Question about Cuisinart DCC-2000
The unit has started to leak water and is not too full. Is this something that could be fixed without sending it back? It's only 2 years old.
  • burgroot Sep 16, 2010
    Thanks for the info, I thought it was something simple since I haven't dropped it or abused it in any way.Could I order it from Cuisinart, or is there some place around northeast Ohio that I could buy it now? If there is a generic size to replace it without any special attachments, I could run out and buy it and save time.
  • 944 Answers
You have to replace the dispenser tube.It has to be replaced.Since you say you have used for 2 years.The tube has a bending that will become bad after years.So only it leaks.You have to replace it.
You have to take apart the screws to replace it.It costs very less only.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 16, 2010
  • Natarajan Ramasamy
    Natarajan Ramasamy Sep 16, 2010
    You can buy from Cuisinart service center.Since i am not from your country i cant exactly help you in this.No size is needed and no attachments is needed.
    Thank you do vote for me.
2000 Frontier, fuel tank leaks when full, live in north east, so rust likely, dealer previously did the recall on the sending unit, where do these systems tend to rust... or is there something else likely
im thinking its the sender unit gasket leaking or the filler hose from the tank,,or even the fule pipes
,rust in a 9 year old car???
mine is 15 years old,,no rust just yet!
Mar 14, 2010 | 2000 Nissan Frontier
Water leaking out of bottom of unit, near reset
Here is a tip that I wrote about how and where a garbage disposal will leak and what can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
p
Nov 11, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My Brunn coffee maker is leaking from the bottom also.
I have the same problem and I took the coffee maker apart to find out why. The fitting for the hold in the black pastic that the water flows through to get into the stainless steel tank may not have a tight fitting with the plastic and that's where I had water leakage. I used some silicone sealant to fix the leak and the water stopped leaking!
Sep 28, 2009 | Bunn 10 Cup Home Coffee Brewer
Unit leaking water,
if your humidity is excessively high unit wont be able to cope,try it again after hi humidity lowers
Jul 27, 2009 | EdgeStar AP450Z Portable Air Conditioner
Cold water trickles, hot water fills fast as normal
where your water lines connect there is a sc reen inside and if it is clogged with rust lime and or mineral deposit. it needs cleaned out. you can pull it out with a ice pick or something pointy. Check your screen first and if that doesn't fix ya then yes replace the unit.
Apr 18, 2009 | Kenmore 23822 Top Load Washer
Water is leaking from the bottom of the unit
The tune up kit that I ordered arrived on Friday and I installed most of it on Friday night. While it is nice to have a new frame and the distribution panel and I think the price of the whole kit was fair considering it comes with the parts and 2 water panels, the fix was really simple.
The kit came with the water distribution tube with with a new blue orifice (Aprilaire #4232) already inserted. This orifice is in the end of the plastic tube at the solenoid end. When I removed the old water distribution tube, the old orifice was not really dark blue anymore but kind of a light blue and was deteriorating from 12 years of exposure to the chemicals in the water. What should have been a pin-hole size opening in the orifice was up to about 2mm or a little more so the orifice was letting way too much water through.
If anyone else has this leaking problem, and your orifice is several years old, I would check that first. It is a $2.75 part and may be the cause of the leak. The whole feed tube kit is only $8.75 and includes the feed tube, nozzle, orifice, ferule, compression nut, strainer so if you need to replace the orifice, I would order the whole feed tube kit for a little bit more.
Hope this helps,
Roger...
Jan 17, 2009 | Aprilaire 700 Humidifier
1 1/2 years old 5 tons leaking yellow rusty water
Most likely yours has a scroll compressor which are notorious for being quite loud on start they will start for years, just a liitle noisy. Is the water from the pvc drain or from the base of the outdoor unit??
Oct 02, 2007 | Carrier 38CKC036 Air Conditioner
LG Dehumidifier Not Working
the freon has leaked out, must be replaced.
Jun 05, 2007 | LG LD65EL Dehumidifier
Coffee Makers & Espresso Machines Logo
511 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
