Question about Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher
Dishes are not rinsing properly they come out spoted and full of streaks.
  • Bosch Master
  • 43,501 Answers
Here is a tip that will help you with how to clean that dishwasher up and get it smelling good again...
Dishwasher Maintenance
heatman101
Posted on Sep 18, 2010
My Maytag quiet series 200 is not cleaning and despite many attempts it is also leaving terrible residue on dishes.
I found this on ehow I believe it will help. How to Troubleshoot Dishwasher Residue By Dale Yalanovsky eHow Contributor
5Found This HelpfulGeorge Doyle/Stockbyte/Getty images
Dishwater residue is a fairly common occurrence, and several things can cause it. Even the newest dishwashers may leave residue, and it might have nothing to do with the actual dishwasher function itself. However, there are things you can do to prevent, limit or completely remove dishwasher residue during every washing cycle.
Other People Are Reading
  1. Detergent Residue
    • Modern phosphate-free detergents are the main culprits when it comes to detergent residue. After every wash, many leave a slight whitish residue behind. After several washings, the residue becomes caked on and leaves a noticeable white tint to your dishes. Some dishwasher detergent brands are better than others, and either minimize residue or do not leave any. Once residue is present, however, the only way to remove it is by hand scrubbing or scraping.
    Hard-Water Residue
    • Hard-water residue comes from non-softened water from your hot water tank. Non-softened water leaves a white tint on dishes, but no amount of scrubbing will remove it. Only by wiping a small patch of the dish with vinegar or lemon juice will you be able to ascertain whether the white residue left is hard water or detergent. The slight acidic action of the vinegar or lemon juice removes hard-water stains, but they have no effect on detergent residue.
    Greasy Residue
    • If the dishes feel greasy when they come out of the dishwasher freshly washed, you are dealing with a greasy residue. There are two main reasons for this: either the detergent is not an effective grease remover, or the hot water inside of the dishwasher, either from the hot water tank or the dishwasher's heating elements, is not hot enough. Boosting the hot water temperature on the water tank may solve the problem, and a second wash cycle may be needed for the dishes. A preventive measure of running the dishwasher empty with a full load of detergent also removes the residue inside of the dishwasher.
    Streaking and Spotting Residue
    • If you have spotting or streaking on your dishes, that may be a sign you need a rinse agent. Many modern dishwashers recommend a rinse agent to prevent spotting or streaking, and without one, your dishes will never be crystal clear or streak-free. The next time you do a dishwasher load, add a rinse agent. If the dishes come out spot- and streak-free, the problem is solved.
Read more : http://www.ehow.com/info_12285021_troubleshoot-dishwasher-residue.html
May 19, 2015 | Maytag Dishwashers
Dishes are coming out streaked and not properly cleaned. I have added rinse aid, salt and even descaler.
De-scaler wont wash your dishes. The simplest cause of dishes coming out unclean is over-loading, bad stacking (spray arms blocked), or using too short a programme for heavily soiled dishes.
If it's just streaky (not food remnants), you may have the rinse-aid set too low. Open the flap where you add rinse-aid and you will see a know with an arrow shaped grip. There are 5 positions for the knob marked 1 to 5. Try a higher setting (1 is low) but don't go too high as this will cause other problems. If it's on 1, try 3 and if it's on 2 or 3, try 4 or 5. You may have to adjust this a couple of times until you get satisfactory results.
Howver, If you're referring to a white powdery residue on dishes and glasses, that's an entirely different answer . . .
Oct 11, 2010 | Bosch 24 in. SGS43C12 Classixx...
The dishwasher doesnot dry anything.
  • Check the rinse aid indicator beside the rinse aid dispenser cap. If the indicator window is clear, refill the dispenser. The dishwasher will retain moisture and the heat dry option will not perform properly without rinse aid. Turn the dispenser cap clockwise and lift it up to remove it. Pour rinse aid into the dispenser until the indicator appears full. Place the dispenser cap over the dispenser and turn it counterclockwise to tighten it.
  • Load the dishes properly so that all dishes can drain after the rinse cycle. Do not overload the dishwasher. Towel-dry plastic dishes because they will not dry completely during the dry cycle.
  • Select the heated dry option on the dishwasher. The air-dry and energy-saving dry options will not perform as well as the heated dry.
  • Oct 10, 2010 | Whirlpool Dishwashers
    Filters clean, arms unblocked, salt and rinse-aid ...
    Yes! you are already having the answer. check your water inlet flow. Clean the strainer at the machine water hose connecting end.
    Check the drain filter also. Refer user guide for instructions on cleaning.
    May 19, 2010 | Dishwashers
    Dishes not clean?
    Check all the water jet orfices in the moving arm. Try cleaning without loading the top rack.
    If cleans well, mostly the upper rack dishes not arranged properly.
    I hope you are using the main wash detergents. Rinse aid is just to remove the stains after the main wash rinse.
    Apr 01, 2010 | Dishwashers
    Some of the dishes come out with a white stain on
    Look to see if you have an adjustment for the rinse agent dispenser. You would need to decrease the amount of rinse agent which is being dispensed.
    Oct 12, 2009 | Dishwashers
    Dishes come out with white stuff all over them
    Dishwashing detergents have recently been re formulated and sulfates were removed. This has caused the dishes to no rinse properly in areas with hard water. The solution is too add a rinse agent containing citric acid. I got some today from our local appliance store and the dishes came out perfect!
    Jul 15, 2008 | GE Nautilus 24" Built-in Dishwasher
    Indesit D63 dishwasher dishes not getting clean
    Dishwasher seems to cycle through but dishes are still dirty, like there is no water being sprayed?
    Jan 23, 2008 | Dishwashers
    Rinse aid used very fast and dishes not drying
    Look for a blue or green streak on the door panel when you upen it to load the dishes. Does the washer sound different during the wash than it used to? If so your dispenser is leaking. This will also cause the water to suds up and not wash as well as it should. Start the washer with no detergent or dishes and let it run for 5 minutes, then open the door and see if there are a lot of suds in the water. Post back to let me know what you find.
    Oct 20, 2007 | Whirlpool 24 in. ADP5966 Free-standing...
    Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher Logo
    106 people viewed this question
    Top Bosch Dishwashers Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
