Question about Philips Shielded Serial Cable (A-PCC003-WW)
Connecting my pc to my tv
When i try to connect my pc to me phillips tv via a mdh1 cable it is'nt working. I think i may be missing a cable or two, as it says on the screen "no input signal".
  • Anonymous Aug 14, 2008
    connecting my laptop to my tv. It continually says no signal.
  • 51 Answers
Verify the settings for your monitor are correct. with a video card that supports an HDMI output you should be able to go into your display properties (maybe advanced properties) and either force the TV detection or force the HDMI output to be enabled so it's displaying on your PC and your TV simultaniously. I know with N Vidia GeForce video cards you can do this and with most major brands it should work similarly.
Posted on Jul 01, 2008
How do I change source resolution on my TV?
connecting PC to Tv through VGA - Tom's Guide
Nov 20, 2013 - Q: Can I connect the TV to the PC via a VGA cable...bearing in mind the .... Forum; SolvedI'm trying to connect my Sony bluray player home ...
Connecting my Plasma to my PC via the VGA port. - Forums - CNET > Forums > Samsung
CNETJun 11, 2015 - Ensure that the VGA cable is working properly using other methods. Perhaps .... I am trying to connect my pc with my samsung tv. .... I'm very sorry to hear that has happened, and I apologize for any inconvenience this may have caused you. Connection between Dell laptop and Samsung TV
Jun 11, 2015
How to connect computer to tv with sound and picture?
Jun 5, 2015
PC Audio won't play through connected Samsung LCD TV
Jun 4, 2015
Connecting computer to TV
Jan 18, 2008
More results from
My custom built PC will not connect to my TV via VGA cable ... > Forum > Graphics Cards
Tom's Hardware Guide
Jun 28, 2013 - 5 posts - ‎2 authors
Jan 31, 2016 | VIA Computers & Internet
Phillips MT1400, saying no video input, what lead is missing
There should be a video cable you connect to the video card and also to the monitor. It should look something like this.
I also notice that it has a TV out. There would also be a co-axial cable output close to the VGA output. That would connect to the TV. If you want to use the TV though you will need the proper software to operate it or expand your desktop to it.
Mar 09, 2015 | Computers & Internet
I can't connect my sgh u700 with my pc via cable
Should'nt be a big deal- Remember not to plug in the ph till told too when your first installing the software?
tryed rebooting PC
tryed rebooting Ph
That does'nt work try using a differant USB port
May 05, 2011 | Samsung SGH-U700 Cellular Phone
Issue playing audio from AcerTravelMate6593 on Phillips37PFL7603D
You need to run the audio out to an amplifier such as a stereo unit. The computer doesn't have enough power via the line out to make the TV pick up the sound by itself unless you turn the volume all the way up and maybe not even then, so an amplifier is your answer. It work for me.
Aug 17, 2009 | Acer TravelMate 6593-6656 Notebook
No sound via TV when PC connected
1. Ensure the TV is set to "home" mode in the user menu. If set to "Shop" it will not retain audio settings change
2. verify that the Audio out from the PC is working. Use a set of headphones just to verify
3. Triple check that you have the audio input assigned to the correct HDMI input
4. after doing these if it still doesn't work, I would suspect the Software update had a side affect that phillips is not aware of. Since this function would probably be missed by Phillips software testers, it is highly likely that this is possible. Contact phillips and let them troubleshoot the problem with you. Let them know it happed after you did the update also and let them know that you have verified the audio out from the PC.
May 20, 2009 | Philips 42PFL5603D 42 in. LCD HDTV
Blu Ray connection on notebook to tv
i would go with the dvi or, avi pc inputs. this will mesh well with this Phillips.
Feb 15, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
No 5.1 surround when adding a Philips upconvert player to the San
Sounds like you are getting analog signals from your componet cables and a true digital input from your HDMI into your tv.
However that unit is Analog audio input x 1 only.
So i dont think your going to get true digital surround sound.
The problem being
Sanyo =
Inputs: Analog Audio x 1 Outputs: Composite x 1 · S-Video x 1 · Component x 1 · Digital Audio Coaxial x
Feb 03, 2009 | Sanyo DWM-2500 System
Samsung LCD TV not receiving PC signal
Check your vga cable. Some cables have only 14 pins, some have all 15. The missing pin is pin 9, in the 15 pin cable it carries 5v from the graphics card to the screen. Without that 5v signal most LCD and Plasma television screens won't recognise a PC input. I had the same problem and only managed to fix it when my girlfriend swapped a cable over for me and as she did so glanced inside and said "it's got a bit missing" The cable that came with your PC most likely only has 14 ins as that is all a monitor screen needs.
You can buy a 15 pin cable at most PC or electronic shops, just check that isdoes have all 15 pins befiore you buy it. The cheap ones are just as good as the expensive ones unless you are buying 20 foot cable. For 6 foot cable the cheap ones are just as good as the expensive ones.
Mar 08, 2008 | Televison & Video
Philips Shielded Serial Cable (A-PCC003-WW) Logo
103 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
