Question about HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001
HP Compaq Presario F700, making loud noise and getting very hot, running super slow. If not plugged will only last 20 mins on battery only
  • 137 Answers
System creating Noise/Heat MUST BE SHUT DOWN as Quickly as possible !!
you may hamper your computer.
Large Noise issues may be investigated only if you Open the computer Chassie.
It need Expert care and practice to open the systems.
You may give a try if you dont owe them or can take the risk.
after opening the chassie we can define the problem.. whether big or small.
Every problem has a solution !!
Rate this solution, Write a comment to keep in touch.
Posted on Sep 16, 2010
My compaq is power on for 2 second and off , how to fix is thank you
You need to print this out-on someone else's computer. Hope it works for you!
Remove the battery and charger/ac adapter/power cord from your Compaq Presario F700 laptop, press and hold the power button for 20 seconds to discharge any residual current inside the Compaq Presario F700 . This clears your RAM and is like a hardware reset. Replace the battery and charger/ac adapter/power cord and turn your Compaq Presario F700 laptop on.
Boot in "safe mode". As it starts up press F8, the computer ask you if you'd like to start in safe mode. Highlight "safe mode" and press enter. See if your laptop is booting up ok .
If your Compaq Presario F700 boots ok, do the following,
Try System Restore first,
Start Menu->All Programs->Accessories->System Tools->System Restore. Choose the most recent date before you the encountered problem. If it doesn't work, try the next date.
If System Restore does not fix it, as a last resort, you might need to fdisk, reformat your laptop hard disk clean and reinstall OS, that usually fixes all bugs. Before going that route, try following,
Uninstall unnecessary programs and applications.
Scan with a antivirus program
Scan with a spyware/malware program
DEFRAG C:
CHKDSK C:
Clean up and repair registry problems with registry repair software of your choice
If the problem persists, did you check if it could be your Compaq Presario F700 laptop power cord or power source problem? Defective or insufficient power supply might cause error messages that are misleading. Take the battery out and power on your laptop with the charger only. Make sure your Compaq Presario F700 power jack and charger plug tip are securely connected. Did you notice the power jack loose? You can find laptop power jack on ebay. Fixing and soldering the power jack requires professional skill though. The charger green/blue LED should be on. If not, replace the defective charger. Compaq Presario F700 laptop battery charger, especially its power cord/cable, lifespan is limited and does not last forever, consider buying a lifetime warranty charger online from company like www.topmic.com
Dec 29, 2012 | ASUS K52n-a1 Notebook
Iv locked my bios password and cannot get into my bios... its a presario f700 i dont remember setting one in the first place pretty random but yes any help much apprectiated
remove all power from hte computer and the bios battery for about 10 min then put it back together this should reset it back to factory.
Jul 01, 2011 | HP Compaq Presario F500 F700 and G6000...
Compac Presario F700 makes constant humming noise
Sounds like its the fan . The more demand you place on the system makes it run hotter so the fan speed automatically increases to compensate
Jan 19, 2010 | Compaq Presario 700 470024-192 Notebook
Loud buzzing noise......possibly the fan?
is the battery ok? have it tested, sounds like a weak battery that is failing, the battery lasts about 2 years in most laptops.
Sep 04, 2009 | Compaq Presario Fan
How do i unlock my compaq presario f700 laptop computer
See this article. You may have to contact HP support or take it to an HP authorized service center.\
Sorry, those passwords are there for a reason.
Make a list and keep it somewhere safe away from your computer, where you can refer to it in need.
Aug 14, 2009 | HP Compaq Presario F500 F700 and G6000...
Presario f700 no fan/lights = nothing at all. The charger works
try to jump green and any black wire from the power supply...if the fan dont work..power supply is damage..need to change..
Jul 14, 2009 | HP Compaq Presario F500 F700 and G6000...
Compaq F700 Battery live very less
Giri,
Its normal, generally it comes with 80-90 min. You can use HP Power management to optimize the use of battery. Making screen less bright will increase the power backup.
Thanks
Iqbal
Apr 28, 2008 | Compaq Presario 700 470024-192 Notebook
Hearing noise while switching on/off
Monitor clicks, pops, or makes other noises. Noise when turned on or off. It is normal for standard computer CRT .
How can I make my computer quieter? If your power supply has a power switch on it, you can easily determine how much noise your power supply generates by disconnecting it from the motherboard.
Good Luck, Read and follow instructions/Please dont for get to Vote/Thank You.
Dec 26, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001  Logo
357 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
