65S500 65" HDTV-Ready Rear...
I have arear projection Hitachi big screen that has an unlevel picture. Crooked a bit. How can I manually fix this?
Very common problems for DLP tvs,will get worst as times go by.Tv probally have a problems known as a convergence problems,it is dead.Tv have colors lines R,G,B unlevel on the pictures?Crooked pictures have mis colors alignments?Yes.There is no way manually to do an adjustment to fixed for this.Try push the tv remote button that said Magic Focus button.If the tv have data processing never completely done and have a error message and stop.Ur tv 100% have a dead tv convergence board,the tv convergence board must have it parts to be replaced like 2 STK convergence ICS and some or all of it resistors too.Than tv will be able to run the tv remote Magic Focus again to have a 100% data processing with no error message,tv to fixed this problems.The shop will cost u like $300-350 for parts and labors.
Jul 17, 2011 | Hitachi 61SWX10B 61" Rear Projection...
Ghost image in red and alot of red color. This occurs all the time. I have tried magic focus and manuel focus. No change
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?This tv have a dead convergence board.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.Fixing the tv convergence board,will solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Feb 09, 2011 | Hitachi 51F500 51" Rear Projection...
Won't magic focus
Magic FOCUS button no help all?The tv have a problems known as a convergence problems,it dead 100%.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors it dead too.These parts on the tv convergence board must be replaced to solved the tv convergence pictures problems.The shop,will cost u like $300-350 for parts and labors.
Dec 08, 2010 | Hitachi 53SBX59B 53" Rear Projection...
The magic focus does'nt seem to reset the auto convergence on the tv. Do you have any sugestions
The Magic focus button,not in effective anymore.The tv is 100% have convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must replaced these parts on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 07, 2010 | Hitachi 46F500 46" Rear Projection...
The top of the screen is yellow color then drops down in a swoop and more yellow and blue. otherwise picture is good, pushed the magic focus but it did no good. thanks for any help
The magic focus button don't work.The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost u $300-350 for parts and labors.
Oct 15, 2010 | Hitachi 65TWX20B 65" Rear Projection...
51 Hitachi rear projection 6 years old, can't get it to focus, Has sound. Can only get the picture to come in abpout 80%. Around the perimeter, sports scores and subtitels are not readable. Used the fucus...
Flash Focus magic button no longer work.The tv have a problems known as a convergence problems,it dead.Tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures problems.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost $300-350 for parts and labors.
Oct 13, 2010 | Hitachi 51F500 51" Rear Projection...
Can't get full screen. tried all aspect selections. also color is off. can't get it to adjust. magic focus dosen't help. any suggestions?
Magic focus button don't work.Colors lines R,G,B mis alignment,have colors shadows picture or 3D pictures.The tv have a problems known as a convergence problems,it dead.The tv convergence board it dead,must require replacing 2 STK convergence ICS and some or all it resistors to solved the tv convergence picture problems.The shop,will cost u $300-350 for parts and labors.
Oct 07, 2010 | Hitachi 57F510 57" Rear Projection...
Magic focus error Hitachi 52
The model number you have selected here does not have magic focus--if you really want a answer post the correct model number.
SD TECH
Dec 12, 2009 | Hitachi 52LDX99B 52" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
