Question about Tomtom GO 300 GPS Receiver
Tomtom one Used the device yesterday. To-day it will not turn on. The green light is on. Tried to reset but still does not work. Can you help.
  • grace blanco May 21, 2008
    the ligth power is green when turn on but the screen is same as the tomtom is off.
  • westhamal May 25, 2008
    green light is on, but it wont switch on. green light is only on whn plugged into mains. there is no green light when not plugged into mains.
    i accidentaly tried charging it with 12v and not 5v. slight smell of burning now. have i killed it?
    Novelist:
  • 158 Answers
Resetting only needs one quick push of the reset button. repeated pressing or too much force will damage the button. You can feel the reset switch operate as it clicks ( tactile ). All the reset switch does is momenteraly disconnect the battery. This resets the proccessor. You can also do a harder re-set by holding the on button down whilst also pressing the reset button. This should disconnect the battery AND discharge any internal capacitors , thus ensuring a complete reset of the processor. If resetting doesnt work , then its likely 2 IC's are blown inside the TomTom , U24 and U25 , this fault being caused by a faulty charger unit ( cigarette charges are known to go faulty giving too higher voltage out ) . Unfortunatly, U24 and U25 cannot be replaced by an ordinary repair service as it needs special technique and special tools. The green light ON , only proves that power is getting to the unit , it does NOT prove the battery is being charged. .... Good luck
Posted on Sep 15, 2008
  • 515 Answers
After a reset, hold down the power on button for at least 15 sec...
Posted on May 18, 2008
Tomtom 510 - packed up
try re setting the TomTom, reset button is founded on the bottom underneath where the docking mount connect, hold down for 15 seconds, then press the little button on the top on the right side while turning on. worked for me
Jun 06, 2010 | Tomtom GO 510 GPS Receiver
My Tom Tom 510 will not turn on at all. I plug in the power supply and the green light comes on. I used it yesterday and this morning, and all was fine, tried using it 1 hour ago to travel home and...
try to reset
The Reset hole is hard to find, you need to first remove it from the mount, turn it upside down, and within the mounting base area of GO you will see two interface slots (currently only one is being used) and towards the front of the unit on the base you will see a little hole marked reset. This is just like soft resetting a Palm or Pocket PC, it requires something small like a paperclip, and nothing was supplied with GO to enable you to easily reset the device.
Nov 15, 2009 | Tomtom GO 510 GPS Receiver
My Tomtom XL won't turn on. No reset button apparent
The reset button is on the bottom of your device. On my older model XL it is just above the sd card slot. If you have the newer model XL 330 then you have to hold down the on/off switch for 20 seconds to do a reboot. If you have not used it in a while let it charge for 30 monutes before doing a reset.
Hope this helps
May 12, 2009 | Tomtom GO 720 GPS Receiver
Tomtom 510 will not activate. tried it with connection to electrical outlet and without being plugged into the outlet. It quit working after it was plugged into an automobile cigarette lighter plug, then...
After posting my problem, I did some more browsing and came across this on the amazon webiste:
31 of 32 people found the following review helpful: stars-4-0._v45457020_.gif Cure for not able turn on the Go 510, 16 Jun 2007 By Sirius (Essex) - See all my reviewsI like the tomtom so far the only niggle was it would not turn on once.
No troubleshooting on instructions, found cure on internet,reset button
underside. With the tomtom turned over and the card slot on top right hand
side there is a small rubber foot at the half moon shaped enterance, up at about the 10 o'clock position from the foot,but before the green circuit
board there is a small half round cut out with a hole under you need to press in this hole for a few seconds with a paper clip to reset. I wonder how many people have sent their tomtoms back that would not turn on.
Tried it & worked a treat!!! Newcastle here we come again ...
Apr 07, 2009 | Tomtom GO 510 GPS Receiver
Doesn' t turn on
1. Connect the TomTom to the USB for power (green light should be on).
2. Hit the reset button on the bottom of the device - you should feel it depress slightly.
3. Press firmly and hold the power button and count to 10.
5. Try this a couple of times if it doesn't work the first time.
Even if your battery is ****, the power connection has a pass-through, so you can still use the device as long as its connected to the charger.
Dec 19, 2008 | Tomtom GO 720 GPS Receiver
Tomtom 910 sat nav.
Complain to Tom Tom ,you may have a lemon,look for law suit soon
Mar 25, 2008 | Tomtom GO 910 GPS Receiver
Tomtom 910.
Mar 23, 2008 | Tomtom GO 910 GPS Receiver
GPS Won't Turn On
www.batteryship.com
look up tomtom 510 - or whatever model you have
Order the battery..........comes with manual and tools to fix it
only 20.95
it works
cheaper than sending it in!!!!!!
These are genuine replacement parts!!
Laura
Jan 30, 2008 | Tomtom GO 510 GPS Receiver
Frozen tomtom
Is there a reset button? See this from PocketGPSworld.com: Reset hole The Reset hole is hard to find, you need to first remove it from the mount, turn it upside down, and within the mounting base area of GO you will see two interface slots (currently only one is being used) and towards the front of the unit on the base you will see a little hole marked reset. This is just like soft resetting a Palm or Pocket PC, it requires something small like a paperclip, and nothing was supplied with GO to enable you to easily reset the device.
Feb 25, 2007 | Tomtom GO 510 GPS Receiver
Tomtom GO 300 GPS Receiver Logo
258 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
