Question about IBM Wheelwriter 6 Typewriter
Ribbon strike mechanism won't move and strike ribbon when key is hit
  • IBM Master
  • 3,594 Answers
You most likely have a broken plastic print solenoid cap.
We sell them for 20.00 with instructions and shipping.
DickyO
Cleveland Business Machines
216-241-0027
Posted on Sep 17, 2010
  • djbleything Sep 17, 2010
    If we wanted to buy this part from you, do we just call the number under your name?
    Is there a CA office?
Swintec 2500 printhead won't strike the cartridge ribbon.
there is a rubber seperator that is bad this will not let it hit hard enough to strike the print wheel. your local typewriter shop should take care of it.
Feb 01, 2017 | Swintec Office Equipment & Supplies
IBM wheelwriter won't strike. Ribbon is good. Wheel is working. Carriage is moving. Just not striking. I dusted & cleaned as well as I can, but to no good.
there is a solenoid that fires the hammer to strike ribbon and that most likely is the culprit. sometimes, you can clean solenoid and replace the little plunger to take care of the problem. however, it takes a tech or at least someone with very good mechanical skills to get to it.
good luck,
razors
Mar 16, 2010 | Office Equipment & Supplies
Letters aren't striking ribbon
Get some WD40 and spray it on thw segment (the place where the type bars are swung) then everywhere the key mechinism pivots.
DickyO
Apr 04, 2009 | Olivetti Linea 198 Typewriter
I put in new Brother ribbon - won't type. I hit code reset.
MAKE SURE THE RIBBON IS INSTALLED CORRECTLY AND IS BETWEEN THE TWO METAL "FINGERS" AND THE CARDHOLDER AND THE PRINTWHEEL IS LOCKED INTO PLACE (JUST PUSH FORWARD ON THE BLACK LEVER TO THE RIGHT OF THE PRINTHAMMER
Dec 19, 2008 | Brother GX-6750 Typewriter
Brother CE-70 typewriter. Was typing perfectly well. Over about 15 characters the impact on the print head reduced to nil. Although printhead appears to strike the daisy wheel the character does not strike...
Make sure that the ribbon is moving. If characters are piling up in the same spot on the ribbon you will get this problem. Easiest fix is to replace the ribbon. Many brand new ribbons can have a problem. If this dosent solve the problem it may be a mechanical problem with the mechanism that drives the ribbon, requiring a technician to repair.
Oct 22, 2008 | IBM Wheelwriter 30 Typewriter
Typewriter won't type letters
HI.. the hammer solenoid may be faulty..it should make a typing sound when you hit a key.( the printhammer moved and strikes the printwheel) or when you changed ribbons you might have unlatched the printwheel..there is a lever you press to relatch it until it "clicks"
If not that then make sure the ribbon is seated correctly, that it is between the printwheel and the black roller.Also visually inspect the ribbon so it is not caught in the printwheel.
Feb 06, 2008 | Brother ML-300 Typewriter
Lexmark Wheelwriter 2500
If th ribbon is lifting but not feeding you probably need a new ribbon.
DickyO
Jan 14, 2008 | Office Equipment & Supplies
Wheelwriter 6
You may need a ribbon motor or motor board, however on the older wheelwriters sometimes the gear mesh gets sloppy and gears jam tooth for tooth. Try moving the ribbon lift gear/cam on rt. side of the carrier by hand with the machine off if it won't move that's the trouble. Wiggle it back and forth and it may free up.
Dec 20, 2007 | Lexmark Wheelwriter 6 Series II Typewriter
IBM Wheelwriter 6 Typewriter Logo
98 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
