Question about Sport & Outdoor - Others
Have a 2007 yamaha AR230. the check engine light blinks 6 times and shuts off. waits 3 seconds and then blinks 6 times and shuts off. it will continue to do this while motor is running. What does it mean?
circuitcity
  • 137 Answers
SOURCE: power button
This is a very simply fix. Your problem is you have a bad thermal fuse. This fuse can be found in the Lamp housing. You need to take the back off in order to fix this problem. Replacing the thermal is not hard, but you need to be a little handy. Part number 1-910-023-93 Average cost $9.00
Posted on Dec 07, 2007
SOURCE: Blinking status light
Replacing the lamp with an old one was helpful for me. Good news: the projector itself not faulty. Bad news: I have two projectors with the same issue at the same time (the lamps were replaced also at the same time) after only 400 hours of running.
Posted on Jun 23, 2008
tipstir
  • 67 Answers
SOURCE: Viking Dishwasher won't start. All the lights continue blinking and it sounds as if a motor is continually running.
What had changed since you last use it? Prior day? Also when last did you clean out the filters for it?
1. Drain Pump
2. Block Drain (blocked or kinked)
3. Valve Leakage
The electronic display has detected a sensor fault on the unit for the flashing you see. Check the filters and drain pump. Make sure nothing is clog also the line where the hot water goes to it. I know you said you have it under protection for 5 years and that's up right so some parts might need to be replace. If you go down to your main breaker for the unit you can trip it off and on and see if that clears it up but I you might have a serious problem with it.
Now you got 2 options.
1. Call up Viking and get an estimate of how much it will cost to repair the damage.
2. If the cost is greater than buying a brand new one then, better off getting another one then. If not then get it repaired.
Posted on Jul 31, 2008
mecanica03
  • 905 Answers
SOURCE: My 2007 Toyota Tundra 4.7l shows VSC OFF lights
check air filter for dirty , how many miles or kms have your car? , maybe need to replace spark plugs, try to reset the ecu for a momentany malfunction, remove the negative battery terminal few minutes and reconnect,start engine and drive, check if lights goes off , please write me
Posted on Jul 05, 2009
raygin
  • 322 Answers
SOURCE: My 2005 Jag S-Type 6
You have a fault condition in the the engine management system - get the codes read to indicate where the fault lies ... It is probably just a faulty sensor as this is the most common cause of check engine warnings. The restricted performance condition is meant to protect the engine or components from damage, so don't panic - get the codes read - its probably not as bad as you expect. hope this helps - good luck.
Posted on Apr 28, 2011
My R15 v2 YZF engine light blinks 10 times firsts 5 blinks slow rest very fast bike tends to stop whenever it appears n stop but when the light is on upper the bikes dont stop above 90 km/hr not stop
Yamaha yellow blinking light start Motorcycles Questions ...
www.fixya.com > ... > Tags > yellow blinking light start > Motorcycles
Ad. Question about 1997 YZF 750 R ... oil light blinking on 2004 yamaha r1 oil lightblinks 10 times stops then blinks 10 ... My yamaha r15 v2 I drive to bike after sometimes yellow engine light on aftersometime I light on to yellow engine light of.
Yamaha blinking yellow light Questions & Answers - Fixya
www.fixya.com > Forum > Tags > blinking yellow light
oil light blinking on 2004 yamaha r1 oil light blinks 10 times stops then blinks 10 times ... Question about 2008 YZF-R15 ... My yamaha r15 v2 I drive to bike after sometimes yellow engine light on aftersometime I light on to yellow engine light of.
[Ownership Thread]: Yamaha YZF-R15 - xBhp.com
www.xbhp.com/talkies/.../4854-yamaha-yzf-r15-1951-print.html
Jul 11, 2013 - 4 posts - ‎3 authors
2months back i got this problem while riding the engine goes off, but ... of heavy traffic after transporting it from my home town. then it works fine and all of a sudden i find the bike engine light blinking. it reads '42'. then after showing it to ... the ECU alone wil cost me to 10k. and obviously it is very expensive ...
