Question about Sony VAIO PCV-V200G PC Desktop
Disk Drive will not eject/open - Sony VAIO PCV-V200G PC Desktop
  • 72 Answers
The drive is struck try insert pin at the edge and pull it out.....
Posted on Sep 16, 2010
Disk will not eject
Unplug the drive. insert a paperclip in the hole in the back of the drive. This will manually eject the disk. You can also open the cover but that's a lot more work than you need to go through when a simple paperclip will move the manual eject lever.
Jan 19, 2014 | Iomega Z100P2 External ZIP Drive
Eject a disc from the desk top
Push the eject button on the drive. OR open MY COMPUTER, right click on DVD/CD rom drive, eject. If all else fails, remove drive open case remove disk, inspect for debris in drive.
Nov 25, 2012 | Dell INSPIRON 6000 CENTRINO...
How to eject dvd disk samsung laptop no eject button?
There are two ways toopen the CD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drivetray next to the Eject button. Push the paper clip gently until the drive traypops out, then pull the tray until it is fully out, then you can remove the CDdisc.
If you continue having problem opening with the Eject button, then the CD driveis faulty and needs replacing.
Apr 01, 2012 | Samsung NC10-14G Notebook
I can't open my disc drive on my Acer Aspire 5820T without using a pin. How do I get the eject button to work?
I suggest that you can use the other method to eject: press start and go to my computer, select the disk drive and you should see an eject option in the menu bar.Remember that disk drives are subject to computer admin and do not respond quickly to a button press, especially if a disk process in taking place...
Mar 03, 2012 | Acer Aspire TimelineX 5820T-5951 Notebook
Disk drive door wont open. LED light comes on an hums, but tray wont eject to open. Where is manual eject hole located?
Below the drive tray there is a tiny hole, straighten a paper clip and gently insert the paper clip into this hole. Push the paper clip and the tray will release and pop out, then pull the tray out to the fully open position.
Mar 02, 2012 | Computers & Internet
My hp laptop keeps ejecting disc itself when i insert any disc. Wat do i do pls
> keep ejecting
The disk-drive is having a mechanical problem, i.e., it is not fully-loading the disk,
or it is not detecting that the disk is fully-loaded. Therefore, it assumes that the open/close
mechanism is "jammed", and so it ejects, to indicate that the disk-loading was not completed.
Replace the disk-drive.
Jun 26, 2011 | HP Computers & Internet
I have a disk in my apple computer that will not eject when I press the eject arrow
If you look carefully you will see a pin hole on your disk drive built in to your apple computer.
The disk inside the disk drive might be stuck or the there can be some damage in the disk driver. Either ways you can insert a sharp pointed object like a needle or a pin in the pin hole. This will eject the drive.
If the disk drive does not eject, to avoid any further possible damage the laptop has to opened and the disk drive has to be removed and inspected. If the above solution solved your problem, You disk drive may start to function properly otherwise if there is no hole (since many disk drivers have no holes) or the insertion and poking of needle does not work the only recommended option is that you have to take it Repair shop or give it to a tech.
Good Luck!
Jan 06, 2011 | Computers & Internet
DVD does`t open. It have one disc inside and I need it. Exist one software command (by pc) that permit to open the dvd without use the open key? Thank you, Jorge Lopez
Any operating system that believes the disk is in use may restrict the disk bay from opening by the use of the drive button or a soft eject keystroke. In Windows this most commonly happens when the system believes itself to be actively accessing or installing from the CD/DVD drive when actually the disk is unreadable, the drive has become unmounted, or a software product has locked the drive. In this case, there is no soft key command to force it to open.
You essentially have three choices:
  1. Wait for the application using the drive to time out and then eject the disk normally
  2. Force quit the application or software that is monopolizing the drive then eject the disk.
  3. Restart the computer to terminate any processes currently monopolizing the drive.
  4. Force a paper clip in the small access hole to manually eject the drive. (I know this third is exactly what you didn't want to do)
Apr 26, 2010 | Sony (DDU1613) (ddu1613black) Internal DVD...
Dell Inspiron-1520 unable to read RW DVD's.
you have a faulty disk inserted in the drive. Restart the computer and continuously press eject while the pc is booting, it should eject then.
Oct 11, 2008 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Wii console
Im not familiar with the Wii but i will try to help.
Is it just not opening or is it actually physically Jamed?
If its jamed, try turning it upside down and then back to right side up, then try ejecting it.
There may be a pin hole on the front of the drive, just like a computer cd drive, get a thick paper clip and insert it, push hard till the drive pops slightly open, then pull it the rest of the way and remove the disk.
Last resort is to open her up and remove the disk drive altogether and then take apart the case, then you can use your finger to move the disk back onto the carasel and then eject it once its plugged back in.
Mar 25, 2008 | Nintendo Wii Console
Sony VAIO PCV-V200G PC Desktop Logo
20 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
