A signature kirkland washing machine that used to work 2 years ago has just been reconnected. the problem is that when the machine 1st starts filling up with water, the water starts emptying through the drain pipe. At present there is 2" of water in the machine that has not drained out, but any higher level of water appears to just drain out? Any suggestions?
  • 11,896 Answers
Drain screen is plugged. Only the overflow is draining. Clean drain and drain screen and double-check the pump to make sure it is cleaned out.
Posted on Sep 16, 2010
My kirkland washing machine filled with water worked for a whole stopped I checked plug put in different socket and it worked then stopped again. Next day ran a empty load just with water did great. Just...
If the program seems to stop in between , check and see if there is any circuit tripping or loose connection that can cause a connection failure and so trip the program to stop. If there is interruption the processor will shut off. so check this out.
Feb 28, 2013 | Washing Machines
I have A whirlpool kirkland signature 4 cycle heavy duty xl capacity dryer that is not putting out the heat as it was A few days ago. I have cleaned out the vent area to the outside and still nothing. The...
did you clean out the duct that the lint filter slides down into?also remove the vent line from the back of dryer and start it,if it blows strong you still have something in the vent line,stick a leaf blower into the vent line and blow it out to the outside,if the vent is clear then you know there's a block in the dryer or you have a bad blower wheel,if the wheel is bad when you first start it you might hear the blower wheel banging around or make a sound that isn't supposed to be there,i don't know what a kirkland dryer is so next time open the door and send the model number off of the dryer.
Dec 28, 2017 | Dryers
Washing Machine
the main water valve that the fill hoses connect too in the back of the washer is probably bad.
Jul 25, 2008 | Indesit W 123 Front Load Washer
Kirkland Signature by Whirlpool Washer
There could be 2 possible issues, one, the simplest is the switch activated by the lid, look for a plastic "prong" sticking out from the lid, see where it goes and find a switch, use sometime of similar size and see if you can activate it. If that is eliminated then it is a plastic coupling broken, quite involve, need to remove the back lower section and inspect for this, Had both these issues myself.
Apr 01, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