Yamaha YZF-R15 version 2.0 - xBhp.com
www.xbhp.com/.../20138-yamaha-yzf-r15-version-2-0-a-786-print.html
Nov 26, 2013 - According to me the problem of chain with my bike is because i ... list about the required changes at 10k kms like Fork oil change and ... On switching on the ignition, the engine malfunction light, the orange(?) ... From your description that a longblink coupled with 3-4 short blinks it .... All times are GMT +6.5.
Jan 27, 2016 | Motorcycles
Tip
How to reset ECU,Throttle and Accelerator Position Learning
Hi.
Below the procedure to reset ECU,Throttle and to perform Accelerator Position Learning on Nissan. It works on Titan, Altima, Infinity, pathfinder and other models.
ECU Resetting
While performing the procedures below, ensue that you are respecting the times stated. If the steps are not done within the specified times, the module will not reset. You will need to use a watch or a chronograph while performing the procedures.
Procedure:
1. Ensure that the accelerator pedal is fully released, set ignition switch to the “ON” position, then wait 3 seconds.
2. Follow the steps a and b below, repeat the two steps in sequence quickly for five times within 5 seconds.
a. Push hard the accelerator pedal untill fully depressed.
b. Release the accelerator pedal in full.
3. Wait 7 seconds, then depress the accelerator pedal completely, and hold it for about 10 seconds until the CEL (check engine light) starts blinking.
4. Release the accelerator pedal while the CEL is still blinking.
5. Wait 10 second.
6. Depressthe accelerator pedal in full and hold it for 10 seconds or more.
7. Fully release the accelerator pedal while the CEL light keeps flashing.
8. Turn the ignition switch to “OFF” position and start the vehicle. If procedure has been done correctly, then the light light will turn off.
If the light continues to stay on, repeat the procedure.
Accelerator Pedal Release Position Learning
Procedure
1. Ensure that the accelerator pedal is completely released before starting the procedure.
2. Turn the ignition switch “ON” and wait at least 2 seconds.
3. Turn the ignition switch “OFF”, and wait at least 10 seconds.
4. Turn the ignition switch “ON” and wait 2 seconds.
5. Turn the ignition switch “OFF” and wait 10 seconds.
Throttle Valve Closed Position Learning
Procedure
1. Ensure that accelerator pedal is completely released.
2. Turn ignition switch to the “ON” position.
3. Turn ignition switch to the “OFF” position and wait at least 10 seconds.
Ensure that the throttle valve moves after turning the switch off.
Idle Air Volume Learning (Throttle Position Learning)
Procedure
1. Follow the Accelerator Pedal Released Position Learning described above.
2. Do the Throttle Valve Closed Position Learning also described above.
3. Start the engine, and allow warming up.
4. Turn the ignition on “OFF” positionand wait 10 seconds.
5. Ensure that accelerator pedal is fully released, then turn the ignition switch to “ON” position, and wait 3 seconds.
6. Repeat the steps a and b below five times within 5 seconds in sequence.
b. Release the accelerator pedal until reaching full extension.
8. Wait 7 seconds or more, depress the accelerator pedal completely and hold the pedal down for about 20 seconds until you see that the Check Engine Light stops blinking and starts getting steady..
9. Rrelease completely the accelerator pedal within 3 seconds after the light coming ON.
10. Start engine and let it run at idle for about 20 seconds.
12. Test the engine to ensure the idle speed and ignition timing are set correctly.
Regards.
on Mar 25, 2010 | Nissan Titan Cars & Trucks
Fault light is flashing 3 times when I put down the side stand
2011 Yamaha Cygnus X Fault code - Questions - Fixya
www.fixya.com > ... > Yamaha > Snub Nose > 2011 Yamaha Cygnus X
Get solutions for 2011 Yamaha Cygnus X fault code related issues from top ... ...filight is on and the red check engine light flashes flashes 3 brief times then 5 ...
2011 Yamaha Cygnus X Check engine light - Questions ...
Get solutions for 2011 Yamaha Cygnus X check engine light related issues from ... My engine light will come on and then blink 3 times go off and blink 3 times.
