Question about Frigidaire GLTR1670A Front Load Washer
My machine sounds like it is going to put a hole in the floor from the terrible thumping noise.
    Genius:
  • 1,044 Answers
Two reasons The bearing of the rotating motor or the connecting bush is worn out. The suspenders which hold the drum are loose or one of them is broken
Posted on Sep 16, 2010
2002 toyota corolla thumping noise between 30 j 40 mph
If it only did it once then it was a road problem most likely and not the car.
Oct 22, 2012 | 2002 Toyota Corolla
Creda simplicity TVU1 tumble dryer is making a thumping noise while drying
Hi dave hemming.
I do not believe it is a bearing that is causing your thumping noise
No...you do not need a new drum...all you need is new drum rollers
You probably have a flat spot on one of the rollers, it will make the thumping sound when the drum rotates.
Go to the following webpage and get your drum rollers and install them and that should take care of the noise you are hearing
Please take time to rate me
Bud
http://www.appliancepartspros.com/index.aspx
Oct 13, 2012 | Dryers
2002 olds intrigue shakes while idling with brake on in drive
The cause is too low an idle and engine is starving for fuel so it shakes like that.The thumping sound you hear is most likely just the exhaust being too close to the floor amd bumping against it when in drive with brake on.You said yourself that it stops when you put it in nuetral,well the engine speed goes up when there's no stress on it.With some one holding the brake and it's sitting there thumping,set the idle speed up just enough to make the engine stop rocking that way.
Sep 14, 2012 | 2002 Oldsmobile Intrigue
Washing machine - terrible noise during spin cycle
sounds like the drum is rubbing on some part of an exterior wall of your washer,.or you have a bearing going, or worst case scenario you have transmission problems and need to get a serviceman in to check your machine.But firstI would call the manfacturer and explain the problem they may be able to resolve it over the phone give them model no. Make and year of manfacture they hopefully can help you with this
Jan 07, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Rubbing and Clicking Noise in Dryer.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth  is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth
Mar 07, 2009 | Kenmore 98702 Stacked Washer/Dryer
2005 expedition rear a/c makes thumping noise when transferring
Sounds like the roof/floor actuator internal gear is stripped. The only way to fix it is to replace it. Remove the cup holder in the right rear trim panel. remove the 8mm bolts holding actuator and replace.
Feb 01, 2009 | 2005 Ford Expedition
Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore front loader model 417.29042992
check and make sure the washer is LEVEL otherwise when in spin, it may "walk" across the floor. also if it's not level then the tub will "tilt" in one direction and may contribute to the thump, thump.
Aug 23, 2007 | Kenmore 43042 Front Load Washer
Frigidaire GLTR1670A Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
