Question about Ovens
I have a viking gas range that won't get hot enough. After reading all the online advice, based on my problem, I am trying to replace the oven ignitors. However, I can't figure out how to get them out. They are screwed in and in order to get to that screw I have to take the whole base of the oven out it seems, about 10 screws. From what I have read, I should only need to take out 2 screws. There must be an easier way to get access it would seem. Can you help?
  • crista_19 Sep 16, 2010
    It's a Viking VGIC365-4G. I can see the ignitors, and yes there are only 2 screws holding them in. The trouble is, they are in a tight spot and there is not room to get even a stubby screwdriver in there to unscrew them. So do I need to remove the 20 screws holding the base, and remove the base to get to those 2 screws holding the ignitor in?
  • 11,896 Answers
First unplug the stove. Remove the ovens racks & oven bottom, also the flame spreader. The spreader is the metal plate attached to the top of the burner. It will have a wing nut securing it to the burner. This is close to what you will see - picture.
Loosen or remove the screws securing the glow igniter to the burner. Follow the two wires attached to the igniter. At the end farthest from the igniter will be a wire pull apart quick disconnect. Disconnect the glow coil at that point.
Install the new coil exactly as you found the existing coil. Replace each part in reverse order. Plug in the stove and turn it on. The oven burner now should work.
Be advise that some new replacement igniters do not come with quick disconnect ends. In this case, it's okay to cut off the quick disconnect from the old igniter and attach it to the new igniter.
Simple clip off the wires several inches above the disconnect on the old igniter, attach to the wires of the new igniter and wire nut the two ends together. Porcelain wire nuts are best - picture.
Porcelain wire nuts parts help - click here.
Repeat the process to attach the other set of wires and wire nut them together. There is no positive nor negative {polarity} to be concerned with.
Glow igniters are fragile & they break easily. Handle and install the new igniter carefully. Glow igniters are a non returnable and non refundable electric component.I have a viking gas - 9732604.jpeg
Posted on Sep 16, 2010
  • 944 Answers
Actualy the igniter only has two screws.To remove it you just need two screws from the oven.But to access it,you have to remove the whole base.Basically the Igniter is places at backside of the base.Please specify the model so that i could be more specific on the no of screws to be removed.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Where to purchase
http://www.consumerreports.org/cro/kitchen-ranges.htm
Freestanding electric smoothtop ranges are the big sellers, but you have more choices than ever. Our Ratings include smoothtop ranges, of course, but you'll also find induction and coil-top ranges in the electric category, along with gas, dual-fuel (gas cooktop, electric oven) and pro-style ranges. Choose a single oven or double-oven range, freestanding or slide-in. We test all of these. Consumer Reports offers you buying advice that you can trust. We provide unbiased Ratings and range reviews to help you choose the best range for your needs and budget, and use our buying guide to learn more about range types and features that matter most.
Ratings & recommended kitchen ranges
Electric smoothtop ranges (62)
Our Recommended ranges can do it all and, based on our survey of thousands of readers, do not have brand reliability issues. The Recommended ranges will bring pasta water to a fast boil, hold a big batch of spaghetti sauce or chili at a low simmer, a... More
Recommended electric smoothtop ranges
Electric smoothtop range Ratings
Electric induction ranges (9)
Recommended electric induction ranges
Electric induction range Ratings
Electric coil ranges (10)
Recommended electric coil ranges
Electric coil range Ratings
Gas ranges (43)
Do you love cooking with gas? Our Recommended gas and dual-fuel ranges (which pair a gas cooktop and electric oven) are top scoring and, based on our survey of thousands of readers, do not have brand reliability issues. They have large cooktop burner... More
Recommended gas ranges
Gas range Ratings
Pro-style ranges (34)
Pro-style ranges are stylish, stunning, and make a statement. But despite their high price, they aren't the best ranges we've tested. So before you swipe your credit card check our Ratings. You'll see the top brands, including Viking, Wolf, Thermador... More
Recommended pro-style ranges
Pro-style range Ratings
Jul 19, 2015 | Ovens
There is no gas flow to one of the ovens igniters
Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. I offer free advice bcuz God is so good!
GAS OVENS
The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Jan 28, 2014 | Viking 30" Professional Select Built-in...
Viking professional glasstop gasket replacement
If you have a VESC model you have to order a new glass top. They come glass in frame. My advice as a Viking Certified Servicer is to contact a local servicer to repair your range.
Oct 01, 2013 | Viking Ovens
Hope you can help i have a frigidare 30 in stove 7 years old oven does not go on glow coil is working help thanks andrew
the "glow coil" /ignitor is weak and needs to be replaced , to get a bit techinal for a minute since the ignitor comes on at all that eliminates all other possibilities and the ignitor must draw between 3.2-3.6 amps to open the gas valve it indeed is coming on yet not drawing enough amps(getting hot enough) to open the gas valve.I base my oponion on 30 years plus as a appliance repair technician
Jul 19, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
My Viking oven will not lite, the igniter glows, but it will not lite. I have to turn on the 4 stove top burners and then it will lite. Also, when the oven reaches temperature and the therastat shuts it...
That sounds like you have too high of gas pressure which keeps the oven gas valve from opening...turning on the burners lowers the gas pressure enough to allow the gas valve to open. this is a saftey feature on many gas valves.
To stop that you will need to install a gas pressure regulator which will hold back the gas pressure so the valve can open.
Here is a tip that I wrote about regulators and them failing on the low side, but it will give you and idea what I am talking about and what you need to install in the line to your range.
http://www.fixya.com/support/r5849793-propane_lp_or_natural_gas_regulator
heatman101
Apr 22, 2011 | Viking 27" Professional Select Built-in...
I just had my 30"
Hello michelle. go to this viking link for the free downloads
http://www.vikingrange.com/consumer/library/documentation.jsp?id=cat40032
Joe
Thanks for choosing Fixya!
Mar 12, 2011 | Viking Ovens
I have an older whirlpool free-standing gas range and oven and the broiler works but the bake option does not, the oven doesn't get hot, any suggestions?
you may need to replace the bake ignitor. if it is glowing orange and not white, it isn't hot enough to light the bake. hope this helps
Oct 15, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
VDGO viking gas oven upper won't heat
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
Aug 16, 2009 | Ovens
Viking professional gas range isn't heating properly
The ignitor must glow brightly, if it is dim it is probably too weak to open the bi-metal safety valve. Take a LOOK
Jul 17, 2009 | Ovens
Oven takes a long time to heat up
your ignitor could be going out. the ignitor has to get hot enough in order for the gas to turn on and heat your oven. if your ignitor is going out, sometimes it doesn't glow hot enough for the gas to turn on, or it could be that is takes longer than normal to get hot enough to turn the gas on. I would replace the ignitor and that should solve the problem. Joe
Nov 15, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
50 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
