Question about Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
Refridgerator keeps popping the breaker- Removed front vent and cleaned underneath as far as I could reach but seems to still be doing it. How can I reach the back grates underneath? Is there something else I can do?
  • Kenmore Master
  • 43,501 Answers
The compressor is not starting and is probably bad...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 17, 2010
Drse663b
sounds like the automatic defrost system failed and if you removed the evap cover it would be blocked with frost.
Nov 29, 2013 | Amana Refrigerators
My Amana ABC2037DPS Refridgertor is not keeping items cool. Last time the serviceman came out he went into the back and "RESET" the unit. Does anyone know how to RESET the Refridgerator?
Most likely the coils under the refrigerator need cleaning. Unplug the refrigerator and remove the front, vented cover below the door. With a vacuum cleaner and crevice tool clean the coils off. It may also help the clean off the door gasket and apply a very thin coat of Vaseline. (Don't forget to clean the refrigerator edge that makes contact with the gasket.)
Sep 20, 2013 | Amana Easy Reach AFD2535DE Bottom Freezer...
My amana fridge keeps blowing the GFI circuit
change the GFI circuit to 20 amp
Mar 30, 2017 | Refrigerators
How do I remove the coils underneath my fridge so that I can clean them? I can vacuum out the front coils but they continue further towards the back of the fridge and my vacuum doesn't reach them. Is...
You can not disconnect the coils from a fridge. It is a closed system and if they were removed it would vent your coolant into the atmosphere. If REALLY need to clean them have someone help you slide the fridge away from the wall. Oh and also make sure that you keep the fridge upright.
May 02, 2011 | Whirlpool GD5SHAX Side by Side...
Went to warm up a food item and after 3 seconds the microwave shut off like the circuit breaker tripped. time face went blank, light inside does not light up and stove top lights do not light. circuit...
You have a fuse behind the screen panel. You have screws inside the microwave holding the panel. you have 1-2 at the bottom. You may also have to remove the vent. It has 2-3 screws which will be inside the vent. These can be removed from the front. Once these are removed the panel will pop off and you will see the fuse The fuse can be bought at a radio shack. BE SURE TO UNPLUG THE MICROWAVE! Good Luck
Dec 04, 2010 | GE JVM1631 Microwave Oven
I NEED TO REMOVE DASHBOARD FROM AUDI A4 2001
What happened?? Dash boards don't like to be removed. You will need a book, some of the bolts are hidden behind vents and other stuff in the dash, the steering will have to come off. The switches, for the most should pull out the front, be disconnected, and the wire stuffed back in, the ac controls should pop off, remove the plastic front, bolts underneath?, leave the vent controls where they lie, take notes, take fotos, get help, this is a 2 day job!!
Feb 13, 2010 | 2001 Audi A4
Samsung AC keeps popping breaker
use larger extention cord with thicker wiring,as short as possiable!
Jun 25, 2009 | Heating & Cooling
Right turn signal flashes fast. Front bulb appears to be burned
There are 2 bolts on the top corners of the bulb lens that needs to be removed then the lens pops right out and you can change the bulb.
Apr 06, 2009 | 2006 Pontiac Montana
Kenmore 64942300 Electric Dryer runs, no heat
This may seem too simple of an answer based on your extensive troubleshooting thus far, but the most common reason for cold air running of any electric dryer is a broken heater coil. This is simply a coil of wire that is heated to warm the air in the fan duct. These often overheat and break if the vent duct is blocked, too long, or has odd bends that can restrict flow. Recommend replacing heater coil and use smooth wall vent pipe. Avoid coil type flexible duct.
Jul 03, 2017 | Kenmore 64942 Electric Dryer
Can't remove a1985 GE Microwave Mode3l jvm61001 fro0m the wall.
this microwave oven slides out of its casing. here's how: first shut the power to the unit by the breaker from your main panel. on the mw oven remove the underneath rightside vent filter. unplug the large white connector that you see in through where the filter was . Dont break it. its locked and keywayed. next remove the top front plastic horizontal louvered front vent by one phillips screw on each end of the vent left and right. then remove the next two phillips screws you see under where the vent screws were. then remove the 3 shoulder screws underneath the front edge of the case bottom then slide that piece of **** oven out of its casing. I'm sure you will know what to do next. Good luck!!
Oct 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
