Question about Nintendo Wii Console
Dirt in my console
There seems to be some brown dirt (or chocolate) in my wii console. It works and everthing, I just don't know how to get it out. Please help!
  • bruno123456 May 19, 2008
    What do you mean Guest?
  • bruno123456 May 22, 2008
    It's OK. As long as it works i'll be fine
Posted on May 17, 2008
SO i went to play sonic hereos last evening and the disc has no scratches or finger prints on it and the disc is fine so I put it in my gamecube and turn it on and then it says the disc cannot be read so I...
Same thing with my gamecube console so I was getting ready to play my gamecube games and it said the disc cannot be read so I decided to check my disc;s and they look fine no scratches or dirt on them. So I tried it on a wii instead and that message didnt occur so the laser inside of the gamecube console leaser
is weak or it needs to be adjusted.
10 Stars if this solution is helping you out.
Mar 16, 2012 | Nintendo GameCube Console
What's your problem? the wii wont turn on
    • 1 Disconnect any accessories, such as GameCube controllers or SD cards.
    • 2 Unplug your Nintendo Wii AC adapter from the wall outlet and from the back of your Nintendo Wii. Leave the adapter disconnected for two minutes. Reconnect the adapter to the console and plug the outlet end straight into a wall outlet, not a surge protector.
    • 3 Remove the AC adapter from the wall outlet again. If the Wii has yet to turn on, the problem may lie within your electrical outlet. Plug a lamp, nightlight or something electrical into the outlet the AC adapter was connected to. If the outlet appears to work, then you'll have to test the AC adapter itself.
    • 4 Run your fingers along the AC adapter cable and visually look for any damage, such as frayed wires or a cracked piece of cable. Also look for the model number "RVL-002" and "Wii" on the adapter. If you don't see the "RVL-002" model number and "Wii" on the adapter, then you are using an unlicensed adapter, which can cause instability and power failure. If the adapter has incurred any damage, you will likely have to buy a new adapter.
    • 5 Spray air to clean out the vents on the back of the Nintendo Wii. If your Wii has been sitting for a long time, then dust and dirt may have built up around the vents, preventing the console from cooling itself. If the console cannot cool itself, it overheats and shuts down.
    • 6 Click "Start," "Internet Explorer" and visit the Nintendo repair page (see Resources) to open a repair claim. If you tried the above steps and your Wii has yet to power on, your system probably needs professional repair.
Oct 05, 2011 | Nintendo Wii Console
The screen on my Wii game is frozen and even if I unplug it, it just goes back to the same frozen screen. Please help!
Please check to see if there is any dirt or dust on the disc, this will often cause the game to freeze.
If the console has stuck on a frozen screen, please unplug from power for 10m then plug back in.
Your console should reset and start working normally again.
Mar 06, 2011 | Nintendo Wii Console
When i put my wii game in, the wii console does not read the disk! i tried all my games and turned the wii on and off but it still does not work!!
the laser lense is damaged is its still under warranty send it to nintendo otherwise replace the disk drive
Dec 16, 2010 | Nintendo Wii Console
Some wii game disks aren't being read. I know the
Take a can of air and gently blow some into the drive to make sure there is no dust or dirt interfering with the laser.
If after you do this and the drive is still having problems then the laser is starting to go bad and either the laser needs to be replaced or the whole drive.
Nov 26, 2009 | Nintendo Wii Console
Brown dirt coming out of steam iron
You're seeing hard water deposits and maybe a little rust. Use some CLR and pour in the iron and let it sit with it off. Shake it a bit and let it clean it all out, then rinse with clean water. (Vinegar will work too)
Jul 01, 2009 | Sunbeam 4214 Iron
Wii disk read errors
Fiend your solution direct from nintendo. Here is your solution....
Jun 21, 2009 | Nintendo Wii Console
My Kenmore Elite HE3 washer doesn't get the dirty laundry clean. It redeposits the dirt on the clothes, causing brown stains. I had a Sears rep look at it when it was new (5 years ago), and he said it was...
Brown stains are likely from the felt seal. The adhesive used from the factory disintegrate over time, and when you replace the felt - use some silicone instead.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 08, 2009 | Kenmore Washing Machines
On Wii sports the controller seems to work in every respect apart from when trying to swing on a game (e.g. tennis, bowls, golf etc) The buttons work. Also, the controller can go up and down and left to...
well i have the same problem , i have tried everthing so i just feel sorry for u knowing that u cant play on ur Wii so if u do get an answear could u contact me at"
Apr 27, 2008 | Video Game Consoles & Games
Nintendo Wii Console Logo
21 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
