Question about Ricoh Caplio GX100 Digital Camera with 24-72mm
Card is write-protected. When I try to take a 'photo this message appears on the LCD
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Ricoh Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Sep 16, 2010
What does it mean "memory card is write protected?"
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 01, 2014 | Nikon COOLPIX S630 Digital Camera
I cant take photos anymore and the LCD screen says CARD'S WRITE PROTECT SWITCH IS SET TO LOCK.How can i solve this problem?
You didn't specify the make and model of your camera, so I'm going to assume it uses SD and/or SDHC cards.
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
If this doesn't do it, try another card.
Dec 28, 2011 | Cameras
I have a vivitar camera from a friend and she took her memory card out then i bought my own brand new memory card with nothing on it and new batteries too. then when i try and take a picture it says memory...
From the manual:
http://static.infoteldistributors.com/pdf/VC8025%20User%20Manual.pdf
Installing SD Memory Card
Your camera has a memory card slot that enables you to insert any "SD" compatible memory card up to 8BG. Adding a memory card will allow you to increase the capacity of your camera before you have to transfer photos and videos to your PC. Install the SD memory card as below:
  1. Locate the Memory Card slot within the battery compartment.
  2. Insert the Memory card into the slot in the correct direction. (see the sketch below)
7
  1. Push the card in until you feel it "click" into position. The top of the card should be flushed with the surface of the camera. An icon will appear on the LCD screen after you turn on your camera.
  2. Once the external memory card is inserted into the camera all the images taken with the camera will be stored on the card.
Note:
  1. Limited internal memory is provided for test images. The image will be deleted when camera power is turned off. Please download the images before power off .SD memory card is required for normal use.
  2. An external memory card is required for normal use. Your camera supports any compatible SD memory card (up to 8GB).
  3. If there is a photo in the internal memory when you insert the card into your camera, a "Copy to card" message will appear on the LCD with Yes or No options. On selecting 'Yes' the photo will now be copied to your card.
  4. Formatting will delete all data on the SD memory card including protected data.
8
  1. Don't remove the SD card during formatting as this may damage the card and render it unusable.
  2. When your card is full, download the media on the SD card to your PC and delete the photos and videos from it in order to continue using your
Dec 24, 2010 | Vivitar ViviCam 8025 Digital Camera
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
Can't take photos as it says card protected. I don't know how to unprotect it?
There are 2 protection that you have to check:
1) Check on your SD Memory card that on the side there is a small switch. Move it to the opposite position and reinsert in the camera. Take a picture and see if it is OK.
2) If still appearing the message go in the PLAY menu of the camera and where there is the entry PROTECT with a Key Logo select NO.
Then it should be working fine.
Remember that then your pictures are not protected anymore.
Regards,
PDG
May 09, 2010 | Fuji FinePix S1000FD Digital Camera
Card protect message doesn't allow any activity with camera how to remove?
Hi there
Face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this 59a6de4.jpg .
Good luck and thanks for using Fixya!!
May 25, 2009 | Toshiba PDR-4300 Digital Camera
Xd memory card
A card access error may indicate that an xD-Picture Card memory card is in a write-protected condition. xD-Picture Card memory cards have a special protection feature to ensure that your pictures are kept safe. NOTE: During this condition, you can still use the printer for printing and saving photos from the xD-Picture Card to a secure location, such as the computer hard drive. To resolve this error, try the following:
  • Reinsert the xD-Picture Card memory card into your camera and turn on the camera. In most cases, the camera automatically makes the necessary changes.
  • Reformat the xD-Picture Card memory card. See the documentation that came with your camera for instructions on reformatting the memory card. Note that this process erases the pictures currently saved to your memory card. To save these pictures, transfer them to the computer before reformatting the memory card. Once you reformat the memory card, transfer those photos back to the memory card using the computer.
Jul 29, 2008 | Fuji FinePix Z10fd Digital Camera
Locked on card protect
pp.5-6 of your manual has the information on locking/unlocking
Apr 18, 2008 | VuPoint DV-DV1-VP Camcorder
When swithched on the camera getting message protected card and unable to shoot photos
Try to slide the little switch on the side of the card in the other direction. That switch is like a write protect for the card. Good Luck.
Nov 16, 2007 | Gateway DC-T50 Digital Camera
Ricoh Caplio GX100 Digital Camera with 24-72mm Logo
47 people viewed this question
Top Ricoh Cameras Experts
Tony
Are you a Ricoh Camera Expert? Answer questions, earn points and help others
