Question about Craftsman 24 Hp 48" Deck Yard Tractor
How to replace Mower DriveBelt? - Craftsman 24 Hp 48" Deck Yard Tractor
  • stacey watkins
    stacey watkins Aug 31, 2013
    Can anyone tell me how to put a drive belt on the lawnflight 705 please
Tip
Replacing Riding Lawnmower Blade Belts.
I discovered on a Craftman Riding 3 bladed mower that there is an easy way to replace the belt for the blade pulleys.
The mandrel cover of the Left side blade is the only part you need to remove to replace the belt. You can insert the belt under the right side mandrel cover and onto the clutch pulley before finishing on the left side of the mower.
The tensioner or idler pulleys will contract when you pull on the belt. When you get to the left blade pulley you can turn the pulley with one hand and guide the belt with the other hand. The belt will walk right up onto the pulley. Attach the cover and you're done.
I like my method because you can stay away from a hot engine and replace the belt without waiting for the motor to cool off. You are also not fighting the mower clutch or drivebelt with my method.
on Dec 16, 2010 | Garden
How to change drive belt
Tom, see pages 23 and 24 from the link below. I have the same tractor but with the 22hp engine. It is much easier to remove the mower deck to replace the drive belt. Make sure your brake is set as this relieves tension on the drivebelt system. Good luck.
http://www.husqvarna.com/ddoc/HUSO/HUSO2006_USen/HUSO2006_USen_O0602053_.pdf
Aug 16, 2015 | Husqvarna Lawn Tractor - 54in. Deck, 26...
MOWER WONT MOVE
Drive belt broken or slipped of pulleys, hydrostatic drive filter(s) plugged. Should be one or those, Roger. Follow the drivebelt with your hand (disconnect battery to be safe) and see if it hasn't slipped off the engine drive pulley, idler pulleys, or axle pulley. If you tractor is hydrostat, may be time to replace filter.
Aug 09, 2015 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Change drivebelt
remove deck and drive the mower up on some kind of ramp and crawl under and look it over then go to doing it .
May 01, 2015 | Husqvarna 8 12hp Riding Mower 970 Blade...
Replaced drivebelt on troybilt riding mower now the forward pedal moves mower in reverse?
Sounds like you have the belt running in the opposite direction. You need to Change the way the belt is routed around the pulleys
Jun 18, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Mower has difficult time moving forward
Is the mower blades engaged if so check spindels if not check the transmisson but check all pulleys first
Sep 23, 2017 | Craftsman 20 Hp 42" Deck Lawn Tractor
Having trouble finding the right size drivebelt?
PLease find the correct category and re-post.
Jun 22, 2012 | Cars & Trucks
Lawnmower keeps slipping power drivebelt over rear sleeve
Usually, when the machine throws belts, the best thing to do is to replace the belt. Sometimes they are worn out or stretched, and you just can't tell it. I had a pristine looking belt on a pretty new mower doing the same thing. I replaced the belt, problem solved.
Best regards, and happy mowing! --W/D-- please feel free to rate this solution! Thanx!
Jul 31, 2009 | Garden
Craftsman 24 Hp 48" Deck Yard Tractor Logo
304 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
