Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Ice Maker Works but water dispenser does not work
I have no problem with the ice maker but the water dispenser sometimes works but most of the times does not. We have replaced the water filter so that is not the issue.
Hoping you have some suggestions.
  • 1 more comment
  • Dehydrated May 18, 2008
    My 2-year old refrigerator model JSI-26 ice maker does work but water dispenser just stopped.  I had the cellenoids checked (they were fine) and we cleared out the line from the dispenser down to the base of the door which had iced-up.  Then it worked until morning.  Help?
  • Anonymous Oct 26, 2008
    ice box works but water dispenser doenst
  • lordsever3 Oct 26, 2008
    my ice despencer is fine but my water dispencer never works
    help? please
  • 218 Answers
SOURCE: Ice Maker not Getting Water
There are two solenoid-operated water valves - one for the water dispenser and one for the icemaker. They're located near the water connection at the back of the fridge. There is no pump; the water pressure sends water to the icemaker whenever this valve is opened by the icemaker controls. Your symptoms sound like the coil is burned out on the valve. You can check it by disconnecting the wires and checking for coil continuity with an ohmeter. If the coil is open, replace the valve. Both valves might be combined into one assembly, so be sure you test both coils. Of course it's also possible that the trouble is in the icemaker itself, but a failed intake valve is more likely.
Posted on Jul 23, 2008
maklean
  • 1665 Answers
SOURCE: no water to ice maker
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Posted on Jul 28, 2008
    fanny
    • 146 Answers
    SOURCE: Kenmore elite (106.53606202) ice maker will not dispense ice
    When you push the ice dispensing lever, you should be able to hear the micro-switch clicking. If no click, the switch is faulty. The auger motor which is activated by the lever could also be faulty. This is the motor that causes the auger in the ice bucket to rotate one way for crushed ice and the other way for cubes. The auger could also be jammed. Try switching between crushed and cubes to unjam the auger. Empty the ice bucket and start again.
    Posted on Nov 03, 2007
    SOURCE: Ice maker
    I am having the same problem with mine.
    Posted on Jul 15, 2008
    duby1990
    • 367 Answers
    SOURCE: ICE MAKER NOT WORKING
    Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
    Posted on Nov 20, 2008
    Samsung side by side ice maker not working
    You have 2 separate valves, 1 for the water dispenser and 1 for the ice maker. (otherwise your ice maker would overflow every time you got water from the dispenser and your dispenser would flow every time the ice maker went to refill.) They are fed from the same tubing.
    The cube/crushed ice motor is completely separate from the ice maker itself and should have absolutely no bearing on the water flow.
    You have narrowed down the problem quite nicely to the ice maker water valve. There is one more thing to check though, the connector. There should be a multi-contact connector from the ice maker to the back wall of the freezer, usually 6-9 wires. Pull that apart and check the cord side (ice maker side) for any corrosion. BE CAREFUL NOT TO TOUCH THE OTHER SIDE AS THERE IS LIVE 110V!!! If you don't see any corrosion, still try try disconnecting and reconnecting 5-10 times and see if that solves your problem. If you see corrosion, unplug the refrigerator before working on the back wall part of the connector. [This connector besides powering the ice maker also allows the ice maker to control the water valve which can't be inside the freezer]
    Sep 03, 2016 | Samsung Refrigerators
    Ice maker quit working but water dispenser still works,the reservoir to make cubes also empty.can you advise?
    If the ice maker tray is empty you may have a water valve failure. usually this unit have a dual valve 1 for the dispenser the other one for the ice maker some time a side fail and the entire solenoid have to be replace. the ice maker can also be bad. an easy way for you to test if ice maker is good is by putting water manually inside the ice maker tray depending on how cold is your frig wait about 2 hrs or less if the ice maker cycles and drop ice then water solenoid is the problem if not then replace ice maker.
    Dec 20, 2014 | KitchenAid Refrigerators
    I have a Maytag Plus side by side with Ice maker and water dispenser in the door. I have replaced both water valves and still cannot get water to the ice maker. The water to the water dispenser in the door...
    First you need to make sure the ice maker works. One way to test it is to manually put water into the ice maker and wait a few hours and see if it pushed the ice out. If it did not you need to find out why the ice maker does not work. There are many reasons for that; that would be a new chapter. If the ice maker does dispense the ice but does not turn on the valve you would need to find a loose connection. There is a way to test the "water fill" after removing the ice maker, but it is a little tricky. Then also, sometimes the fill tube inside the freezer freezes; that is another problem al together.
    May 20, 2011 | Refrigerators
    The ice maker does not seems to dispense any ice. It does have ice in the tray but won't tip into the ice bucket. Water dispenser works fine. If you turn the ice maker off and turn back on again, sometimes...
    The fix to your problem is to remove the ice, warm up the tray with a hair blow dryer and thoroughly dry it. Then spray it with PAM cooking spray which is an edible lubricant. After that dries, turn on the ice maker again and the ice will dispense. Joe
    Mar 08, 2010 | Fisher and Paykel E522BRXUSS Stainless...
    Ice maker will not make ice, water dispenser is working
    Here is a tip that I wrote about the reasons why ice makers do not work.
    Ice Maker Problems and Ice Maker Troubleshooting
    heatman101
    oypyiooiyp
    May 27, 2009 | Amana 22.6 cu. ft. Side-By-Side...
    My Jenn Air refrigerator ice maker quit working
    My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
    ice maker?
    bjones03@comcast.net
    Mar 25, 2009 | Jenn-Air JCD2389G Side by Side...
    Ice dispenser wont work....ice maker works
    Need to check and see if the water filter is stop up ,if you don't have a filter it I would start with water value at the bottom .
    Mar 14, 2009 | Refrigerators
    In door ice dispenser does not work but the water dispenser does.
    check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
    Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
    Frigidaire signaling water dispenser instead of ice maker
    Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
    Dec 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
    Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
    1,276 people viewed this question
    Top Kenmore Refrigerators Experts
    Sal DeAngelo
    Jim Goldsmith
    Jim Goldsmith
    Arnel
    Arnel
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
