Question about Nokia 6111 Cellular Phone
Camera's flash light stays on
I have tried resetting the phone to factory default, removed the battery and attempted to turn the flash off in the camera's options menu. What else can I do? The light just stays on and of course runs the battery down.
Thanks (",)
I have the same problem :(
Posted on May 19, 2008
Thanks for the info. You mentioned factory reset. How does that work?
You should find the reset to factory default option within the camera's menu options.
Try this too: Remove memory card before resetting.
Turn off the camera, and leave the camera without inserting the battery & memory card overnight allowing it to reset.
Dec 10, 2014 | Canon Powershot A1200 12. Megapixel...
How TO RESET flashgun ex 11m7unk
There is no "official" reset option for a 430EX flash. Removing the batteries, discharging any remaining flash and leaving it overnight should clear any issues. If you continue having issues try the flash on another camera to be sure it's not the camera settings you're having an issue with and not the flash. If it is the camera, resetting it to factory defaults through the menu might help.
Aug 31, 2014 | Canon Speedlite 430EX TTL Flash
Digimax A503 going into AUTO mode and running down BRAND NEW BATTERIES before they can be used
Attempt to restore camera electronics to factory defaults. If you cannot do so, contact Samsung tech support for assistance/input. If they cannot help they you have a dilemma/ replace or repair? But if not an expensive camera the choice is clear.
Sep 08, 2017 | Samsung Digimax A503 Digital Camera
Flash Light will not turnoff
Try a hard reset to factory defaults. Then reinstall apps until you find the one that turns on the light.
Jun 17, 2017 | Nokia E75 Cell Phone
My 580ex ii cannot change back to Auto zoom its stuck at 14mm
If removing the batteries overnight doesn't allow it to reset, try mounting the flash on your camera, turn both on and reset your camera to factory default settings through your camera menu settings.
Nov 01, 2012 | Canon Cameras
My LG kf750 secret wont start up, wont turn on. It
You could try to hard reset your device, in an attempt to sort your problems out. Be warned that a hard reset will set everything on your phone to their factory defaults, for what you'll loose all the programs you have installed, as well as your personal data. Anyway, to perform a hard reset, turn your phone off completely, by pressing and holding the power button, and, then, answering to the power off prompt. Then, press and hold the Volume Down, the Call, and the Power buttons, until the LED (at the side of the camera) flashes. Release the buttons. That LED should flash in green/red/blue now. When your device powers up, it should be completely cleared.
Hope it works for you, since this is completely theoretical. I have never done it myself.
Regards,
Carlos
May 15, 2010 | LG Secret ? KF750 Cellular Phone
Itsays turn power off and on again and shutter comes out and back in about 3 or 4 times then stays shut
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks,
KenSolutions
FixYa
Aug 01, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Camera light stays on samsung g600. tried everything, settings, left battery out. helpppp
I recently had this problem too. It started when i first tried the flash settings on the camera. I woke up the next day, turned my phone on and the light wouldn't turn off.
I discovered that by cycling through each flash option (always on, auto and always off) and taking a photo on each setting would sometimes turn the light off for a few moments before the phone crashed and had to be restarted.
Whilst showing this to a friend last night somehow the light went off and the phone didn't freeze (this might be because i had reset the phone to it's factory settings earlier in the day). The light is now off permanently, although i'm hesitant to use the flash again for fear of causing the whole problem again!
Mar 27, 2009 | Cell Phones
HELP 350d still not turning on/screen not working
Hmmm... doesn't sound too good does it? Have you tried another CF card? I know you said it doesn't work even without a card but...
Also one last thing to try is to tkae out both batteries, the main one and the slim watch style backup battery that sits right next to the main one under the cover labelled CR2016. Leave them both out for an hour and see what happens. NOTE this will probably reset your camera to factory defaults and may reset the photo numbering counter back to zero. Worth a try?
Feb 10, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Problem with the Flash Light of Nikon COOLPIX L12 Digital Camera
I know some of the common things for the digital camera. I want you to try these.
-------->If the built-in flash does not function, then the camera may be set to Auto and will only flash when taking pictures in poorly illuminated environments.
-------->Set the camera to the Forced flash setting so it will flash regardless of the surrounding brightness.
IMPORTANT: If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
* When shooting MPEG movies
* When set to the Twilight mode
* If an external flash is connected
The information above should resolve your issue. However, if the issue still persists, you can try resetting the camera to factory specifications.
Some cameras have a RESET button built into them or a menu option to reset the camera to the default settings.
Refer to the instruction manual supplied with your camera for specific information regarding the availability of a RESET button or menu option to reset the default settings. Otherwise, continue with the manual reset procedure below.
1. Turn off the camera.
2. Ensure the camera is not connected to an AC power adapter.
3. Remove the battery from the camera for 15 seconds.
4. Reinsert the battery.
5. Turn on the camera.
If all the above fails you, then i doubt that Impact damage would have caused the flash not to work.
But i know you are not going to like this solution. No other way , you have to contact Nikon service centre for repair.
i hope this helps to fix your problem.
Thanx for using fixya.
Cheers.
Sep 27, 2008 | Nikon COOLPIX L12 Digital Camera
Nokia 6111 Cellular Phone Logo
121 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
