Question about Sony KP-61S75 TV
I am looking for the casters for this TV I only have 2 and it looks like I need 4 more. Anyone know where I can find them.
    Genius:
  • 1,044 Answers
Do any of the followingPlease contact the retailer from whom you purchased the TV. He should be able to guide you OR Go to any SONY dealer and ask him to help you out OR Go to SONY web site, support section and find out if casters are available as accessories.
Posted on Sep 16, 2010
  • bill9 Sep 16, 2010
    I found it at sears parts center was the only place. Tried all others above.
  • Adarsh Saroj Sep 16, 2010
    Happy to know that you have been able to find the casters. Actually Sony should keep and provide when they are giving it out with new equipment OR have they given the responsibility to the retailer
I can not get the caster on the left side to adjust to specs. has new upper control arm and +/- 2 degree adjusterts and caster will not go below +5.5.
There has to be something bent. Lower control arm look oK? Any sign of fame damage? Spindle look ok? Caster is generally not a tire wear factor. However, the vehicle will pull to the side with most caster and least camber.
Jan 20, 2016 | 2004 Ford Explorer Sport Trac
Please help me as I purchased a Rubbermaid Home & Office Cart model 4401 and need to know which are the correct caster wheels for it.Is it the 5 in. 2 rigid and the 2 swivel with the 4 holes or is it...
I see the description says, "500-lb. capacity model has ... 5in dia. casters for extra stability. .... Four nonmarking casters two swivel."
As to screw size, I can't estimate without seeing it, so I would suggest going to a place that sells it.
But you could also ask Rubbermaid:
"For replacement parts, please contact Rubbermaid Consumer Service by calling 1-888-895-2110 Monday through Friday, 8:30 am to 5:00 pm ET or by email using our contact form."
http://www.rubbermaid.com/supportCenter/Pages/ReplacementParts.aspx
Mar 12, 2011 | Garden
Where can i get a set of wheels for my five gallon brute vaccuum?
http://www.shopvac.com/shopvac-accessories/Products/420-63-96.aspx
emailthispage.gif printthispage.gif 1" Dual Wheel Caster (Set of 4 6774200 casters with retainers) Catalog No. 420-63-96
Four (4) casters. Set of 4 Replacement Caster Wheels with retainers. This item is the replacement for the plastic, non-hooded casters shown. These casters you will receive are an upgraded dual hooded caster that are a perfect replacement but offer superior performance.
Four (4) casters. Discontinued. Order this item and we will send you an upgraded, superior dual hooded set of casters. A = 1-12/16" B = 1/4" C = 1-9/16" D = 3-7/16"
You can also look at your local Lowe's who sometimes carry a generic wheel.
Mar 07, 2011 | Shop Vac Brute 5 Gallon Bagged Canister...
Need 2 casters
Is the model number FMP330RGB as listed at the very top? That number does not cross.
There are the parts listed as wheels / caster for Frigidaire:
http://www.repairclinic.com/Frigidaire-Dishwasher-Parts?s=b2a9c252
If you need more assistance just respond here with the complete make and model number and we will help you.
Thanks for using FixYa.
Kelly
May 12, 2010 | Frigidaire FMP330RGB Free-Standing...
Need replacement caster wheel unit.
I found them here:
http://pelonis.com/parts.htm
Feb 20, 2010 | Pelonis WM-HO202C Oil Filled Radiator...
Aspen 4 in 1 bed casters
Okay, this is how I solved the problem.  There is a small "wrench"-looking thing that comes with the crib and the trundle drawer.  You have to take the wrench and put it around the rod between the wheel and the leg cover on the crib (where you inserted the caster).  You have to pry between the wheel and the leg cover and it pops off.
Three of mine came right off, the fourth one took some "mmmmph" to it (and about 3 minutes -- a major pain in the booty).
Hope this works for you.
Jan 24, 2009 | Simplicity for Children Aspen 4-in-1...
Changing the dual axle on an Invacare recliner to lower seat
You will need to remove the rear tires and front casters. If you look at the front caster fork there should be some extra holes where you can re-position the caster wheel. Likewise on the hole where the rear tires mounts there should be a hole above it where you can re-mount the tire. So just move the caster and wheel up to the next hole. If there are no holes to move up to then you cant lower the chair. The only other options would be to install a drop seat which you`ll have to purchase from a dealer or install smaller wheels and casters. So, for instance,say you have 8" casters and 24" wheels you would then install 6" casters and 22" wheels. Good Luck and let me know how it turns out.
Jan 16, 2009 | Invacare Lightweight Tracer SX5 Wheelchair...
Settings
Just one question,, 99 A3 or A4 chassis? An A4 chassis is not adjustable per say. The only adjustement to the camber is to shift the subframe unit left or right to make the 2 sides more equal possible. By shifting the unit after slacking the 4 bolts holding it to the chassis one side will become more negative and the other more positive as the 2 move together. There is a little adjustement in the ball joints but usually will make more problems to the caster when touched. By shifted the unit forwards and back you'll play with the caster a little too but not recommended. If it's still not in specs after doing this by alot you might consider something is bent.
Nov 27, 2008 | 2001 Volkswagen Golf
Broken Caster
OK Master Draco,
Here is the scoop! The casters on your shredder are 30mm dual, swivel, threaded 1/4 x 20 x 1/4. These give you a rise of 1.5 inches above floor. Trying to match this spec is very possible but a little expensive (of course if the mfg made parts available it would be actually cheap. But they don't soooo).
My research found 71 manufacturers of the product that you need. The cost of getting production samples (which are free) to the USA is a minimum of $25.00! Out of sight for this project.
So, Hamar, what do you suggest??
I suggest that you go to PetSmart and purchase item #2755096 for $6.99 and replace all four casters. This will raise your shredder off the floor a bit more but since your raising all the corners it won't rock you to sleep trying to keep it level.
That's the best I could do...anyone else have a better solution?
haMAR
Mar 29, 2008 | Cross Infoguard Shredder SX102M
Do the wheels easily come off this unit?
They should just be standard casters on the bottom. The tough part is laying the TV on its side to remove them.
Feb 07, 2007 | Toshiba 53HX71 53" Rear Projection...
Sony KP-61S75 TV Logo
23 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