2011 Yamaha Cygnus X Light engine - Questions - Fixya
engine light will come on and then blink 3 times go off and blink 3 times... This is on a 2005 Royal Star Tour Deluxe. Any idea?? How to fix your check engine
Oct 27, 2015 | 2011 Yamaha Cygnus X
YAMAHA 2008 R1 HOW TO TURN OFF CHECK ENGINE LIGHT
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r1-forum.com/forums/104-04-06-r1-mechanical-help/285068-check-engine-light.html
How to reset check engine light
http://www.lethaladrenalinrydaz.com/index.php/service-manuals/finish/3-service-manuals/6-2007-2008-yamaha-r1-service-manual/0
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Oct 14, 2012 | 2007 Yamaha YZF-R1
2004 nissan quest DTC P0507. Can't get IAVL to
My quest 2004 idle below 500, start up then off, have to start couple times when the engine is cold. when i pushed the gas pedal, it smells gas.
Oct 21, 2009 | 2004 Nissan Quest
Stops while driving
this is usually due to a dirty throttle body. just beware if you do try to clean it you will need to preform the idle relearn procedure. this does work, ive done it personally.
A. Accelerator Pedal Release Position Learning Procedure.
1. Make sure that the accelerator pedal is fully released.
2. Turn ignition switch “ON” and wait at least 2 seconds.
3. Turn ignition switch “OFF” wait at least 10 seconds.
4. Turn ignition switch “ON” and wait at least 2 seconds.
5. Turn ignition switch “OFF” wait at least 10 seconds (how would you know if you get it right?)
B. Throttle Valve Closed Position Learning
1. Make sure that accelerator pedal is fully released.
2. Turn ignition switch is “ON”.
3. Turn ignition switch is “OFF” wait at least 10 seconds.
Make sure that the throttle valve moves during above 10 seconds by confirming the operating sound (i never get this right because i never heard anything)
C. Idle Air Volume Learning (Throttle Position Learning)
It's best to time with a watch/clock.
1. Perform “Accelerator Pedal Released Position Learning”.
2. Perform “Throttle Valve Closed Position Learning”.
3. Start engine and warm it up to normal operating temperature.
4. Turn ignition switch “OFF” and wait at least 10 seconds.
5. Conform that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
6. Repeat the following (steps 7a, 7b) procedures quickly five times within 5 seconds.
7a. Fully depress the accelerator pedal (HARD)
7b. Fully release the accelerator pedal.
8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the Check Engine Light (CEL) stops
blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the CEL is ON.
10. Start engine and let it idle.
11 Wait 20 seconds
12Rev up the engine two or three times and make sure the idle speed and ignition timing are within the specifications. (this is fine because SES light lets you know if you did it right the way it blinks)
Oct 25, 2008 | 2005 Infiniti G35
Reset check engine light
First of all, you should'nt do this unless you know what the problem is.. or what tripped it. I had this problem when my husband and I were replacing a head unit and disconnected the old head unit, a/c and other stuff then turn the car on. This made the light flash. The first time we took it in and got charged $50 to reset it. The second time we did this procedure and it worked.
ECU Resetting Procedures
Timing is extremely critical. If it is NOT DONE within the specify time, the ECU will not reset and the Check Engine Light (CEL) will continue to remain ON.
A stop watch or an analog clock with a second’s needle will be useful.
Reset Check Engine Light Procedures
1. Confirm that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
2. Repeat the following steps (2a and 2b) procedures quickly five times within 5 seconds.
2a. Fully depress the accelerator pedal (HARD).
2b. Fully release the accelerator pedal.
3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the CEL starts blinking.
4. Fully release the accelerator pedal (while the CEL is still blinking)
5. Wait about 10 seconds.
6. Fully depress the accelerator pedal and keep it for more than 10 seconds.
7. Fully release the accelerator pedal (The CEL light will continue to blink).
8. Turn ignition switch to “OFF” position and now you can start the car. The CEL light should be gone.
If the CEL light continues to remain ON, repeat the above steps. Timing is EXTREMELY critical to resetting the ECU.
-Christine
May 15, 2008 | 2007 Nissan Murano SE
Sport & Outdoor - Others Logo
109 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
