Question about Electric Health & Beauty
My mom's Bladez DKS200 mobility scooter suddenly stopped working when she tried to take it up a steep hill. At first, even the battery light wouldn't come on, but after pushing the reset button, the battery shows a full charge and the horn blows but it's not moving at all. We've turned it off and on and engaged/disengaged the free wheel assembly. Is there anything else we can do to make it work?
Not exactly sure this is helpful, but make sure the bottom of the scooter is dry; all it takes is a little moisture and the scooter won't work.
Posted on Nov 17, 2010
Rascal Candy Apple. Why did it stop moving while I was driving it?
On the rascal, if your driving along and it suddenly stops, the throttle lever could be bad or the speed control could be bad or both. A battery lead maybe loose. The tiller cable may have slid back causing line interruption.
The flashing 4 indicates current timeout, the scooter may have been going up a steep hill, over heating the motor, turn off and allow motor to cool. then try again. if this happens on flat ground then check the parking brake, it maybe hanging up causing the motor to over work. Other trouble-shooting information for rascal, scooters on my free app.
Scooter Doctor App
Aug 11, 2015 | Health & Beauty
My panther MX4 quits when I'm going up hills outside.
what ah batteries do you have? have you tried going up hill at a slower speed? as you may be over loading the controller, is the scooter rated for the steepness of slope you are trying to get up? if going slower works take it to a mobility shop and ask them if they can reprogram the scooter, they may make a small charge for that.
Sep 20, 2013 | Health & Beauty
Whisper mobility scooter
hi, is that the one where the battery case sits on the contacts, if so that is a area you need to look at as this has been a common fault area , the string contacts get weak so losing contact when being jolted etc.
Regards
Jan 14, 2013 | Health & Beauty
Looking for a bladez DKS200 mobility scooter battery case?
http://www.bladezscooters.com/
http://www.monsterscooterparts.com/
Unlikely some other manufacturer's box will fit, if only because the circuit connecter is built into the pack.
May 03, 2012 | Health & Beauty
The scooter charges and shows full charge when started. Scooter will not drive uphill - certainly seems to lack torque - when driving up hill battery indicator drops to red
Either the hill is too steep of a grade/incline, the weight of the rider is more than the scooter is designed to carry, or the battery does not have enough power. If the batteries are old or have not been maintained properly, they may not be getting a deep solid charge that is needed to operate on hilly terrain. This is indicated when the batteries show a full charge, and then drop off quickly after a short period of use. Make sure that you are not exceeding the recommended weight limit for the scooter and that your batteries are less than 2 years old. Inclines of more than 5-6 degrees are typically not recommended for safe operation.
I hope this information is helpful to you, good luck!
Dec 27, 2010 | Electric Strider Mini 4 Wheel Mobility...
Scooter won't move forward or backward
go to electricscooterparts.com get a rear wheel clutch assemly fixed ours!!
Jul 25, 2009 | Cycling
Rascal scooter mo 655 motor stops going up hills
the batteries could be the problem, is it possible to try some other batteries, silly question , how steep is this hill ? remember scooters cannot climb steep hills as the motor will shut down due to the increased load.
1 Year old batteries ok ? but if they get used on a non daily basis and are not fully charged after use, I would question the batteries but again the motor could be overloading,
How much do you weight ? sorry for the personal question but it all loads the motor and that increases the current and that will cause the motor controller to shut it down.
Jun 14, 2009 | Pride New Mobility Legend 4 Wheel Scooter
Scooter battery problem
lots of things come into it driving up steep hills,useing lights,but you can get a larger amp hour battery witch make it last longer
Sep 28, 2008 | Amigo Rd 3 Wheel Scooter with 33AH Battery...
Health & Beauty Logo
360 people viewed this question
Top Electric Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
