Question about Whirlpool Refrigerators
Do model no. ED2CHQXKQ05 serial no. SP3737210 have a filter anywhere had this side by side with water and ice in the door for about 4 or 5 years and i cant find a filter anywhere.
  • 744 Answers
It appears that this particular unit has no water filter. See the link below for a breakdown of the parts for your model:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=503694&diagram_id=129669#d129669
Posted on Sep 16, 2010
I have a Kenmore side by side, model # 106.57032601 that I bought 4 years ago. The ice maker suddenly quit working. The refigerator/freezer work fine otherwise and I continue to have water from the...
Is your ice tray filling with water? If not, then I would suspect the water inlet valve (http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-10657032601/0582/0165000/K0607002/00012?blt=06&prst=0&shdMod=10657032601 - Item 10)
If it does fill with water, but does not eject the ice cubes to start a new cycle, I would suspect the ice maker motor(Item 37). BUT if it is the motor, that part costs $91.22 and you can replace the entire ice maker (Item 100) for $157.95
Jul 10, 2011 | Kenmore Refrigerators
Water in bottom try more than can be evaporated by fan pan overflowing Model Gs6nbexrs00 Serial ss2448296 4 1/2 years old
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check the door seals...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Kenmore refrigerator side-by-side with water/ice in door. Model number 363.9534783 serial number L431 12755. It is now intermitantly leaking water on the floor. A couple of days could go by with...
1. A door open partially will cause a frost build-up then thaw and run down to the floor. Check all doors for proper closure and educate other users.
2. An issue with an unhappy animal is quite common
3. Door switch intermittently causing a light to stay on ora fan to not run
4 Ice build up around ice door chute .
5. Water dripping into ice tray and overflowing. Replace water valve.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Oct 18, 2017 | Kenmore 57029 Side by Side Refrigerator
Ice maker
filter its on the kick plate @ the bottom of the freezer door,push the side button and the filter unlocks
Jun 17, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Not making ice
Hi: Change or just remove the water filter first. As your water dispensing slowed that is a clue. If the water filter is that clogged it will cause a problem with the ice maker. Plus the water you drink is not filtered anymore. City water is being run through 2 years of crud. If you don't replace it just remove it. I hope this helps, Jeff
Jun 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
Apr 14, 2009 | Kenmore Refrigerators
Water Dispenser with mind of it's own
one test is too turn off your ice maker and it will stop...you have a bad diode on the water line and are getting line feed from the ice maker...
to fix it you will need a new diode
#5303918287 DIODE KIT
#5304418384 DIODE KIT
the parts store will get you the correct one with a model and serial number of the refrigerator
let me know if it helps
Nov 03, 2008 | Frigidaire Refrigerators
Refrigerators Logo
571 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
