Question about Frigidaire ATF6000ES Front Load Washer
I have a frigidaire front load washer and the door lock light does not come on and the washer won't start
    President:
  • 1,430 Answers
This is usually caused by the door switch. These are fairly inexpensive and very easy to replace. First unplug your machine. To check you will need to remove the wire ring that holds the front door seal to the front panel. To do this go to the six o'clock position and you will see the spring of the wire clamp, grab this with a pair of needle nose pliers. Grab it right where it connects to the wire part of the clamp and pull it parallel to the front panel. This will stretch the spring so it can be pulled over the flange. Next carefully peal the door seal off of the flange. You do this with a sort of rolling motion towards the opening in the door. Next remove the screws that hold the door switch in place. Make sure you have one hand supporting the switch assembly while removing the screws. Now pull the whole assembly out the opening. Mark wires if you need to and then remove the wires. Now connect your ohmmeter to the 2 wire on the bottom you should have a reading of 1500 ohms no less than 1400ohms. If it is below the 1400 or more than 1700 replace the switch. To reassemble reverse the order of disassembly. Making sure the little arrow on the door seal lines up with the mark on the front panel. The spring can be a little tricky to get back on but grab in same position as removal and use the other hand to push it over and around the seal. Here is a tutorial to walk you thru http://appliancehelponline.com/washerdoorswitch.html . If it is within this range the main control board or motor control board at fault. Not inexpensive. You can enter your model # at www.appliancehelponline.com to view diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Posted on Sep 16, 2010
  • 883 Answers
SOURCE: Frigidaire gltf1670as0 Front Loading Washer
door lock position switch may not have been properly tightened at factory. first position then tighten the switch
Posted on May 23, 2007
SOURCE: FRIGIDAIRE FRONT LOAD WASHER
I too had the same problem, I closed the soap tray and a magnet popped out and got stuck to the door. Same problem with it acting like it was going to start and then beeped. This is where the magnet goes, just stick it back in, its held in with pressure (barely) :)
I took the whole control panel off to locate the magnetic reed switch, then just reverse engineered where the magnet is supposed to go on the soap drawer.
Posted on Sep 26, 2008
SOURCE: Frigidaire Front load washer FTF2140FS
I HAD THAT TOO I UNPLUNG IT FOR 30 MINTUES AND WHEN PRESS START AND CANCEL TOGETHER AND PLUNG IT BACK ON IT SHOULD BLINK A FEW TIME THEN STOP . IF THIS DOESNT WORK THEN REMOVE IT AND MAKE SURE NOTHING CAME LOSE AND PLUG IT IT AND IF THEN NOTHING HAPPENS SORRY ITS BROKEN REPLACE CONTROL PANNEL.
30-50 $$ NOT MAD AT ALL
Posted on Nov 10, 2008
  • 240 Answers
SOURCE: accessing the door lock switch
spring clamp around boot (spring at bottom) pop off with screwdriver, pull boot off groove.
Posted on Mar 16, 2009
SOURCE: My Frigidaire front load washer won't start
A year later! I experienced the same problem this morning - exactly as you, Bessie24, stated. I could hear a faint humming sound and thought the lock mechanism was still trying to complete its locking function. It would know the lock function was completed when the lock trips the wee (micro) switch. I reckoned if the female portion (with switch) were a tiny bit loose, the switch might not trip, so I loosened then tightened the two screws attaching it to the carcass of the washer (as opposed to the door part) while pushing upward on the same part. This fixed my problem and i hope many others find this procedure useful.
Posted on Oct 11, 2009
FRIGIDAIRE FRONT LOAD WASHER WON'T START. DOOR LOCK WILL NOT LOCK. DOOR LOCK LIGHT IS OFF. PULL START HANDLE OUT/ NOTHING. HEAR CLICKING WHEN TURNING SELECTOR SWITCH/BUT WILL NOT LOCK DOOR OR TURN LIGHT ON...
Good Morning REDS, thank you for your inquiry!
I understand that your door indicates it is open and your washer will not operate. Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn on the washer. Select a normal cycle, confirmed the latched is securely latched and verify if the washer will start. If the washer will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. At this point, it would be advisable to contact an experienced appliance repair tech to assist further.
Sep 11, 2013 | Frigidaire ATF6000ES Front Load Washer
Why won't my door lock?
If the door lock will not engage, then the door lock will need to be replaced. Here is the lock to order.
Nov 18, 2012 | Frigidaire ATF6000ES Front Load Washer
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire front load washer model LTF7000ES0 got out of balance with a heavy pillow and we had to stop it. Now it won't do anything. Everytime I start it, the door light comes on as usual, then a
Check to see if the door sags at all and doesn't line up correctly with the door latch. Then check to see if the drum wobbles when you rotate it yourself when not in use.
Jul 30, 2012 | Frigidaire ATF6000ES Front Load Washer
I have a Frigidaire Front Load washer Model#ATF6000FS2 washer . It will not start and seems to be experiencing a problem with the door. There is 'DOOR LOCK' light that does not turn on and th
Sounds like the door is not latching correctly. Check the door for any sagging problems and then check the door latch itself for any damages, cracks, or issues with the door itself connecting to it.
Jul 21, 2012 | Frigidaire ATF6000ES Front Load Washer
Fridgaire FTF530fs3 door lock buzzing and not locking, washer won't start
fit a new door lock as if it doesnt engage it wont allow the machine to start the washing cycle
May 31, 2011 | Frigidaire FTF530FS Front Load Washer
My Affinity Front load washer, Model #ATF7000ES1
I am having this same exact issue, have you figured out what the was?
May 13, 2010 | Frigidaire ATF6000ES Front Load Washer
The door lock on my frigidaire washer
The locking mec is jambed or broke easy fix hope this helps
Apr 29, 2010 | Frigidaire GLTF1670A Front Load Washer
Aug 11, 2008 | Frigidaire ATF6000ES Front Load Washer
Door lock
Check for loose wires in the door lock; or replace door lock.
Dec 02, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
153 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
